POV-Ray : Newsgroups : povray.off-topic : Kindling Server Time
6 Jul 2026 13:39:32 EDT (-0400)
  Kindling (Message 81 to 90 of 520)
Subject: Re: Kindling
Date: 17 Jan 2011 04:29:17
Message: <4d340bed$1@news.povray.org>
On 14/01/2011 05:25 PM, Darren New wrote:
> scott wrote:
>> The audio DAC is probably one of the simplest parts in the phone for
>> the designers to do.
> You probably have separate DACs for the MP3 player and the rest of the
> phone anyway.
You reckon? I would have thought space and power consumption
considerations would preclude that.
Date: 17 Jan 2011 06:30:41
Message: <4d342861$1@news.povray.org>
>> phone anyway.
Well for power consumption the DAC for the the phone conversations can
be much lower quality.  It wouldn't surprise me if there was a clever
DAC that could be switched between low-quality-low-power and
high-quality-high-power mode.  There is all sorts of stuff like that in
phones.
Date: 17 Jan 2011 06:35:09
Message: <4d34296d@news.povray.org>
> I bought the
> content, and I'm not breaking the DRM to profit from it - but to preserve
> my access to the content in the event that I cannot get it back again.
Presumably they factored in to the original price that a certain % of
customers will re-buy the same material due to losing access, changing
hardware or whatever.  They also probably put something in the license
describing that too.  If everyone removed the DRM they would probably
need to sell it for a higher price.
Date: 17 Jan 2011 07:52:13
Message: <4d343b7d$1@news.povray.org>
>>> phone anyway.
> be much lower quality. It wouldn't surprise me if there was a clever DAC
> phones.
I wouldn't have thought there's any relationship at all between quality
and power consumption. Not for a DAC, anyway. Either way it's a pretty
low-power device. Presumably the transmitter and backlight use vastly
more power...
Date: 17 Jan 2011 08:30:47
Message: <4d344487$1@news.povray.org>
In general more power means you have more possibilities to do stuff to
increase the quality.  If you've designed what you think is a great DAC,
and someone tells you to reduce the power by 25%, chances are the
quality will suffer as a result.  All sorts of things used to increase
quality (eg digital filters, analogue filters, voltage regulators) draw
power, and usually can be removed/replaced to reduce the power.
> low-power device.
Only if it's designed that way, according to Wikipedia a typical DAC for
PC soundcards is the CS4382, which draws almost half a Watt during
normal operation - not really suitable for a portable device!  Believe
me, the phone makers will be pushing very hard to get the power for all
components as low as possible, every little helps!
> more power...
Backlights usually use around 100 - 200 mW depending on the screen size,
but I don't think they usually stay on (at least not at full power)
whilst music is playing, do they?  The transmitter should be on almost
zero power whilst playing music, and judging by the talk times and
battery capacities, looks around half a Watt whilst in a call.
Date: 17 Jan 2011 08:36:57
Message: <4d3445f9$1@news.povray.org>
I still rather suspect that rather than put in a high-quality DAC and a
low-quality DAC, they'll just not bother with the high-quality one at all.
>> Either way it's a pretty low-power device.
OK. But also not *designed* for a portable device either. I'm sure
somebody has come up with much more frugal designs.
>> Presumably the transmitter and backlight use vastly more power...
I would hope not.
> The transmitter should be on almost zero power whilst playing music
I don't know that much about GSM, but doesn't it have to periodically
broadcast to keep in touch with the network?
Mmm, maybe.
Date: 17 Jan 2011 10:03:07
Message: <4d345a2b$1@news.povray.org>
And then your MP3s sound like phone conversations .... ummm I doubt it.
  IIRC phone conversations are up to 3.4 kHz or something, whilst MP3s
are usually up to 20 kHz or so.  As a very simple solution you could
just run the same DAC at a slower clock rate for the voice calls to save
power, but I bet there are far more sophisticated solutions actually
used in the handsets.
Hence "almost" zero, and not actually zero.
Date: 17 Jan 2011 10:06:00
Message: <4d345ad8$1@news.povray.org>
>> all.
> IIRC phone conversations are up to 3.4 kHz or something, whilst MP3s are
> usually up to 20 kHz or so. As a very simple solution you could just run
> the same DAC at a slower clock rate for the voice calls to save power,
> but I bet there are far more sophisticated solutions actually used in
> the handsets.
Is power consumption directly related to clock speed in some way?
Oh, OK.
Date: 17 Jan 2011 10:33:26
Message: <4d346146$1@news.povray.org>
Pretty much always.  On the digital side of things transistors use most
power whilst switching (as opposed to being in steady state on or off),
so the more switching they do per second the higher the average power
consumption.  On the analogue side the details probably vary depending
on exactly which DAC architecture you're using, but in general I can't
imagine power going down at higher clock speeds.  Higher clock speeds
mean faster rate of change of voltage, which usually means higher
currents are involved, so more power gets dissipated in various components.
Date: 17 Jan 2011 11:11:04
Message: <4d346a18$1@news.povray.org>
> Pretty much always.
Mmm, OK.
> On the analogue side the details probably vary depending on
No, but it could stay roughly the same.
I suppose the next question is how much power changes with frequency,
but I guess that's going to depend intimately on exactly what you're
doing...
I still rather suspect that the difference between a 30,000 sps DAC and
a 20,000 sps DAC is rather minute, but whatever.
