POV-Ray : Newsgroups : povray.off-topic : Gah... Server Time
18 Mar 2026 00:36:06 EDT (-0400)
  Gah... (Message 21 to 30 of 36)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Gah...
Date: 23 Sep 2010 12:14:42
Message: <4c9b7cf2$1@news.povray.org>
On Wed, 22 Sep 2010 21:15:22 +0100, Orchid XP v8 wrote:
> I could go on... GIYF.
<checks that gravity is still working>
Yep, gravity's still on. ;-)
Jim
Subject: Re: Gah...
Date: 23 Sep 2010 13:50:39
Message: <4c9b936f@news.povray.org>
Mike Raiford escreveu:
> On 9/22/2010 12:02 PM, nemesis wrote:
>> neverending revelations... pi *has* uppercase... *head spins*
> Greek, like Latin has both upper and lower case.
I'm used to Scheme, you case-sensitive clod!
a game sig: http://tinyurl.com/d3rxz9
Subject: Re: Gah...
Date: 24 Sep 2010 02:57:44
Message: <4c9c4be8$1@news.povray.org>
On 23/09/2010 12:59 PM, Invisible wrote:
> Yes - but you must be careful that it's spelt the word you actually
> want. (!)
True
> Well, whatever.
Hmm!
> In the case of knowing the Greek alphabet, this is
> trivially searchable. Indeed, you just need to type "Greek alphabet"
> into Wikipedia...
Or just remember it.
Best Regards,
Subject: Re: Gah...
Date: 24 Sep 2010 04:44:41
Message: <op.vji3wtvumn4jds@phils>
And lo On Thu, 23 Sep 2010 13:15:45 +0100, Mike Raiford
<"m[raiford]!at"@gmail.com> did spake thusly:
> On 9/23/2010 6:59 AM, Invisible wrote:
>> Well, whatever. In the case of knowing the Greek alphabet, this is
>> into Wikipedia...
> That is, of course, if you know the character you're looking at belongs
> to the Greek alphabet. Otherwise, googling is futile.
> Though, I guess since it's a mathematical symbol chances are, it's Greek.
Although if you know its a mathematical symbol you can Google that and get
http://en.wikipedia.org/wiki/Table_of_mathematical_symbols as the first
return and just scroll down that until you see the same one ;-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: Gah...
Date: 24 Sep 2010 04:50:05
Message: <op.vji35termn4jds@phils>
And lo On Thu, 23 Sep 2010 13:10:44 +0100, Mike Raiford
Or to put it another way Greek like Latin has only upper case letters with
lower case being only a recent introduction ;-)
Phil Cook
Subject: Re: Gah...
Date: 24 Sep 2010 05:02:17
Message: <4c9c6919@news.povray.org>
> get http://en.wikipedia.org/wiki/Table_of_mathematical_symbols as the
> first return and just scroll down that until you see the same one ;-)
And, like it says at the very top, "this list is incomplete". ;-)
Subject: Re: Gah...
Date: 24 Sep 2010 07:59:45
Message: <4c9c92b1$1@news.povray.org>
On 9/23/2010 7:26 AM, Invisible wrote:
> Good luck looking up Aleph and Beth. ;-)
Hebrew... I learned about ‬‭‭א‬‭‭‪‪₀ from the commentary on
Futurama of
all things.
(Apologies if that doesn't show properly ... Some fonts may not contain
the proper glyphs, and I had a hell of a time with the whole RTL thing
and getting the proper control code in there to revert from RTL to LTR.
Hebrew characters inline can be a bit bothersome ;)
~Mike
Subject: Re: Gah...
Date: 24 Sep 2010 08:24:48
Message: <4c9c9890@news.povray.org>
You think that's bad? You try doing *arithmetic* with transfinite
cardinal numbers! :-P
Almost any function of infinity IS ALSO infinity! >_<
Subject: Re: Gah...
Date: 24 Sep 2010 08:33:07
Message: <4c9c9a83$1@news.povray.org>
Case sensitivity gives me twice as many characters available for
variable names!
As a fun aside... apparently C# will accept any
non-number/non-punctuator as a valid variable name. This is valid C#
code and will compile and execute (and give completely wrong results):
         private static double Γ(double z)
             // in reality this would actually return the result of the
gamma function...
             return z;
         static void Main(string[] args)
             Console.WriteLine("The value of the gamma function is: " +
Γ(1));
             Console.ReadKey();
A good way to piss off your co-workers, for sure.. XD
~Mike
Subject: Re: Gah...
Date: 24 Sep 2010 08:34:56
Message: <4c9c9af0@news.povray.org>
I think I'll hold off on that one for a little while. ;)
~Mike
