POV-Ray : Newsgroups : povray.off-topic : Friday WTF Server Time
26 Feb 2026 11:31:34 EST (-0500)
  Friday WTF (Message 1 to 10 of 24)
Subject: Friday WTF
Date: 18 Feb 2011 09:18:35
Message: <4d5e7fbb@news.povray.org>
"The file Data.csv is already open. You cannot open two documents with
the same name, even if the documents are in different folders. To open
the second document, either close the one that's already open, or rename
one of the documents."
Who knew Excel couldn't do this?
For that matter, who has any idea *why* it can't do this?! o_O
Subject: Re: Friday WTF
Date: 18 Feb 2011 09:24:52
Message: <4d5e8134@news.povray.org>
Because internally it uses some reference based on the filename of open
documents?  Or it would get confused if you tried to reference another
open document and there were two with the same filename?
Date: 18 Feb 2011 12:12:39
Message: <4d5ea887@news.povray.org>
Or the UI didn't have a place to put the path name of the file in your face,
and the Excel team decided it was easier to disallow that than to fix the UI
to find a place to put the path?
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 21 Feb 2011 03:19:53
Message: <4d622029@news.povray.org>
I did. And it's not limited to csv file: all files in excel must have a
unique name, and the path is irrelevant.
It might be due to its long history... and the display of filename in
the window submenu. (it might be for the "benefit" of the end-users, so
as to not confuse them.)
Excel is a sandbox: it make nice graphics (yet not all of them keep
being available across its versions) but is usually overused for database.
It's fine to use excel as a sketch, but any real production should stay
away from it. Alas, it's so eye-candy that it usually stays with the
uneducated people in charge (like CEO and other administrative/marketing
people).
Date: 21 Feb 2011 04:13:23
Message: <4d622cb3$1@news.povray.org>
> people).
It's true enough that my company's IT department keeps *all* of their
records in Excel spreadsheets. License keys, user account records,
everything like that... all spreadsheets. Never mind that only one
person can work on it at a time and that people can screw up each
other's updates and all the rest of it. How hard would it be to put this
stuff into a trivial Access database? Not very. But apparently our IT
department is too stupid to understand why this would be a good idea.
For my part, the entire reason that I'm using Excel is that I *want*
graphs. If it were somehow possible to make gnuplot draw graphs from CSV
data, I'd use that. (It's scriptable, after all.) But since it isn't,
I'm stuck with Excel.
Date: 21 Feb 2011 09:06:43
Message: <4d627173$1@news.povray.org>
Your friend on unix would be ploticus.
The script can read a separated data file in csv...
scripting in ploticus has a strange learning curve, best to copy & paste
from their gallery then play a bit.
For the lazy and/or always overbooked people:
http://ploticus.sourceforge.net/doc/welcome.html
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 22 Feb 2011 06:15:06
Message: <4d639aba$1@news.povray.org>
>> people).
Excel is good for simple databases with infrequent updates for many
reasons, the most important is that almost everyone has it installed on
their machine and most people are familiar with it.  If you store the
Excel file on a network drive it will get backed up regularly and ensure
that only one person can edit it at a time.
There are also more advanced features to lock ranges of cell based on
who is logged in if you want to limit certain parts of the database.  We
use this on a couple of files where managers have to authorise certain
items (it prevents non-managers from changing those cells).
If you have no experience with Access it's not trivial to set it up
properly, and if the only perceived benefit is that more than person can
edit it at a time it's unlikely to be seen as worthwhile.
Probably they just have other stuff to do they think is more urgent.
Date: 22 Feb 2011 06:28:37
Message: <4d639de5$1@news.povray.org>
> reasons.
It's like the fact that all screenshots are always emailed as Word
documents, even though it takes up far more space. It's just that nobody
knows any better.
We don't use that feature at all.
(Unrelated, but... I was astonished when I discovered how hard Access
security sucks. Excel is much better at this.)
> properly,
True. But we're talking about the IT department here. If we don't know
how to work it, what hope is there?
The other benefit of course is that you can trivially sort the data
without screwing it up. (Excel makes it very easy to accidentally sort
one column only, muddling up all the data.) It also makes inserting or
deleting records vastly easier. (The same goes for adding or removing
columns.) Don't even get me started on how difficult it is to
cross-reference data in a spreadsheet. (Although admittedly it's
unlikely you need to do that very often.)
This is from the department that has set most of our admin passwords to
"our1Tr0x!"...
Date: 22 Feb 2011 06:45:56
Message: <4d63a1f4$1@news.povray.org>
Err, you did turn on filtering first on your table (select the header
cells and click Data->Filter)?  This makes sorting and filtering a
no-brainer and AFAIK prevents people from sorting the data incorrectly.
If you need to cross-reference beyond simple drop-down selection lists
then you're probably beyond what Excel can easily offer as a simple
database.
Date: 22 Feb 2011 07:03:58
Message: <4d63a62e$1@news.povray.org>
Really? I had literally no idea that was possible. In 15 years of using
Excel, I didn't know about this. (I wonder how many other people didn't.)
Rather than clicking on an unintuitive command name buried in a menu, if
you click on the big "sort ascending" button right there on the toolbar,
it can *totally* mess up your data. Fortunately there's an undo button.
(I wonder how many people know that?)
> database.
I meant stuff like if you have one spreadsheet with all the license
keys, and another spreadsheet that tells you when each product was
purchased, you're going to have fun trying to link one to the other.
With a real database this would be a trivial table join.
(On the other hand, databases generally *need* to do joins more often
because the data is usually normalised - something people don't bother
with for Excel.)
