Mike Raiford wrote:
> Sure, flash drives work easily enough, but any other piece of hardware
> usually requires you follow a specific sequence before you even plug the
> device in. Otherwise, Windows (not sure how this works on other
> platforms) will do magically bad things, such as install a persistent
> incorrect driver that takes several steps and a few sacrificed chickens
> to remove.
Clearly I don't have enough USB gear - I haven't had that problem.
(Although something similar happened with a SCSI tape drive. But then,
it's a SCSI tape drive...)
Not that anybody cares, but I have an outboard USB sound card, USB MIDI
interface, USB printer and a USB mouse. The mouse keeps not working...
everything else works flawlessly.
http://blog.orphi.me.uk/
Invisible wrote:
> Touch the wrong thing and they will scatter your ashes over the place of
> your choice - because you will in fact be fried to a human crisp long
> before you reach any hospital. ;-)
Mostly not. You'll need some ultimate stupidity to get your hands around
the PSU so that the shock won't throw them off from the PSU. Possibility
of getting some current trough your heart is the real beast - 50mA can
be enough to kill a healthy man.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethiszbxtnetinvalid
On Tue, 05 Feb 2008 12:12:29 -0600, Mike Raiford <mra### [at] hotmailcom> wrote:
>Stephen wrote:
>> Ouch! That woke me up is much more common than You deaded me.
>> Having said that you do need some common sense.
>Popping open a camera can have a similar effect. Most cameras have an
>onboard flash, which means they have a rather sizable capacitor. Touch
>the wrong thing ...
Caps should be shorted out before working. Use a resistor or a bucket of water
Drat I can't remember if I lie or tell the truth :)
Regards
> to remove.
Yes, that IS a Windows-feature. And yes, the hw-support is still much
better in Windows (more drivers), even though it has its problems.
Eero "Aero" Ahonen
http://www.zbxt.net
Invisible wrote:
> Darren New wrote:
>> Invisible wrote:
>>> http://www.apple.com/xserve/raid/
>> You can get a Dell with stuff like that for $3000. It's not *that*
>> expensive. You can get a 4T hard drive case for like $250 or something
>> (without the 4T of drives, of course).
> Oh, "only" $3,000. Bargin. ;-)
Well, the $3000 covers dual power supplies, hardware raid, dual giabit
ethernet, rack-mount, a year of Linux support from Novel, dual SATA 500G
hard drives, 16G of RAM, four dual-core 2.<mumble> CPUs...
Yeah, not too bad.
It's not your desktop machine, no, but $3000 isn't a whole lot for a
company. You can apparently lease them from Dell for <$50/month. Which
is like one good person's salary for an hour, counting taxes and
expenses and such the employer has to pay.
You can't look at stuff you run a business on and say "Wow, that's
expensive for a desktop", any more than you can look at a bus and say
"Wow, that costs way too much for something to commute to work in."
On what day did God create the body thetans?
Yeah. It sucks to give MS a driver for your hardware to be distributed
on the OS install disks, only to find out it doesn't actually work. :-)
I remember spending $12,000 on two 486 systems. Compaq Prosignia servers.
I still have them in the basement, in fact. No, they weren't bought by a
business - I spent my own money on them (in fairness, an advance on a
book I wrote back in the early 90's, plus a little of my own money).
Jim
In article <47a8a92a$1@news.povray.org>, voi### [at] devnull says...
e
> > to remove.
Its mostly low end, 'cheapy', stuff in my experience. Like the
inexpensive camera which a) didn't support **any** method to read its
memory as a HD, under *any* OS, and b) would suffer a massive memory
wipe if you *didn't* first install the drivers for it. Frankly, I wasn't
real impressed with the HDSD reader I got free with the 4GB card...
Stupid thing *acts* like its running through like USB v0.01 alpha or
something.. It doesn't read anything, including non-SD at a normal speed
and when trying to transfer large files (you know, anything bigger than
about 100MB...) it actually crashes. Most stuff works fine. Most stuff
designed by companies that have a clue work more or less OK without
extra drivers, but the drivers are needed for more than just reading the
internal memory. Then there are things like the v262 Motorola phone,
which their driver/transfer software didn't support out of the box,
needed two major patches to work, can't be accessed as a HD at all, and
tended to frell the XP machine you installed the driver on for *all*
phones, if something went wrong with XP SP2 and the driver, who didn't
like each other much.
Yeah, most stuff works OK, once you do the disc switch shuffle, but some
stuff.... Nothing short of an act of the FSM will get working acceptably
(or maybe a sacrificed chicken).
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
> Yeah, not too bad.
That's actually quite good.
it doesn't have half that stuff.
OTOH, Phil was complaining that you can't buy desktop machines that slot
together like lego. And I countered that you *can* buy such equipment,
it's just far too expensive to use as a desktop. ;-)
And lo on Wed, 06 Feb 2008 09:57:38 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> 500G hard drives, 16G of RAM, four dual-core 2.<mumble> CPUs...
>> Yeah, not too bad.
Succinctly put thank you. The whole thing is why hasn't the slot-together
style reached down into the standard market, and if it did how would that
affect 'normal' users' computer buying patterns. Instead of buying an
entire new computer would they instead opt to upgrade the old one because
it's a piece of cake to do.
I mean seriously I've listened to friends talking about upgrading their
entire computer to get more speed out of a game or something when all they
need to do is switch the video card (or *to* a video card rather then the
MB GPU). To them the computer is a lump like a television, opening the
case doesn't occur to them and I don't think they'd be enthused by what
they'd find if they did.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
