POV-Ray : Newsgroups : povray.off-topic : Boat/river puzzle Server Time
11 Sep 2025 17:24:09 EDT (-0400)
  Boat/river puzzle (Message 1 to 9 of 9)
Subject: Boat/river puzzle
Date: 30 Nov 2010 11:31:53
Message: <4cf526f9$1@news.povray.org>
Maybe some of you remember the problem from basic vector math class, where a
boat must travel across a flowing river to a certain point, and you need to
calculate which direction the boat should point.
The captain of a certain boat is not so clever though, and just aims his
boat straight at the destination, of course the boat starts to get pushed
off course by the river current, but the captain keeps the boat pointed at
the destination at all times.  Eventually (assuming the boat can overcome
the river current) the boat reaches the destination.  What shape curve did
the boat trace out?
Subject: Re: Boat/river puzzle
Date: 30 Nov 2010 15:43:58
Message: <4cf5620e@news.povray.org>
Le 30/11/2010 17:31, scott nous fit lire :
> where a boat must travel across a flowing river to a certain point, and
> you need to calculate which direction the boat should point.
> pushed off course by the river current, but the captain keeps the boat
> pointed at the destination at all times.  Eventually (assuming the boat
> can overcome the river current) the boat reaches the destination.  What
> shape curve did the boat trace out?
It would be some sheared tractrix (dog-curve), I presume.
(the shearing is due to the change of referential, as instead of the
target moving very slowly perpendicular to the boat direction, it's in
fact the boat which get drift away perpendicularly by the river)
Instead of a river, put the destination on a road, the boat on a lake,
and you get a tractrix.
Date: 2 Dec 2010 04:11:09
Message: <4cf762ad$1@news.povray.org>
That's a surprisingly cute little puzzle, at least in the case where the
speed of the current matches the speed of the boat and you can prove
without any calculation that it follows a parabolic arc.  In general I
think the curve is of the rather less elegant form x*sinh(v*log(x)+c)
where x>=0, although it's possible I made a mistake somewhere.  Did you
come up with this on your own or did you hear it elsewhere?
Date: 2 Dec 2010 11:47:46
Message: <4cf7cdb2$1@news.povray.org>
I think that means you never get to where you're going. Once the current
carries you downstream, if you can't outrun the current, you're not going to
get upstream again.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 2 Dec 2010 12:11:43
Message: <4cf7d34f$1@news.povray.org>
> going to get upstream again.
Precisely, but you can still calculate the curve that the boat follows,
and unless I'm mistaken it's a parabola (in this case restricted to x>0
rather than x>=0).  It's not strictly within the parameters of the
problem, but I mentioned it because I couldn't see how to derive the
full answer without some calculus, but I could get an answer for that
special case with just geometry.
Date: 3 Dec 2010 03:56:18
Message: <4cf8b0b2@news.povray.org>
I started to try and figure it out using calculus but it all got too
complicated when I tried to write the velocity in terms of the current
position.  I kind of guessed intuitively it would be an interesting shape, I
thought like half a water drop or something.
> Did you come up with this on your own or did you hear it elsewhere?
I came up with it on my own somehow, I don't recall how I got round to
thinking about it!
Date: 3 Dec 2010 18:32:18
Message: <4cf97e02$1@news.povray.org>
> position.
In that case I'll give some more info.  I was refraining from saying too
much since I try to let the people who pose puzzles be the ones to talk
about the answer.
[SPOILERS BELOW]
I started by normalizing everything by assuming that the target is at
the origin, that the boat's speed is 1 and that the speed of the river
is v in the y direction.  If you try to solve things the way you were
going, you get the equation of motion:
-1/sqrt(x^2+y^2)*(x*dx/dt + y*(dy/dt - v)) = 1
subject to (dx/dt)^2 + (dy/dt - v)^2 = 1
After a bit of algebra you can simplify this to (I think, I didn't check
my work):
v*x + y*dx/dt - x*dy/dt = 0
It's been a while since I've done any differential equations, so I
didn't go this route.  Instead I eliminated the `t' variable and rewrote
everything in terms of just the position of the boat (i.e. x and y).  In
this view you get the differential equation:
dy/dx = y/x - v*sqrt(1+(y/x)^2)
Where the y/x term is the motion due to the motor of the boat and the
-v*sqrt(1+(y/x)^2) term is due to the river's current.  As I said, it's
been a while since I've done any differential equations, so I just
plugged it into wolfram alpha and got the equation:
y = x*sinh(-v*log(x) + c)
Here v is the velocity of the current and c is a free parameter which
you can use to adjust the initial position of the boat.  It also handles
cases where |v|>= 1 and the boat can't ever reach the target perfectly well.
If you want to avoid using any calculus, it's easy to show that the boat
moves in a parabola with the target at its focus when v=-1.  You can
show this by using two (related) facts about parabolas:
1) A parabola is the set of points equidistant from a point at its focus
and a horizontal line at its directrix.
2) A parabola reflects all vertical rays through its focus.
These two properties are best illustrated in this diagram:
http://upload.wikimedia.org/wikipedia/commons/9/97/Parabola_focus_directrix.svg
Here the (x,y) is the boat's position, the vector to the focus is
parallel to the velocity due to the boat's motor, and the vector down to
the directrix is parallel the velocity due to the current, and
importantly is of equal length to the first vector, corresponding to the
river's speed matching the boat's.  So you can see (and it's easy to
prove) that if you sum these vectors you get a line parallel to the
tangent of the parabola at the boat's position.  Thus the boat will move
in a parabola with the target at its focus.  You can verify that if you
plug v=-1 (or v=1) into x*sinh(-v*log(x)+c) you get a parabola with its
focus at the origin.
I actually solved things this way (with a parabola and geometry) first,
then used it as a model to write the differential equation which gives
answers for when |v| != 1.
> shape, I thought like half a water drop or something.
It does looks sort of neat if you plot it for different values of v:
http://fooplot.com/index.php?&type0=0&type1=0&type2=0&type3=0&type4=0&y0=x*sinh%280.5*ln%28x%29%29&y1=x*sinh%280.8*ln%28x%29%29&y2=x*sinh%281.0*ln%28x%29%29&y3=x*sinh%281.1*ln%28x%29%29&y4=x*sinh%281.2*ln%28x%29%29&r0=&r1=&r2=&r3=&r4=&px0=&px1=&px2=&px3=&px4=&py0=&py1=&py2=&py3=&py4=&smin0=0&smin1=0&smin2=0&smin3=0&smin4=0&smax0=2pi&smax1=2pi&smax2=2pi&smax3=2pi&smax4=2pi&thetamin0=0&thetamin1=0&thetamin2=0&thetamin3=0&thetamin4=0&thetamax0=2pi&thetamax1=2pi&thetamax2=2pi&thetamax3=2pi&thetamax4=2pi&ipw=0&ixmin=-5&ixmax=5&iymin=-3&iymax=3&igx=0.1&igy=0.1&igl=0&igs=0&iax=1&ila=1&xmin=-0.47609860408646915&xmax=1.2753839171157066&ymin=-0.9772358187959684&ymax=0.056507871184616004
Date: 7 Dec 2010 10:12:55
Message: <4cfe4ef7@news.povray.org>
> It's been a while since I've done any differential equations, so I didn't
That would have been the step I couldn't figure out - it's been a while
since I did this type of thing regularly!
Date: 7 Dec 2010 11:43:47
Message: <4cfe6443$1@news.povray.org>
Understandable.  Still, it was a fun puzzle -- I'll remember it!
