POV-Ray : Newsgroups : povray.off-topic : Wolfram's rule 110 bit Server Time
22 Jul 2026 21:34:11 EDT (-0400)
  Wolfram's rule 110 bit (Message 11 to 14 of 14)
Subject: Re: Wolfram's rule 110 bit
Date: 4 Jan 2011 21:39:16
Message: <4d23d9d4@news.povray.org>
Am 04.01.2011 23:48, schrieb Darren New:
> clipka wrote:
>> And that's no problem, because CA are allowed to have that /by
>> definition/.
> That right there is what I'm asking about. I've never seen a definition
> that allows for a CA to have an infinite initialization other than to a
> default state. Do you have a citation to a definition that describes
> this? I am having trouble coming up with a trivial way to define what
> would be the allowable initialization and what would be the disallowed
> initialization without making reference to something outside the realm
> of CAs. Perhaps if you can describe its state based on a RE function of
> its index or something?
"An initial state (time t=0) is selected by assigning a state for each
cell."
(Wikipedia)
Isn't that plain enough? You assign a state for /each/ cell. CA's don't
seem to make any limitations on this.
Just like you "create" a TM [tape] to be initially empty except for a
limited section, you "create" a CA with an explicit initial state for
/each/ cell. How you pick that state per cell is purely a CA design
decision, and it doesn't matter whether you fetch that state out of thin
air already providing (part of) your solution. Just name /any/ rule for
that pattern - I guess the only limitation is that if you define the
initial state at time t=0 as a function of any states at time t>0 you
have a CA with oracle - and in fact may find yourself running straight
into a paradoxon.
Date: 5 Jan 2011 04:24:08
Message: <4d2438b8$1@news.povray.org>
On 22/12/2010 11:07 PM, Darren New wrote:
> Initializing an infinite tape for a
> turing machine at least makes it more powerful than one with an
> uninitialized tape.
OK.
> And rule 110 needs an infinitely initialized tape.
I'm still not convinced that this is actually necessary.
In other words, I suspect that rule 110 *is* Turing complete, it's just
that the proof provided is a bit weak.
Date: 5 Jan 2011 12:05:42
Message: <4d24a4e6$1@news.povray.org>
> cell."
> (Wikipedia)
Well, from that same page:
It is usually assumed that every cell in the universe starts in the same
state, except for a finite number of cells in other states, often called a
configuration. More generally, it is sometimes assumed that the universe
starts out covered with a periodic pattern, and only a finite number of
cells violate that pattern. The latter assumption is common in
one-dimensional cellular automata.
So you "generally" don't start with an infinite aperiodic pattern.
What I was really interested in was a proof that starting with a periodic
pattern (except a finite number of cells) didn't give more computing power
to the CA than starting with a single state (except a finite number of
cells). Because Wolfram is arguing about the computational power of Rule 110.
> Just name /any/ rule for that pattern
I don't think that works, because then it lets the CA calculate stuff a TM
cannot, and I think that would lead to a trivial disproof of the
Church-Turing thesis.
Now, a pattern that differs from a regular repeating pattern in only a
finite number of places? Sure, that's likely good.
But if Wikipedia says a repeating pattern for linear CAs is common, I'll
assume that's sufficient to quell my disquiet with the Rule 110 proof in
that regard. I'd still like to see a proof that having the repeating pattern
doesn't add computational power, which is what the Crawley paper was
apparently discussing. I'll have to take time to look at that closer.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 5 Jan 2011 12:13:42
Message: <4d24a6c6$1@news.povray.org>
I suspect you can build a linear CA that's turing complete. I'm not
convinced that 110 without the infinite initialization can do that.
   Serving Suggestion:
