![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here's one for you:
A single-layer DVD apparently holds about 4.7 GB of data. So ten of them
would hold about 47 GB.
That means that if I burn 10 DVDs and mail them to somebody, and it
takes 2 days for them to arrive, I have just achieved an average data
transfer rate of about 1 GB/hour. (About 0.2 MB/sec.)
But hey, why burn 10 DVDs when you can just buy a cheap HD and mail
that? (I'm guessing at this point the weight starts to become
takes 2 days for that to turn up, that's around 23 Mbit/sec -
significantly faster than any possible broadband connection.
rate!
On the other hand, if it takes 4 days to arrive, I just halved the
transfer rate. And the latency is, of course, abysmal...
I found the following quote on Wikipedia:
"The theoretical capacity of a Boeing 747 filled with Blu-Ray discs is
595,520,000 Gigabits, resulting in a 37,034.826 Gb/s flight from New
York to Los Angeles."
Somebody bothered to compute this?!? o_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 29 Apr 2010 14:01:26 +0200, Invisible <voi### [at] dev null> wrote:
> for that to turn up, that's around 23 Mbit/sec - significantly faster
Less than a quarter of the bandwidth I have had at home for several years.
Yet they failed to account for the time needed to record the three million
discs.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Which country do *you* live in? According to my data, ADSL has a maximum
speed of 8 Mbit/sec, and even ADSL2 stops at 12 Mbit/sec. So where on
God's Earth are you getting 23 Mbit/sec from?
> million discs.
Yes... It strikes me that if you really wanted to do this, you wouldn't
use BluRay disks, you'd use harddrives. (Much faster to access, and less
bunky too.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 29 Apr 2010 16:06:22 +0200, Invisible <voi### [at] dev null> wrote:
> According to my data, ADSL has a maximum speed of 8 Mbit/sec, and even
> ADSL2 stops at 12 Mbit/sec. So where on God's Earth are you getting 23
> Mbit/sec from?
Why do you assume I am using ADSL?
http://en.wikipedia.org/wiki/FTTB
Even if I did use ADSL(2+), I would still be able to get 24 Mbps.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I assumed it wouldn't be FTTB or ADSL2+ because, as far as I'm aware,
nobody has actually deployed these technologies yet. I've read about
companies who say they're *going* to do it someday, but I'm not aware of
anywhere that has actually *done* so yet.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
ADSL2+ is available pretty much everywhere here in Germany. If I paid 10
euro more per month I could have 16 Mbit/s instead of 8. Also if I lived
about 5 km closer to Munich I could get VDSL2 which is 50 Mbit/s :-D
It seems some companies are using ADSL2+ in the UK in limited areas:
http://en.wikipedia.org/wiki/ADSL2%2B#United_Kingdom
In some UK places you can also get internet via cable (I had this while I
lived in Oxford). Last time I checked you could get 10 Mbit/s that way,
probably higher now.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> of anywhere that has actually *done* so yet.
> 10 euro more per month I could have 16 Mbit/s instead of 8. Also if I
> lived about 5 km closer to Munich I could get VDSL2 which is 50 Mbit/s :-D
50 Mbit/sec... That's just trippy.
If they ever do replace all the copper with fiber, access to the
Internet should get a lot faster. (I always thought it was silly that I
was accessing the Internet using an infrastructure designed for narrow
bandwidth voice coms, but hey...) Don't hold your breath for that
anytime soon.
It says which companies, doesn't seem to say where. Presumably only
inside London at the moment.
> I lived in Oxford). Last time I checked you could get 10 Mbit/s that
> way, probably higher now.
I've only seen one person who had this, and she was on 2 Mbit/sec.
Still, one person isn't a large sample size, and it was a while ago now.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As usual, you assume incorrectly.
> I've read about companies who say they're *going* to do it someday, but
> I'm not aware of anywhere that has actually *done* so yet.
You need to read more.
http://en.wikipedia.org/wiki/ITU_G.992.5#Deployment
http://en.wikipedia.org/wiki/Fiber_to_the_premises_by_country
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> but I'm not aware of anywhere that has actually *done* so yet.
...so it's just a case of the UK being behind the rest of the world then?
(Also, notice how Fibercity is being trialled in Bournemouth,
*Northampton* and Dundee. Not Milton Keynes, but Northampton. God only
knows why everything happens in Northampton, not Milton Keynes...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://aws.amazon.com/importexport/
Linux: Now bringing the quality and usability of
open source desktop apps to your personal electronics.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
