POV-Ray : Newsgroups : povray.off-topic : Really deep Mandelbrot zoom Server Time
25 Feb 2026 16:32:34 EST (-0500)
  Really deep Mandelbrot zoom (Message 30 to 39 of 39)
Subject: Re: Really deep Mandelbrot zoom
Date: 7 Nov 2010 22:39:13
Message: <87lj54jxed.fsf@fester.com>
Francois Labreque <fla### [at] videotronca> writes:
> Holy crap!  FractInt is still maintained!  There goes today's hope of
> doing actual work.
Not well maintained, though.
Date: 8 Nov 2010 04:12:09
Message: <4cd7bee9$1@news.povray.org>
>> doing actual work.
No, there is that.
Then again, most of the recent questions on the FractInt mailing list
are "how do I make FractInt run under Windows XP?" or "how do I make an
MS-DOS boot disk?"
It's a powerful little program, for sure, but I fear it has been
somewhat left behind by now...
Date: 8 Nov 2010 12:22:14
Message: <4cd831c6$1@news.povray.org>
Is it open source? It would seem to be the kind of thing that isn't hard to
keep up to date, at least at the core.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 8 Nov 2010 12:54:16
Message: <4cd83948@news.povray.org>
> >> doing actual work.
> No, there is that.
> MS-DOS boot disk?"
  I would recommend XaoS. It might have all the features of fractint, but
most fractals can be zoomed in real-time, which makes it cool.
Date: 9 Nov 2010 02:45:08
Message: <op.vlv7s12eufxv4h@go-dynamite>
>> >> doing actual work.
>> No, there is that.
>> MS-DOS boot disk?"
I'd love to see a screensaver like that =)
-Nekar Xenos-
Date: 9 Nov 2010 04:22:01
Message: <4cd912b9$1@news.povray.org>
> to keep up to date, at least at the core.
Yeah, the source code is completely open.
On the other hand, the entire UI is text-mode fun and games using BIOS
calls, and the entire graphical engine revolves around either calling
the BIOS or directly poking magic numbers into hardware registers.
(Wanna guess why it doesn't work under Windows any more?)
On top of that, the entire program fundamentally assumes you're working
with 6 bits per channel and palette graphics. These assumptions are not
easy to change. (E.g., all of the external file formats describe colours
as triples of integers between 0 and 63.)
Really, it would be simpler and quicker to just start again. And indeed
many modern fractal programs understand FractInt parameter files as a
sort of de facto data standard. (Although none of them have the layers
upon layers of backwards compatibility that FractInt itself has, and
AFAIK none of them can read the data chunks that FractInt embeds in the
GIF files it writes.)
Then again, I'm not really aware of any freeware program that has quite
the range of scope that FractInt has. Most of them seem to plot just one
kind of fractal, and that's it...
Date: 9 Nov 2010 04:24:11
Message: <4cd9133b$1@news.povray.org>
On the other hand, it seems to be comparatively slow. And it doesn't
have arbitrary precision, so you can only zoom in so far. (Then again,
FractInt's arbitrary precision mode makes continental drift look fast,
so...)
It also has an annoying habit of sometimes "forgetting" to finish
rendering an image. Like, when you zoom in it's all blocks, and
gradually the resolution increases. But sometimes, it stops increasing
before it's finished.
Date: 9 Nov 2010 17:05:08
Message: <4cd9c594@news.povray.org>
  Comparatively slow? You can use XaoS to zoom into the Mandelbrot set
(and other fractals) in real-time. Fractint isn't that good.
> (Then again,
> so...)
  Btw, "continental drift" is an obsolete theory. "Plate tectonics" is the
currently accepted one.
  (Of course you are talking figuratively, but I couldn't help but nitpick.)
Date: 10 Nov 2010 04:18:58
Message: <4cda6382$1@news.povray.org>
FractInt seems to render things quite a bit faster than Xaos. I haven't
actually measured it, it just seems more responsive. And you don't need
to zoom in very far before you have to frequently stop zooming and let
Xaos catch up with redrawing the image, so you can see where to go next.
(It probably doesn't help that Xaos uses boundary-trace to draw the
image in certain instances, and the display updates very, very
infrequently while it does this. With FractInt, you can see what's
happening while it does this. It's kind of mesmerising, actually...)
It's news to me that continental drift isn't the same thing as plate
tectonics...
Date: 10 Nov 2010 10:26:08
Message: <4cdab990@news.povray.org>
> tectonics...
  Wikipedia is your friend.
