POV-Ray : Newsgroups : povray.off-topic : Mini-languages Server Time
1 Jul 2026 08:00:09 EDT (-0400)
  Mini-languages (Message 31 to 40 of 108)
Subject: Re: Mini-languages
Date: 10 Nov 2010 14:28:32
Message: <4cdaf260$1@news.povray.org>
Invisible wrote:
>> OK, so how do you do
>> (\+|-)[0-9]+(\.[0-9]+)?(E(\+|-)?[0-9]{1,3})?
>> in your parser language?
> OK, that's one big ol' complex regex, right there.
That's a pretty simple regex, actually.
>> (That is, optional sign, one or more digits, optional decimal point
>> followed by one or more digits, optional E followed by optional sign
>> followed by one to three digits.)
> If I've understood the spec correctly, it's
>   do
>     option (char '+' <|> char '-')
>     many1 digit
>     option (char '.')
>     many1 digit
>     option (do char 'E'; option (char '+' <|> char '-'); many1 digit)
Bzzzt. Sorry. That requires at least a 2-digit number.
> Enforcing that the exponent is less than or equal to 3 digits would be
> slightly more wordy. The obvious way is
>   xs <- many1 digit
>   if length xs > 3 then fail else return ()
> Notice that since this is written in a /real/ programming language and
> not a text string, we can do
>   sign = char '+' <|> char '-'
>   number = do
>     option sign
>     many1 digit
>     option (char '.')
>     many1 digit
>     option (do char 'E'; option sign; many1 digit)
> and save a little typing.
You can do that with many regexp engines too. That's what I meant by
"trivial macros".
> You can also factor the task into smaller pieces:
Yeah, that's just a text substitution in the regexp expression.
> With a regex, on the other hand, you cannot even statically guarantee
> that a given string is even a syntactically valid regex.
Nonsense. How'd you get that?
If you mean you can't use a regexp to parse a regexp, well, yeah, so?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 10 Nov 2010 15:53:32
Message: <4cdb064c$1@news.povray.org>
Invisible escreveu:
>>    Nice straw man.
> Wasn't his problem that he didn't have a brain?
>> (And "foo*bar" still doesn't mean what you think it means
>> as a regex.)
> So, what, it means
>   string "fo"
>   many (char 'o')
>   string "bar"
> Or am I reading this wrong?
* means 0 or more of the previous pattern, in this case, letter 'o'.
+ means 1 or more.
"fobar" is accepted.  The correct pattern should be foo+bar or foo.*bar.
a game sig: http://tinyurl.com/d3rxz9
Date: 10 Nov 2010 16:04:03
Message: <4cdb08c3@news.povray.org>
Invisible escreveu:
I see you never looked at perl code.
>   do
>     many1 digit
>     option (char '.')
>     many1 digit
so, besides the errors, are you satisfied to go the Lisp route and spell
out all functions rather than rely on specialized, more convenient
predefined syntax?
do you really believe spelling out "option (char '+' <|> char '-')" is
any worth as opposed to "(\+|-)"?
>   xs <- many1 digit
no, sorry.  Truly overkill against "\d{3}".
Date: 10 Nov 2010 16:39:07
Message: <4cdb10fb$1@news.povray.org>
Invisible wrote:
>   xs <- many1 digit
By the way, this also means you have backtracking, which means you have
exponential time and space requirements for your match rather than provably
linear time and constant space.
   Serving Suggestion:
Date: 10 Nov 2010 16:49:58
Message: <4cdb1386@news.povray.org>
Orchid XP v8 escreveu:
> killer application for Unix", you don't expect some ugly archaic looking
> text-only interface...
> Yes, I've used SSH myself. It's quite neat that I can have an old 386
> laptop sitting in a cupboard somewhere and operate it basically as if I
> was sitting in front of it. On the other hand, would it be so hard to do
> so with a less primitive interface?
it's strange that I guy used to programming languages feels awkward
about a text interface.  Plus, were you ever taught that one shouldn't
judge a book by its cover?  Notepad in all its glorious graphical user
interface is much more featureless and rudimentar than vi on an old Unix
terminal.
There is power in words, they make spells and those magical enchantments
make things happen in the real world, like dispensing cash at your local
ATM.
Date: 10 Nov 2010 17:07:12
Message: <4cdb1790$1@news.povray.org>
Invisible wrote:
> I've always thought that manpages and the ugliest, lamest, most archaic
> thing ever, so I don't see that that's much of an advantage.
Oh, wait. Aren't you the one that goes on about LaTeX and Postscript? :-)
I'm not sure what you have against a text-based program for generating
typeset output.
> (On the other hand, today's reading suggests that troff is really
> designed to control phototypesetters - whatever those are - and not
> produce stuff on screen...)
Plus, they didn't produce stuff on screen. This is hardcopy land. Screens
were advanced stuff. :-)
   Serving Suggestion:
Date: 10 Nov 2010 20:35:00
Message: <web.4cdb481595607d658c9d68c40@news.povray.org>
> it's strange that *a* guy used to programming languages feels awkward
> interface is much more featureless and *rudimentary* than vi on an old Unix
> terminal.
> ATM.
Date: 11 Nov 2010 04:19:04
Message: <4cdbb508$1@news.povray.org>
>> xs <- many1 digit
No it doesn't.
Parsec doesn't backtrack by default; you have to explicitly request it
(which I haven't).
If there are more than three digits, the above parser fails, and no
other alternatives are tried (i.e., no backtracking).
(As an aside, there are other Haskell libraries that work similarly to
Parsec, but where backtracking is the default and turning it off is
explicit. Apparently this is more intuitive to work with...)
Date: 11 Nov 2010 04:22:39
Message: <4cdbb5df$1@news.povray.org>
It's something I generally try to avoid, yeah. :-)
Um, *yes*. Why, do you think it doesn't have worth?
>> xs <- many1 digit
So define a combinator for it:
   manyN 0 _ = return []
   manyN n p = do x <- p; xs <- manyN (n-1) p; return (x:xs)
And now, forever more, you can merely write
   manyN 3 digit
Problem solved.
EDIT: Apparently this function is already predefined. I hadn't even
noticed. I could have just written "count 3 digit". In all the time I've
been writing parsers, I've never needed this.
Date: 11 Nov 2010 04:27:10
Message: <4cdbb6ee@news.povray.org>
>> do
>> many1 digit
>> option (char '.')
>> many1 digit
I don't follow. Where do you think by definition deviates from your spec?
> "trivial macros".
I've never seen a system that can do that, but I guess that doesn't
prove a lot.
Sure. Except without any guarantee of syntactic correctness.
Not every string is a valid regex. You have to follow the syntax rules.
But this is not checked at compile-time (and usually /cannot/ be checked
at compile-time). So if you make a typo in your regex, you won't find
out until runtime.
If you start constructing regexs programmatically, your problems just
multiplied.
On the other hand, with a /real/ parser library, both of these grave
problems immediately vanish into thin air.
