POV-Ray : Newsgroups : povray.off-topic : Mini-languages Server Time
1 Jul 2026 11:35:31 EDT (-0400)
  Mini-languages (Message 51 to 60 of 108)
Subject: Re: Mini-languages
Date: 11 Nov 2010 11:04:47
Message: <4cdc141f$1@news.povray.org>
Invisible escreveu:
>>> Um, *yes*. Why, do you think it doesn't have worth?
>> it's far more verbose and, thus, hurts readability?
> Far more verbose, and as a consequence it's almost self-explanatory what
> it does. (Unlike a collection of symbols that have no widely-accepted
> meaning outside of regex languages...)
symbols like $ or >>=?
yeah, every language has them and you *learn* to live with them.  or you
just endlessly refuse to learn and whine all day long about them...
you are correct though in that the Lisp way of spelling out names is
more self-explanatory than the Haskell abuse of perlisms.  At least for
outsiders.  For insiders, you know by personal experience that a concise
DSL made out of single chars is much more practical... which is why you
can do it in Lisp with macros too!
>> then try this in your little language:
>> // A phone number with or without hyphens:
>> [2-9]\d{2}-?\d{3}-?\d{4}
>> It looks pretty much like a template for a phone number. I'm sure yours
>> will look like a little backwards forth script and will be much harder
>> to figure out.
> I actually can't figure out what that does, so I can't implement it.
BS.
>> I also wonder if it's the postfix nature of regexes that bothers you...
> No, mostly it comes down to these:
> 1. Commands have cryptic names like "*" or "+".
more than frakkin' $ or >>= ??!
you quite throw away reason completely when you try to invent reasons
for why you dislike something, don't you?
> 2. Literal characters aren't quoted, so it's hard to tell what's literal
> and what's a command.
there's only .*+?^$\ for commands and the rest are grouping chars ()[]{}
and literal chars.  what's to be confused?
> (And 3. since spaces are literal characters, you can't even use spacing
> to make the structure of the expression clearer.)
you can in perl regex extensions.
a game sig: http://tinyurl.com/d3rxz9
Date: 11 Nov 2010 11:16:28
Message: <4cdc16dc$1@news.povray.org>
On 11/11/2010 03:52 PM, Warp wrote:
> Invisible<voi### [at] devnull>  wrote:
>> Actually, I found a rather interesting description of the history of
>> Unix the other day. I'll have to see if I can find it again. As you read
>> it, you discover that many design decisions that look stupid are in fact
>> merely obsolete. They served a purpose 60 years ago, it's just that they
>> aren't the best choice any more.
>    That would be quite strange, given that Unix was originally developed
> 41 years ago.
How do you know all these things?
>> These days, the fashion seems to be for everything from print servers to
>> network hubs to be controlled by HTML over HTTP. Which is equally
>> stupid, but looks more pretty...
>    Well, it has the advantage that it's still relatively low-bandwidth and
> usable with any web browser in any system, and you can do things with the
> mouse.
>    Of course the downside is that you need something that can run a web
> browser.
You need something that supports HTTP, HTML, JavaScript, the DOM, and
[typically] supports these things with all the same glitches and bugs as
Internet Explorer 4.5 >_<
What's that? You wanted to reconfigure all your print servers from a
script? Good luck with that...
Date: 11 Nov 2010 11:22:27
Message: <4cdc1843$1@news.povray.org>
Invisible escreveu:
>> 41 years ago.
he is omniscient.  You are just a puny ignorant human.
Date: 11 Nov 2010 12:07:57
Message: <4cdc22ed@news.povray.org>
  You might as well argue that math is cryptic because it uses notation
like "1+2=3".
Date: 11 Nov 2010 12:09:21
Message: <4cdc2341@news.povray.org>
> > 41 years ago.
  There are two friends of everybody. The name of the first one starts
with a G and the name of the second one starts with a W.
Date: 11 Nov 2010 15:21:00
Message: <4cdc502c$1@news.povray.org>
Invisible wrote:
>>>> (That is, optional sign, one or more digits, optional decimal point
>>>> followed by one or more digits, optional E followed by optional sign
>>>> followed by one to three digits.)
>>> If I've understood the spec correctly, it's
>>> do
>>> option (char '+' <|> char '-')
>>> many1 digit
>>> option (char '.')
>>> many1 digit
>>> option (do char 'E'; option (char '+' <|> char '-'); many1 digit)
>> Bzzzt. Sorry. That requires at least a 2-digit number.
> I don't follow. Where do you think by definition deviates from your spec?
Your parser won't parse "+3" as a valid number.
> I've never seen a system that can do that, but I guess that doesn't
> prove a lot.
Basically, if you wanted the sign, you could do something like
string sign = "(+|-)?";
and then construct your regexp out of parts. Basically, just like you did.
It's not because "your parser is in a real language". It's because you're
using whatever language the parser is in to construct the match expression
and I didn't.
>>> You can also factor the task into smaller pieces:
>> Yeah, that's just a text substitution in the regexp expression.
> Sure. Except without any guarantee of syntactic correctness.
Again, until the first time you run it. So?
Clearly you have no guarantee of semantic correctness, so this really isn't
a problem, given that with your syntactic correctness you still got the
expression wrong. :-)
>>> With a regex, on the other hand, you cannot even statically guarantee
>>> that a given string is even a syntactically valid regex.
>> Nonsense. How'd you get that?
> Not every string is a valid regex. You have to follow the syntax rules.
> But this is not checked at compile-time (and usually /cannot/ be checked
> at compile-time). So if you make a typo in your regex, you won't find
> out until runtime.
It can be checked at compile time if your language cares to. That's not an
aspect of the regexp, but an aspect of you using Haskell.
And if you wrote the code and never ran it, then guess what, you have worse
problems than syntax errors in your regexps.
> If you start constructing regexs programmatically, your problems just
> multiplied.
> On the other hand, with a /real/ parser library, both of these grave
> problems immediately vanish into thin air.
How do you construct your parser programatically in Haskell? That looks like
code to me.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 11 Nov 2010 15:23:33
Message: <4cdc50c5$1@news.povray.org>
Warp wrote:
> nemesis <nam### [at] gmailcom> wrote:
>> do you really believe spelling out "option (char '+' <|> char '-')" is
>> any worth as opposed to "(\+|-)"?
>   Btw, "(\+|-)" is unnecessarily complex. Just use "[+-]". That's exactly
> what the [] syntax is for.
Good point. That was my bad.
   Serving Suggestion:
Date: 11 Nov 2010 15:25:43
Message: <4cdc5147$1@news.povray.org>
Invisible wrote:
> If there are more than three digits, the above parser fails, and no
> other alternatives are tried (i.e., no backtracking).
Then you aren't doing what regular expressions can do.
In order to *get* the power of regexp, *your* parser has to backtrack. So if
you turn backtracking off, there are trivial regular expressions you can't
match. If you turn backtracking on, you're using more time and space than a
regular expression engine.
   Serving Suggestion:
Date: 11 Nov 2010 15:28:37
Message: <4cdc51f5$1@news.povray.org>
Invisible wrote:
> The reason I put up with TeX, in spite of its innumerable and obvious
> limitations, is that it produces very, very nice output. troff doesn't
> seem to compare to that.
I'm guessing you've never run troff, but only nroff. I'm also guessing that
if you *have* run troff, you've only run it using the man page macros.
   Serving Suggestion:
Date: 12 Nov 2010 04:13:59
Message: <4cdd0557$1@news.povray.org>
I don't see how that is the case.
> So if you turn backtracking off, there are trivial regular expressions
> you can't match. If you turn backtracking on, you're using more time and
> space than a regular expression engine.
Do you have a concrete example?
