![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"alphaQuad" <alp### [at] earthlink net> wrote in message
> They believe in freedom. They believe in your freedom and right to be
> wrong. The
> freedom to be yourself when it hurts no one. Freedom of speech was never a
> danger before fluoridated gullibility set in.
Have you read an MSDS for Sodium Fluoride? WOW!
The difference between a poison and a cure is the dosage....
SODIUM FLUORIDE
1. Product Identification
Synonyms: Floridine; sodium monofluoride; disodium difluoride; natrium
fluoride; Florocid
CAS No.: 7681-49-4
Molecular Weight: 41.99
Chemical Formula: NaF
Product Codes:
J.T. Baker: 3687, 3688, 3689
Mallinckrodt: 0467, 5309, 5325, 7636
2. Composition/Information on Ingredients
Ingredient CAS No Percent
Hazardous
Sodium Fluoride 7681-49-4 100%
Yes
3. Hazards Identification
Emergency Overview
DANGER! MAY BE FATAL IF SWALLOWED OR INHALED. AFFECTS RESPIRATORY SYSTEM,
HEART, SKELETON, CIRCULATORY SYSTEM, CENTRAL NERVOUS SYSTEM AND KIDNEYS.
CAUSES IRRITATION TO SKIN, EYES AND RESPIRATORY TRACT. IRRITATION EFFECTS
MAY BE DELAYED.
SAF-T-DATA(tm) Ratings (Provided here for your convenience)
Health Rating: 3 - Severe (Poison)
Flammability Rating: 0 - None
Reactivity Rating: 1 - Slight
Contact Rating: 3 - Severe
Lab Protective Equip: GOGGLES & SHIELD; LAB COAT & APRON; VENT HOOD;
PROPER GLOVES
Storage Color Code: Blue (Health)
Potential Health Effects
If inhaled or swallowed, this compound can cause fluoride poisoning. Early
symptoms include nausea, vomiting, diarrhea, and weakness. Later effects
include central nervous system effects, cardiovascular effects and death.
Inhalation:
Causes severe irritation to the respiratory tract, symptoms may include
coughing, sore throat, and labored breathing. May be absorbed through
inhalation of dust; symptoms may parallel those from ingestion exposure.
Irritation effects may not appear immediately.
Ingestion:
Toxic! May cause salivation, nausea, vomiting, diarrhea, and abdominal
pain. Symptoms of weakness, tremors, shallow respiration, cardopedal spasm,
convulsions, and coma may follow. May cause brain and kidney damage. Affects
heart and circulatory system. Death may occur from respiratory paralysis.
Estimated lethal dose = 5-l0 grams.
Skin Contact:
Causes irritation, with redness and pain. Solutions are corrosive. Effects
Eye Contact:
Eye irritant! May cause irritation and serious eye damage. Effects may not
immediately appear.
Chronic Exposure:
Chronic exposure may cause mottling of teeth and bone damage
(osteosclerosis) and fluorosis. Symptoms of fluorisis include brittle
bones,weight loss, anemia, calcified ligaments, general ill health and joint
stiffness.
Aggravation of Pre-existing Conditions:
Populations that appear to be at increased risk from the effects of
fluoride are individuals that suffer from diabetes insipidus or some forms
of renal impairment.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 13 Jun 2009 10:25:36 EDT, "alphaQuad" <alp### [at] earthlink net>
wrote:
>Stephen <mcavoysAT@aolDOTcom> wrote:
>> On Sat, 13 Jun 2009 09:43:48 EDT, "alphaQuad" <alp### [at] earthlink net>
>> wrote:
>> >My Dear John Dense Rim, (note I use ALL the letters of his name)
>> Give it a break! This level of rudeness is not appreciated.
>> Regards
>> Stephen
>Sorry you take it poorly. A poor humor attempt on my part I suppose, and a knee
>jerk reaction to his insanity.
>Regards to your too Sir,
> aQ
I do take it poorly, it does not sound like humour just rudeness. As does your
tirades against fluoride in the water supply. (If you had my teeth you might not
be so antsy.) I do understand that it is considered by some to be immoral to
force a medication on to the whole population and have my own doubts on the
matter. IMO your method of putting your point across is counter productive. It
makes for difficult reading and turns people off. Try the gentle way and if that
does not succeed then you have done your bit so you can just look after your own
self.
As for insulting a friend of mine by implying that he is insane. I do not
appreciate it.
One further thing, it might be polite where you come from to call someone sir
but I take it amiss. I am not a member of the nobility neither have I been nor
will I ever be a white slave master or anything of that ilk. It is not a sign of
respect to me but one of toadying.
Please tone it down.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You are barking up the wrong squid, Ken ;)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 13 Jun 2009 10:22:33 -0400, alphaQuad wrote:
>> Oh and "Jim", All my love to you in an attempt fill your void. I am
>> working on a solution to your condition.
> And REALIZE, it's NOT your fault, no words can put you down. Don't ever
> take it that way. That would never be my goal.
I appreciate that you *finally* got my name right. That's a step in the
right direction.
As to your words, you are right, your words cannot put me down unless I
let them. You need to learn to control your "knee jerk" reactions and,
as I said a couple of times, if you find yourself getting angry, take
your own advice and just walk away. Your failure to do that is what has
led to these confrontations.
As for me, I've walked away. So be proud that you got someone to take
one piece of your advice. But the more I read of your posts, the more
I'm convinced you need clinical help, and I urge you to do so. Whether
you do or not is your own business, but do it before you hurt yourself or
others in a real and irreversible way.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 13 Jun 2009 12:29:05 +0100, Stephen wrote:
> On 12 Jun 2009 20:30:56 -0400, Jim Henderson <nos### [at] nospam com> wrote:
>>On Fri, 12 Jun 2009 21:50:22 +0100, Stephen wrote:
>>> On 12 Jun 2009 10:51:13 -0400, Jim Henderson <nos### [at] nospam com>
>>> wrote:
>>>>Congratulations,
>>> AQ season ;)
>>Excuse me, I've just fallen out of my chair laughing. :-)
> <Takes a bow>
And well deserved!
>>Duck season!
> Anything but Fluoride season.
Mornington Crescent season! ;-)
Thanks again, my friend. Next time I'm in your neighborhood (or you're
in mine), first round's on me. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> wrote:
>>>>>Congratulations,
>>>> AQ season ;)
>> <Takes a bow>
>And well deserved!
>>>Duck season!
If only I had the time :(
>Jim
You're on :)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I hear ya there. We've got new exam going into beta that's consuming all
my time right now (along with a system redesign for part of the exam
delivery system). Will have to work over the weekend on some of it.
> You're on :)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, but what about vaccines, where having everyone take them is far more
effective than having only some take them?
Insanity is a small city on the western
border of the State of Mind.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
LOL!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You mean, _most_ vaccines. ;-)
For most vaccines (measles, etc), it's an economic decision - not a
health one. It's cheaper to vaccinate than to treat - and also saves
money with parents not having to take days off to take care of their
sick children.
That's why the HPV vaccine is having trouble, and why Gardasil et. al.
are becoming very aggressive in advertising. If it ever becomes
mandatory, it'll cost the (US) health industry *more* than if no one
were vaccinated - it would be the first mandated vaccine to put a strain
on the health care industry (resulting in lost resources for treating
other ailments).
All because the HPV vaccine is _much_ more expensive than the other
mandated vaccines.
Psychoceramics: The study of crackpots.
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
