POV-Ray : Newsgroups : povray.off-topic : The Raysnail - WIP, a probability based raytracer with (limited) support for PovRay SDL files Server Time
24 Feb 2026 10:05:37 EST (-0500)
  The Raysnail - WIP, a probability based raytracer with (limited) support for PovRay SDL files (Message 1 to 10 of 15)
Subject: The Raysnail - WIP, a probability based raytracer with (limited) support for PovRay SDL files
Date: 17 Jul 2024 12:07:12
Message: <6697ec30$1@news.povray.org>
I've been using PovRay for many years, and I want to say I'm very happy
about the 3.8 release. Thanks a lot for that!
Something though that I had been missing in PovRay is what is known as
global illumination or path based lighting. Radiosity, supported by
PovRay, is very similar, but not quite the same.
First I've been looking into PovRay's sources to see if I can add such a
feature. But at the time I knew too little about both, PovRay coding and
the math behind path based lighting. So I put that idea to rest.
Recently I found a series of lectures, starting with "Raytracing in one
Weekend". It came with example code simple enough for me to understand.
But the real stunning point was, the third series of lectures was just
about what I had been looking for -  Monte Carlo integration of incoming
light and path based lighting (unidirectional). Aptly named "The rest of
your life."
Since some months I'm trying to learn Rust, and found that someone had
translated the example code (C++) from the first two lecture seasons to
Rust. So I tried to get my brain working once more and implement the
features of the third lecture season by myself. Much headache, I'm bad
at this sort of math, but it works now. Some examples are here:
https://github.com/Varkalandar/raysnail/wiki/Raysnail-Render-Examples
Now I had an Raytracer with the desired feature, admittedly a very
simple one. But I also had a lot of PovRay scene files which I had
written over more than a decade. I wanted to continue using these, or at
least continue in a similar manner.
And that's why I am posting here, it could be of interest for you. I've
started to implement a parser for PovRay scene files. It can't parse
much yet, but there are no technical limits on that level, it just takes
time to expand the parser. PovRay SDL is huge.
Here is an example file that the parser can read right now:
https://github.com/Varkalandar/raysnail/blob/e248884b4eb38f1d0f0dab8bca592c05516a5dde/sdl/example.sdl
The Raysnail will render this result from it:
https://private-user-images.githubusercontent.com/62077919/349234580-362117c3-13d9-44ce-a770-0a04d76021f3.jpg?jwt=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.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.M5Dyb6tp2I3chY8uO2nfikF-8xV2n4akmlvWGeV0dmQ
If the link doesn't work, please go here and scroll to the bottom of the
page, the image is included in the examples:
So far so good ... but there are also many issues. One is, that I don't
think I can emulate PovRay materials one to one. I can emulate a lot,
but there will be differences, based in the different approaches that
PovRay and the Raysnail implement to handle materials.
Other problems are that typical lights in PovRay are point lights,
infinitely small and invisible. The Raysnail needs lights with a certain
size to work. I likely can emulate PovRay lights by having really tiny
lights in the Raysnail, but they will still be visible as bright dots.
Long message. In short, I have a raytracer in the works. I am trying to
support PovRay scene files as good as I can. If you are interested in
this project, or have any sort of feedback, please let me know.
The code is here, not really cleaned up, but well, it's what I have:
Thank you for reading.
Subject: Re: The Raysnail - WIP, a probability based raytracer with (limited) suppor=
Date: 17 Jul 2024 12:30:00
Message: <web.6697f09911aab5a3c7a7971d6cde94f1@news.povray.org>
hi,
without having looked at code etc (I haven't the maths, anyway), a new feature
to complement the existing radiosity stuff sounds v cool.  and, as there are
(rumoured) developments beyond v3.8, your idea/code may well find its way into
the "next generation" POV-Ray.  _thank_you_.
regards, jr.
Date: 17 Jul 2024 13:20:00
Message: <web.6697fc4611aab5a3327467e125979125@news.povray.org>
You, Sir, are a legend.
And what timing!
jr, put this man "on the list"!
HJ, please take a look at these and see if they help any:
https://news.povray.org/povray.advanced-users/thread/%3Cweb.6369a6d45447eee1f9dae3025979125%40news.povray.org%3E/
https://news.povray.org/povray.advanced-users/thread/%3Cweb.636eec0e210cb4a81f9dae3025979125%40news.povray.org%3E/
I hope you'll have some time to document your discoveries about coding your
raytracer and BRDF model(s), but especially the parser part.  There are several
of us here that are intensely interested in all of that.
(Also, this seems an opportune time to recall a scene that several of us
remember, but none of us can find again:  someone wrote an SDL file to render a
keyword-colored SDL file (text {} objects), and sort of had to write their own
parser in the process.  I hope someday that someone will be able to find that
again.)
- BW
Date: 17 Jul 2024 14:25:00
Message: <web.66980c5d11aab5a3327467e125979125@news.povray.org>
> I've
I found this while on break:
http://disq.us/url?url=http%3A%2F%2Fkeepcalmandlearnrust.com%2F2016%2F08%2Fpratt-parser-in-rust%2F%3AVTzJuXKy2d8-o-HOB-
QkF3yoZ-s&cuid=968811
Date: 17 Jul 2024 14:38:48
Message: <66980fb8@news.povray.org>
coding > your
The BRDFs are still making my head spin. I understand the concept, but
struggle with the actual math to come up with proper BRDFs for new
materials of my own. So, let me point you to the source instead, the
lectures that I had been using myself:
https://raytracing.github.io/
The third book is about importance sampling and Monte Carlo integration.
It has probability density functions and also scattering functions for
the most important materials, like a diffuse reflecting material, a
specular reflecting material (metal/mirror) and a material which both
reflects and refracts (glass/transparent material).
If you want to look at some code, this developer also has made a
raytracer based on above mentioned lectures and added additional materials,
https://github.com/miguelggcc/QBVH-Rust-Ray-Tracer
Of particular interest will be the Blinn-Phong material and the
Ashikhmin-Shirley material:
https://github.com/miguelggcc/QBVH-Rust-Ray-Tracer/blob/master/src/material.rs
In regard to the parser, I want to say thanks to the people who wrote
the PovRay documentation. Each SDL element is documented with a snippet
of a grammar, which can be converted almost one to one into a recursive
descend parser. So the documentation is already there. I'll try to keep
the identifiers used in the parser code close to the ones used the
documented grammar, so the code will look familiar to those who looked
at the grammar from the documentation before.
I think the real need for documentation will come once I try to support
macros and similar advanced SDL features.
To be fair though, my code needs more comments in general.
Luckily github supports having a Wiki for a project, so there is a place
to write down discoveries, pitfalls to avoid and interesting solutions.
 > There are several
I was under the impression it could be of interest :)
PovRay has a great legacy, and one of the features that really set it
apart for me was the SDL. This, together with all the mathematically
exact objects, as opposed to approximation by polygon meshes as most
other raytracers do.
Date: 17 Jul 2024 15:10:00
Message: <web.6698169e1c222f09327467e125979125@news.povray.org>
Diagrams are definitely your friend.
Drawing the diagram with POV-Ray using the math that you're trying to work out
is also an excellent exercise.
I also found this video extremely useful
https://www.youtube.com/watch?v=gsZiJeaMO48
Maybe before you get too far into that, take a look at:
https://journal.stuffwithstuff.com/2011/03/19/pratt-parsers-expression-parsing-made-easy/
Date: 18 Jul 2024 09:40:00
Message: <web.66991ad111aab5a3f642b0d6f35e431@news.povray.org>
Are you aware of the UberPOV fork?
https://github.com/UberPOV/UberPOV
It's based on POV-Ray 3.7 and hasn't really seen any development for some time,
but one of its notable features is stochastic global illumination as an
extension to radiosity. I still use it quite often because I think it produces
much better results than the standard radiosity with almost no tweaking
required.
Maybe there's something there of interest relevant to your project!
Bill
Date: 18 Jul 2024 10:32:53
Message: <66992795$1@news.povray.org>
Now I am. Well, I had heard of UberPOV before but never really looked
into it ...
> required.
That matches my own impression and why I wanted something with global
illumination while still supporting PovRay SDL. This is quite
interesting, thank you for the link!
Date: 18 Jul 2024 10:38:47
Message: <669928f7$1@news.povray.org>
Interesting, I had not heard of PRATT parsers before.
I think I'll stick with a recursive descent parser though, because it's
a more widely known approach, even if the code is less compact.
The structure of a recursive descent parser resembles the grammar quite
closely which a benefit too, I think, with the grammar being of the docs
already.
Date: 18 Jul 2024 10:39:45
Message: <66992931$1@news.povray.org>
I haven't watched it all yet, but it indeed seems interesting. Thank you
for sharing the link!
