POV-Ray : Newsgroups : povray.off-topic : I am convinced... Server Time
14 May 2026 16:11:30 EDT (-0400)
  I am convinced... (Message 4 to 13 of 43)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: I am convinced...
Date: 20 Dec 2010 16:11:42
Message: <4d0fc68e$1@news.povray.org>
Warp wrote:
>   On the subject of virus scanners in particular, I'd say that the very
> need to have such scanners is a symptom of fundamentally bad OS design.
While I agree it would be nice not to need such things, I don't think many
of the common OSes don't need it. Something like Singularity, where you
can't run code that does something "unsafe", where you have to reboot after
installing a new executable, and where every executable declares in the
manifest what system resources it'll need? Sure, much less virus-prone.
> The reason for this is that unixes have always been designed to be
> multi-user operating systems while DOS/Windows has been designed to be
> a single-user OS with no regard to security.
And yet, I got a virus from a web page while running in a non-privileged
account under Vista. (The first ever malware I ever myself contracted, in
any system since 8-bit computers, I'll mention.) Nowadays, malware attacks
individual accounts. You hit a web site, some bug in Firefox lets some piece
of Javascript write some garbage to some hidden directory, and you have
malware. Bazinga.
It's not like UNIX or IBM big iron never had a worm or virus. They just
weren't trying to hide at the time.  I daresay if something like the Morris
worm got a toe-hold nowadays, it would be some time before someone noticed it.
> You should
> not be able to access other users' data without permission, and especially
> you shouldn't be able to access the superusers' data without permission.
> This causes security to be built into the system from the ground up.
But this has been the case with NT forever, and since XP, people haven't
been running superuser. The problem is that people bitch about the security,
complain they can't set the clock without typing a password, etc.
>   The DOS/Windows design always took basically the exact opposite approach:
> Whatever the user wants to run or do, the OS allows.
That's kind of what happens when you don't have virtual memory mapping.
> This made the spreading of viruses and malware *trivial*.
It's still pretty trivial, methinks. You don't need to be superuser to
spread the kind of malware that spreads these days. People aren't looking to
take down your machine. They're looking to install a firefox extension that
records your bank logins and posts them to a hacker's web site. No admin
privileges needed for that at all.
> rather than relying on the users;
Nah. It's in three parts: (1) unix was and still is used primarily by people
who understand how computers work at least a little; (2) when people broke
into unix systems, they got 50,000 accounts, so they didn't really need to
propagate as much; and (3) the actual problem with trojans (which is where
most malware comes from these days) was solved before networking was ubiquitous.
For example, that was the whole "NT3.5 has C2 security" stuff came from:
there was an actual keystroke (C-A-D) that would uninterruptably ensure
you're talking to a specific program, e.g. the login prompt. UNIX had no
such feature - anything the login program could do, so could a user-level
program, except for the actual logging in part.  It's why "." isn't in the
path by default on UNIX (any more).  There are, basically, 101 fixes in UNIX
for security that was broken in spite of being multi-user. It's just that
UNIX is old enough and had multi-user *early* enough that *those* kind of
fixes got put in place before networking was common. Otherwise, I suspect
you'd see way more worms and such in UNIX, for the same reason that even now
XP and Vista and etc have more malware for them than UNIX does.
> in the single-user OS's it requires a very significantly more radical
> change in design than just fixing a few bugs).
Sure, but Windows hasn't been single-user for 10+ years.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 20 Dec 2010 16:17:13
Message: <4d0fc7d9$1@news.povray.org>
Warp wrote:
> The OS should be designed in such way that it's just not possible.
The problem is people, really. You put in code that says "don't accept
executables." Then you put in code that says "Hey, you downloaded this, do
you really want to run it?" Then you put in code that says "Don't accept
executables inside zip files."
If it went far enough, people would send out "here's a zip file with the
password xyz. Unpack it with that password, rename hello.jpg to hello.exe,
and run it to get an important message from your bank" and someone would do it.
>   Virus scanners are fighting the symptoms, not the fundamental problem.
True. And the symptom is that software is too complex for someone to know
all its interactions in modern systems, in part because software doesn't
come as a package. This is starting to change, but it's still not enforced.
It's more of a convenience feature than a security feature.
If you said "Firefox can only run executable code that you downloaded with
firefox and was signed by the firefox development key", you'd be golden.
Unless, of course, it's an interpreter.
I think fundamentally you're up against the halting problem, and the more
you lock down the system, the more people who *do* know what they're doing
(or who want to do something regardless of whether they know what they're
doing or not) will be annoyed.
   Serving Suggestion:
Date: 20 Dec 2010 16:43:36
Message: <4d0fce08@news.povray.org>
  Didn't seem to be such a problem in the unix world. And even if that
kind of social engineering caused someone to execute a program they
received by email, it would still be limited to that user's account.
The system itself and other users would be safe. It's a whole different
mentality. It's hard to spread viruses like that.
Date: 20 Dec 2010 16:52:57
Message: <4d0fd039@news.povray.org>
> > You should
  They wouldn't if Microsoft hadn't taught them the bad habits.
  If the very first version of DOS had had a similar account/password
system as unixes, and this strict mentality had been dragged along (and
improved) in all subsequent versions of DOS and Windows, people today
would not complain because they would take it for granted, as something
obvious.
  The mentality prevailed well after the 80386 became the de-facto standard.
(And, in fact, even the 80286 supported some type of memory protection.)
  Well, how long it took for Microsoft to *finally* get some semblance
of security into their desktop OS? (And the major reason why it took them
so long is not because of technical difficulties, but simply because they
just didn't bother.)
Date: 20 Dec 2010 17:52:30
Message: <4d0fde2e$1@news.povray.org>
No, because most people running UNIX software knew the basics of how
computers work. They'd recognise this as a scam, rather than just another
series of opaque rules you have to follow to get something done on this damn
machine.
 > And even if that
Except that's why they took "." out of the path, and why setuid files aren't
allowed to be writable and why writing to them turns off setuid, neither of
which were security features even as late as V7. Exactly because enough
people fell for it that they made it inconvenient for developers to keep
those not paying attention from running a trojan.
Except if there's only one user on the system, like there often is with
Windows desktop machines, you're still screwed if your web browser starts
sending your bank passwords to russian mafia guys.
It only takes one hole. How widely do you think the Morris worm could have
spread if he was being paid a million dollars to make it hibernate on the
computer?  He'd write an executable somewhere, call it something benign,
start it up as root, then let it sit and listen for a particular string to
show up in a spam mail to DDOS some network computer.
I think what you're seeing is more that by the time it was *profitable* to
write a virus, Windows was already the best vector both in popularity and
user-naivety. Granted, it was pretty common back in the early days of
Windows to have a virus or whatever spread, but it was also much more common
to hear of break-ins of commercial servers to be stealing credit cards and such.
   Serving Suggestion:
Date: 20 Dec 2010 18:00:04
Message: <4d0fdff4$1@news.povray.org>
Probably true. But that is left over from when Windows ran on machines that
weren't even capable of running UNIX and for which having a multi-user OS
made no sense.
> system as unixes,
... then it wouldn't have run on an 8086, and MS would be broke.
> obvious.
It's hard to say. Most of the other systems of the day didn't have it either.
Backwards compatibility is a bitch, indeed.
Backwards compatibility is a bitch.
Sure. Welcome to the commercial market.
But this is kind of off the topic now, methinks. Or at least drifting into
another discussion.
UNIX isn't safe because it has had multi-user stuff longer. (Safer. Far from
"safe".) One slip by the superuser can screw things up. Anyone with the root
password can do anything they want and steal any data they want from anyone
else on the machine. Tricking the superuser into running your code, or
mounting a disk you have without turning off setuid on it, or a server with
a buffer overflow, or anything like that can corrupt the system in ways just
as hard to figure out.
Contrast with something like Singularity, where you explicitly list every
program you're going to run, every file they're going to access, there's no
way to run code that isn't signed, no way to get someone to overrun a buffer
to run code that wasn't in the executable to start with, and giving each
program its own set of permissions orthogonally to the users running the
program. *That* is a significant advance in security of an operating system.
   Serving Suggestion:
Date: 20 Dec 2010 18:16:33
Message: <4d0fe3d1$1@news.povray.org>
Thinking on it, there are a whole bunch of "patches" made in the UNIX world
to account for bad security. The whole thing with "xhost" and the magic
cookies. Taking "." out of the default path. Sticky bits on directories.
Shadow password files. The vipw command. The -print0 option on find.
Poisoned DNS caches (which affected everyone, really). All *kinds* of stuff
in UUCP. All kinds of race conditions for files in /tmp/. Why people
switched from rcp to scp. Why people switched from http to https. Why FTP
runs in a chroot cell, and still failed that on occasion if one
misconfigured it. Why it used to be easy to find thousands of /etc/passwd
files on the web when search engines first came out. Why Kerberos used to
let you download the whole list of encrypted passwords for off-line cracking
before you identified yourself.
It's just that most of the breaks these changes fixed happened before
networking was really ubiquitous, and before taking advantage of them was
worth huge amounts of money.
Yes, MS was somewhat late to the party, but it's not like UNIX escaped being
broken into over, and over, and over again, simply because it has always
been multi-user. It's only relatively recently that people in general
started worrying about these things on a systematic basis, because it has
only been relatively recently that it was more valuable to break into it
than getting your college class grades changed. ;-)
Oh, and by the way:
http://en.wikipedia.org/wiki/Christmas_Tree_EXEC
So, yeah. Would never happen on a *real* system.
   Serving Suggestion:
Date: 20 Dec 2010 20:14:57
Message: <4d0fff91$1@news.povray.org>
> not enforced. It's more of a convenience feature than a security feature.
http://developer.android.com/guide/topics/security/security.html#declaring
You need something like that to make it work for normal people.
   Serving Suggestion:
Date: 20 Dec 2010 21:53:09
Message: <4d101695$1@news.povray.org>
On 12/20/2010 11:41 AM, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> Traditional file system interfaces probably do too. For example, if you
>> wanted something like a virus scanner that was watching your executables, I
>> suspect that "scan the file when it gets passed to exec()" is probably a
>> much more common implementation than "scan each block between the time it is
>> paged in and the time the code branches to it", for example.  (Indeed, I
>> don't know how you'd even do that latter on Linux or Windows or whatever.)
> Of course this isn't an original idea of mine, as such an idea has been
> expressed numerous times by people more knowledgeable than me (and probably
> even linked to in this very newsgroup in the past).
>    The unix philosophy of OS design has always been a step or two closer
> to the safer design (with respect to computer viruses and other malware)
> then the typical DOS/Windows (and other similar OS's in the past) design.
> a single-user OS with no regard to security. The very need to handle
> multiple user automatically brings forth the need for security: You should
> Whatever the user wants to run or do, the OS allows. It's not the system's
> task to stop the user doing what he wants. Unfortunately it took over 20
> years for Microsoft to rid itself of this mentality (for some reason MS
> has always been very slow to adopt certain ideas). NT had security, but
> it wasn't even intended for normal users. It wasn't until XP that some
> *semblance* of security was introduced (yet, nevertheless, the mentality
> of the regular user being by default the superuser was still there, and
> probably 99% of XP users out there still use their machine with superuser
> privileges). This made the spreading of viruses and malware *trivial*.
>    Not that the unix design is perfect, but at least viruses, worms and
> other malware have always been, and still are, extremely rare in unix
> systems in comparison (basically the only relatively successful worms
> in the unix world have exploited bugs in the systems to spread themselves,
> rather than relying on the users; fix the bug, and the worm stops; however,
Seems to me, the best design would be an additional layer. An
application runs "sandboxed", until a scanner can verify its not
dangerous, and only then does it get "current user" rights, never mind
admin. That way, it can only clobber itself, or the data it creates
itself, or copies of the data you opened with it. Nothing changes in the
"original", of say, a JPG, until you, or your scanner, are sure that the
program is what it says, and even any changes you make only appear in
*its* copy, until verification happens, and the original is updated with
the changes.
Or, something like that. Not unlike the idea I had with using EyeOS as a
host for fake terminals, where you could hack them, but you would be
hacking into the copy of the system, so the normal user of it could log
in, see the hack and then, on their option, restore the whole thing in a
single action, back to the unchanged state. Any changes/additions they
made would still go to *their* copy, unless the changes where to a
hacked file, in which case you could have the option to keep the changes
you made, or throw them out (i.e., restore from a backup).
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 20 Dec 2010 22:51:02
Message: <4d102426@news.povray.org>
> admin.
Begs the question. How do you know it's dangerous?  And what happens if you
run two sandboxed applications that change the same file? How often do you
check? Every time you run it, or just when the code changes? If only when
the code changes, just scan it before you start it the first time, but risk
having malware modify the checksum you're using to check for valid programs.
   Serving Suggestion:
