POV-Ray : Newsgroups : povray.off-topic : Firebug Server Time
14 May 2026 12:47:01 EDT (-0400)
  Firebug (Message 11 to 20 of 39)
Subject: Re: Firebug
Date: 21 Oct 2010 12:18:58
Message: <4cc067f2$1@news.povray.org>
Invisible wrote:
> You realise that the UI already highlights the lines that have code on
> them, right?
No, I haven't used it that much.
*You* should realize that I was speaking in more general terms. The kind of
statement "This has to be trivial" or "This has to be obvious" is often
mistaken, just like "this is obviously impossible" has been slowly being
beaten out of your vocabulary.  ;-)
Now, I will say, when I bought a compiler for a language touting how easy it
is to write correct programs, and I got it out and pushed the button for
"make me a Hello World skeleton project to start with", then pushed the
"Compile" button and got syntax errors, I felt like "how could you release
such a POS as an expensive compiler?"  So I'm not saying it's never justified.
> So the code to figure this out already exists. All you have
> to do is look at where the user put the breakpoint, and select the
> nearest line that's executable. The only possibly-tricky thing is having
> the breakpoint set on line X+N put appear to be set on line X.
I would just move the breakpoint. What would be tricky is if you click
between two functions - do you breakpoint the last line of the previous
function or the first line of the next function?
> I'm still trying to find a way to run CGI binaries (note: binaries, not
> scripts) without having to install and configure Apache or something
> like it.
tclhttpd?
> It seems there are plenty of light-weight HTTP servers, but all of them
> either lack CGI support entirely, or only support CGI *scripts* (usually
> in a single language).
I'm pretty sure tcl httpd supports CGI and FastCGI.  If not, it's pretty
trivial to do so. Basically, copy some header crap into environment
variables, pipe the incoming request to stdin of the CGI, and pipe the
stdout back to the browser.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 21 Oct 2010 12:19:32
Message: <4cc06814$1@news.povray.org>
Invisible wrote:
>> Or, for that matter, the Visual Studio debugger, FWIW. But, Visual
>> studio does something "clever": It moves the breakpoint if its not on a
>> valid line to the next valid line once it has the debugging info for the
>> module the code file belongs to.
> I wouldn't have called that "clever".
Note he didn't call it clever. He called it "clever".
   Serving Suggestion:
Date: 22 Oct 2010 04:22:49
Message: <4cc149d9$1@news.povray.org>
> of statement "This has to be trivial" or "This has to be obvious" is
> often mistaken, just like "this is obviously impossible" has been slowly
> being beaten out of your vocabulary. ;-)
>> So the code to figure this out already exists. All you have to do is
>> look at where the user put the breakpoint, and select the nearest line
>> that's executable. The only possibly-tricky thing is having the
Or you could do that, yes.
Or the first statement outside of a function? Or just refuse to set a
breakpoint there? There's several possible options.
>> them either lack CGI support entirely, or only support CGI *scripts*
>> (usually in a single language).
Constructing and parsing HTTP headers yourself also isn't all that
hard... and yet it turns out to be unexpectedly non-trivial to do a
really good job of it yourself. Especially when you're not actually
trying to write a web server, you just want something to test your CGI with.
Date: 22 Oct 2010 11:49:24
Message: <4cc1b284$1@news.povray.org>
> hard...
It didn't *used* to be. Now so much crap has been added to HTTP to support
everyone using it for something other than hypertext transport that yeah,
actually parsing the headers and doing the protocol turns out to be pretty
non-trivial.
   Serving Suggestion:
Date: 22 Oct 2010 11:53:38
Message: <4cc1b382@news.povray.org>
On 22/10/2010 04:49 PM, Darren New wrote:
>> hard...
> support everyone using it for something other than hypertext transport
> that yeah, actually parsing the headers and doing the protocol turns out
> to be pretty non-trivial.
http://www.w3.org/Protocols/HTTP/AsImplemented.html
Woah! That's pretty... um... special, right there.
Hmm, I wonder if any modern software actually handles HTTP 0.9 correctly?
Date: 22 Oct 2010 12:17:39
Message: <4cc1b923$1@news.povray.org>
Yep. Like all good protocols ;-) it doesn't have a version number in the
first version. That's why the "HTTP/1.0" comes at the end of the request
instead of the beginning.
*Almost* everything since then has been to deal with the fact that HTTP
isn't being used for transporting hypertext, or to add all the features that
all the other data transfer protocols already had.
Most web browsers do, yes. When I want to see if something is actually
running a web server, I'll often telnet in by hand and just "GET /" to see
that I get some sort of answer.
   Serving Suggestion:
Date: 22 Oct 2010 12:20:40
Message: <4cc1b9d8$1@news.povray.org>
Oh, and it's also the first internet protocol that said you had to be able
to handle any kind of line terminator.
   Serving Suggestion:
Date: 25 Oct 2010 11:31:48
Message: <4cc5a2e4$1@news.povray.org>
On Wed, 20 Oct 2010 18:55:25 +0100, Orchid XP v8 wrote:
> When you fire
> up a debugger with support for breakpoints, literally THE FIRST THING
> you're going to do is try to stick breakpoints on top-level functions.
> How did this miss this?!
Not me, because it seems obvious that only code that executes can be
halted by a breakpoint.  I can't think of a debugger I've ever used that
lets you set a breakpoint on non-executable code.  Or if I have, I've
never needed to use that functionality.
Jim
Date: 25 Oct 2010 16:53:00
Message: <4cc5ee2c@news.povray.org>
>> When you fire
It's pretty self-evident that if you put a breakpoint on the name of a
function, you want it to break every time that function is called.
(It's also pretty self-evident that having some visual feedback about
where you can and can't put breakpoints would help enourmously.)
http://blog.orphi.me.uk/
Date: 26 Oct 2010 09:56:42
Message: <4cc6de1a$1@news.povray.org>
Remember: The function declaration is just that: A declaration. It has
no code. Depending on the compiler and execution environment the actual
code will be the first statement with the potential addition of
declarations of variables with assignment.
On the second point. Yeah, I agree it would be nice.
~Mike
