POV-Ray : Newsgroups : povray.off-topic : New, open-source, free software rendering system for physically correct Server Time
19 Mar 2026 11:35:51 EDT (-0400)
  New, open-source, free software rendering system for physically correct (Message 31 to 34 of 34)
Subject: Re: New, open-source, free software rendering systemforphysicallycorrect
Date: 25 Oct 2007 22:38:01
Message: <47215309@news.povray.org>
Jim Henderson escribió:
> On Thu, 25 Oct 2007 15:51:31 -0300, Nicolas Alvarez wrote:
>> None of those forums have proper threading. People add their posts to
>> threads, they don't reply to other posts. Converting that to a tree like
>> it's shown on newsgroups wouldn't work at all.
> Actually, it can be configured to work properly with NNTP - I'm in the
> process of converting some private newsgroups to use that as a web
> interface.
It's more about how people use it than technical issues. If the web
interface has such a thing as "reply to this *thread*", people will
click on it; and where in the tree would that post go?
Also, really long threads (see below) are "wrong" in newsgroups...
Clients aren't really designed for that; for example, Thunderbird
doesn't let you collapse individual posts; only the first level of
nesting (threads) can be collapsed. Again, not technical reasons (the
protocol isn't really "limited" in terms of posts-per-thread at all);
it's just annoying to browse a 10000-post thread with news readers.
By the way, the forum->nntp linking I'm doing involves writing the NNTP
server itself, since I didn't find any code flexible enough to let me
stick any backend. POV-Ray uses DNEWS, but it's commercial software. I
found one that seemed to have the same goals as me (interface with
forums) but it's written in Python, and I don't know a single thing
about it.
-- insanely long threads --
* Ctrl-Alt-Del forum, "Official I need Help finding a CAD Comic Thread",
712 posts. In a sane NNTP server, it would be done by setting a whole
group for those kind of requests, and each comic request would go on its
own thread, with one or two or five replies, but not much more.
http://www.cad-forums.com/showthread.php?t=47935
* RCN BOINC project forum, Cafe category, "Last one to post here wins",
15135 posts at the time of this writing. Thread grows just for the hell
of it. I think no BOINC project lacks such a thread, with usually all
the same people :)
http://dist.ist.tugraz.at/cape5/forum_thread.php?id=12
I was told SETI@Home once had one of those "last to post wins" threads
reach *two hundred thousand posts*. An admin deleted it because it was
loading the database more than *anything* else (the forum software has
no paging; you can only get either the last X posts or the whole thread).
* And an even worse thread, again in Ctrl-Alt-Del forum. "The Official
Chat Thread". It's exactly what it sounds like: abusing a forum for
chat-like conversation. 76391 posts at the moment.
http://www.cad-forums.com/showthread.php?t=74371
Imagine those three in NNTP.
PS: Going off-topic is something completely normal of any
forum/newsgroup/mailing list/chatroom. Wasn't this thread about a render
engine? :)
Date: 25 Oct 2007 23:22:08
Message: <47215d60$1@news.povray.org>
Yes, but I am talking about a specific program that front-ends an NNTP
interface using an NNTP gateway.
Yes, but it does happen.  c.f. NNTP server forums.novell.com, group
novell.community.chat.  This is the testing group used at Novell, and it
holds a lot of random chat (with thread drift and so on).  There are
*NNTP* threads there that run for several thousand messages (there are
stats as well on this, as one of the moderators of those groups wrote a
program to parse the data stored in the newsreader he uses - Virtual
Access, I think it's called).
> about it.
Well, there again, the NNTP gateway on vBulletin is a generic RFC-
compliant NNTP client.  As such, it doesn't care what's on the backend
(Novell use Twister with Cyclone, which are commercial, but they can just
as easily be INN or DNEWS).
> 712 posts.
Tiny.  Very tiny compared to the long threads in n.c.c.  There was one
guy who wrote a program to just generate replies for the hell of it - and
it ended up being used to test the web-based interface in use at the
time.  And it broke it (the front-end provided by the company that does
Twister, in fact).
Maybe in your world, but Novell don't create a newsgroup per topic posted
in NCC - that would be nuts.  There's over 650,000 messages in that group
*alone*, and at one time, it was pegged as the busiest newsgroup on the
'net, with several thousand messages being posted each day.
> the same people :)
> thread).
Simple, the xover file could get quite large, but most NNTP servers can
handle it with enough disk space (spool tends to be the biggest issue).
I wouldn't do it with leafnode.  :-)
I mean really, NNTP message linking is essentially a linked list, linked
by reference field.  IIRC, the NNTP RFCs specify the first message in the
thread and the last 1 or 2 replies prior to the post itself, but many
newsreaders don't do that or tack on as many references as they can.
Some newsreaders stupidly thread by subject as well (fortunately most can
have this disabled).
> engine? :)
Yep, it was.
I've got many years working with the forums at Novell and most of the
iterations of software they've been through - Hypernews, Proxicomm,
Twister/Cyclone, Twister/Typhoon, and a few tests of some customized
software (KNova, for example, which ended up not being implemented).
And personally, I *hate* web-based forums, but I understand that
sometimes you can only use what's available through your firewall, and
usually that means "web".
The worst are the "flat forums" which are basically message lists (like
buffistas.org, which my wife has participated in in the past - I found
that incredibly difficult to read or follow).
Jim
Subject: Re: New, open-source, free software renderingsystemforphysicallycorrect
Date: 2 Nov 2007 14:14:48
Message: <472b7728@news.povray.org>
Waitwaitwaitwait I *just* noticed I misread that, not noticing you had
misread my post. Of course it wouldn't be a *newsgroup* per topic. I
meant a *thread* per topic. Making a "tech support thread" with
thousands of posts is what web forums do, and wouldn't work on
newsgroups. Making a "tech support group/forum category" with one thread
per question is what people should do; and how it works on newsgroups.
When somebody gets a rendering artifact in POV-Ray, he posts a new
thread on povray.general, like for any other problem. Some web forums
would have a sticky thread called "Rendering artifacts help" with
thousands of posts, and asking everybody with an artifact-related
problem to post there. I think that is a stupid idea.
Date: 3 Nov 2007 16:54:38
Message: <472cee1e@news.povray.org>
Ah, yes, well, as you said, thread drift is always going to happen, too.
But many "web forums" interchange "discussion group" with "thread".
vBulletin doesn't do that - it has an NNTP gateway that maps a newsgroup
to a forum.
I agree that it's a stupid idea. :-)
Jim
