POV-Ray : Newsgroups : povray.off-topic : Programming language discussion Server Time
7 Jul 2026 21:55:28 EDT (-0400)
  Programming language discussion (Message 41 to 47 of 47)
Subject: Re: Programming language discussion
Date: 28 Oct 2010 15:36:40
Message: <4cc9d0c7@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Besides, normally just about any code that does stuff to a linked list
> ends up doing something like
>    while (list != null)
>      do stuff;
>      list = next node;
> So there's a check in there anyway. All we're doing by using a union is
> making it a different check.
  Ostensibly there could be other types of nodes in the list besides regular
nodes and end nodes. These could, for example, contain different types of
data. Any operation you do on the data would have to first check that the
node is of the correct type (if the node is a union).
Date: 28 Oct 2010 15:47:40
Message: <4cc9d35c@news.povray.org>
>>       do stuff;
>>       list = next node;
Sure. But the compiler statically knows what all the possibilities are,
and it can decide on some suitable arrangement for doing this efficiently.
Instead of writing the above, in Haskell you end up doing something like
   do_stuff list =
     case list of
       Node data next -> ... [recursively call do_stuff next] ...
       End            -> ...[do something else]...
If there are more possibilities than just "Node" or "End", you just list
them as extra possibilities. Either way, the compiler is going to build
a multi-way jump. (I believe GHC handles this using indirect code
pointers rather than actual integer comparisons against an ID tag.)
http://blog.orphi.me.uk/
Date: 28 Oct 2010 16:09:37
Message: <4cc9d881@news.povray.org>
Warp wrote:
> These could, for example, contain different types of data.
But you still need to do this, even if it's a struct, unless by "struct" you
mean all the data in every element is always valid, in which case you
wouldn't use a union in Haskell either.
Either you're operating on invalid data, or you're checking if the data is
valid before operating on it. Yes?
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 30 Oct 2010 20:43:32
Message: <4cccbbb4$1@news.povray.org>
On 10/22/2010 12:33 PM, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>> http://journal.stuffwithstuff.com/2010/10/21/the-language-i-wish-go-was/
>    I'm not so sure I agree with the necessity of 'union'.
>    'union' in C is basically a construct which exists to save some bytes
> of memory in some rare circumstances. The price you pay for it is reduced
> type safety: You always have to make sure you are using the object with
> the correct type, or else you'll get garbage. More often than not, unions
> are not used raw, but embedded in structs, where one of the struct members
> tells the type of the union. While in some situations you can use this to
> save memory (especially if you need to instantiate this struct millions of
> times), it introduces the overhead of the type member and having to always
> check it. (Without the union there would be no need to write any conditionals
> based on the type.)
>    You could have the language always automatically check the proper type
> of the union, but then you'll be having overhead on every single operation
> you are doing with that union (overhead which could in many cases be avoided).
> It would be rare for the memory saving advantage to be worth the overhead.
There might be an application in which a set of classes derived from a
common ancestor need to be forced to have the same size.  Then a member
which is of a different type in different classes would best be a union.
  Class member functions (late bound) would know which member of the
union to access without having to type check.
Really, though, the union is a kludge built into C for the resource-poor
early days of computing.
John
Date: 17 Nov 2010 18:35:51
Message: <4ce466d7@news.povray.org>
Warp wrote:
>   The most clever use of 'union' I have seen was like this:
> union Matrix4x4
>     double m[4][4];
>     struct
>         double m11, m12, m13, m14,
>             m21, m22, m23, m24,
>             m31, m32, m33, m34,
>             m41, m42, m43, m44;
>   This means you can access the matrix like "transform.m[1][2] = 5;"
> or like "transform.m23 = 5;";
>   Of course in this case this is just a trick to have two naming
> conventions to access the same data (rather than to save memory).
I know someone who got this to work via C++ operator overloading and other
nasties:
Vector3D a, b;
a.xy = b.zx;
It's equivalent to a.x=b.z; a.y=b.x; Any combination of xyz letters would
work, probably even a.xxx=b.yzy;
IIRC it even used SSE inline assembly to do the assignments.
Date: 18 Nov 2010 09:15:47
Message: <4ce53513@news.povray.org>
> nasties:
> Vector3D a, b;
> a.xy = b.zx;
  All to save typing a few extra characters... :P
  And probably hindering any possibility for the compiler to perform
optimizations resulting in even more efficient code...
Date: 18 Nov 2010 11:21:09
Message: <4ce55275$1@news.povray.org>
AFAIK, this is the sort of syntax that the 3D graphics cards use for
built-in vector operations. Of course, that's a separate compiler with
"custom" syntax, so it's probably just as efficient if not moreso.
I'm guessing given the name of the class he was trying to duplicate the
syntax used in the grpahics card stuff.
   Serving Suggestion:
