POV-Ray : Newsgroups : povray.off-topic : Excel question Server Time
11 Nov 2026 14:27:18 EST (-0500)
  Excel question (Message 11 to 15 of 15)
<<< Previous 10 Messages Goto Initial 15 Messages
Subject: Re: Excel question
Date: 16 Feb 2011 04:29:30
Message: <op.vqzonkcqmn4jds@phils>
And lo On Mon, 14 Feb 2011 16:13:24 -0000, bart <bar### [at] homeorg> did spake
thusly:
> On 02/14/2011 11:08 AM, Phil Cook v2 wrote:
>  >As an aside I'd use a "Worksheet_Change" on the sheet itself
> Yes, it seems more practical, especially in case of many worksheets.
>  >and "If Not Intersect(Target, Range("B:B")) Is Nothing Then" and
> "Source.Formula"
>  >to maintain the added value.
> Yes, as I said, it's a start that could be extended to fit one's needs.
>  >Good that you remembered "Application.EnableEvents = False" otherwise
>  >the scripted change will trigger the script again
>  >and it's infinite loop time; so easy to forget
> That's exactly what happened with the first try ;)
> There are many ways of doing things in Excel,
Oh hell yeah; I wasn't offering negative criticism. The problem is that
when anyone offers a solution it can be slavish followed without an
understanding of how it works; then it mutates to fit a situation rather
than reworked. Offer a different approach and hopefully people might take
a closer look and ask "What's the difference?" :-)
> I wander
> what is the real reason behind the original question,
> since it looks like a minimal example.
> As possible application I could think of, say
> - some kind of non-trivial custom auto-correction;
> - instant conversion of typed formula to value;
> - some tricky content-based auto-format...
As mentioned the normal case would be putting A+B into the next cell. It
would be possible to hide the entire B column when printing if that was
the sole purpose; but I think a PivotTable provides the most customisation
without getting too deep into VBA.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 16 Feb 2011 12:38:49
Message: <4d5c0ba9$1@news.povray.org>
Phil Cook v2 wrote:
> But the advantage of the pivot table
OK. I'm not familiar with the details of how pivot tables work. Thanks!
> Yes it's a common technique to put 'workings out' on another sheet and
> then hide it; the formula is "=SheetName!Cell"
Cool. Thanks!
  "How did he die?"   "He got shot in the hand."
     "That was fatal?"
          "He was holding a live grenade at the time."
Date: 17 Feb 2011 05:03:50
Message: <op.vq1kwulemn4jds@phils>
And lo On Wed, 16 Feb 2011 17:38:47 -0000, Darren New <dne### [at] sanrrcom>
did spake thusly:
I don't think many do, which is a shame. I'd bet a lot of duplication of
data occurs because of this. Well worth playing with them
> Cool. Thanks!
Nada. If you really want the sheet to be hidden rather than use the
toolbar a quick bit of VBA will stop it showing to causal users who
understand the Hide|Unhide command - Sheets("SheetName").Visible =
xlVeryHidden attached to the Workbook then password protect the module.
Phil Cook
Date: 17 Feb 2011 09:53:04
Message: <4d5d3650$1@news.povray.org>
It also could be placed in another file, like
"='C:\temp\[Book1.xls]Sheet1'!A1"
Date: 18 Feb 2011 04:47:46
Message: <op.vq3et3qmmn4jds@phils>
And lo On Thu, 17 Feb 2011 14:53:02 -0000, bart <bar### [at] homeorg> did spake
thusly:
or =[FileName]SheetName!Cell if it's in the same folder; just makes folder
integrity a little easier if you're having to pass it on to someone else.
Phil Cook
