![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK, so I realise nobody else gives a damn, but it's frustrating the hell
out of me. All I want to do is convert a tiny, minute, small, simple,
little, trivial, diminutive, insignificant little formula into MathML. I
have just spent literally an hour trying to achieve this tiny task, and
so far have failed miserably. I can't find any web page anywhere on the
face of the Internet that will perform the trivial conversion required
for me.
Wolfram have a page that will turn a Mathematica expression into MathML.
But there isn't any way of writing the construct I want in Mathematica.
The first hit from Google is this:
http://www.orcca.on.ca/MathML/texmml/textomml.html
This is THE EXACT THING THAT I WANT. So imagine my utter rage that IT
DOESN'T ACTUALLY WORK! >_<
I also found this:
http://www.maths.nottingham.ac.uk/personal/drw/lm.html
This works, BUT... I still cannot ACTUALLY VIEW THE MARKUP. I can make a
web page, put some LaTeX markup in it, and load the page, and Firefox
displays it correctly. However, it WILL NOT show me what MathML has
actually been generated. It only shows me the source code it loaded from
disk, not what it was ultimately transformed into.
At this point, it seems that the only option I have left open to me is
to spend 4 days reading through the incomprehensible MathML spec
document. All so that I can convert a piffling 3 characters into MathML...
(I wouldn't mind, but I don't even know if using MathML will actually
fix the problem anyway!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
So add a button you can click when it's done to dump out the DOM that the
javascript created. That'll be a good oppotunity to learn javascript and
DOM processing.
(Or take a look at it in firebug or something?)
C# - a language whose greatest drawback
is that its best implementation comes
from a company that doesn't hate Microsoft.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the javascript created. That'll be a good oppotunity to learn
> javascript and DOM processing.
I guess I could do... It's just intensely frustrating when I wanted to
just quickly test something and I end up having to spent an hour or so
coding, testing and debugging something. I am literally astonished that
there isn't a website that will just *do* all this for you. It's not
exactly a complex transformation, it's just difficult to do by hand...
Never heard of Firebug. However, I just installed it, and in about 20
seconds flat I got what I wanted.
If only I knew about this thing sooner...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Heh, I've never seriously tried to use MathML before. On the plus side,
it does solve the problem I had (i.e., various math symbols have Unicode
codepoints, but don't exist in any known typeface). On the other hand...
it's a tad verbose.
With TeX, if you want to write "x" as a mathematical variable rather
than a piece of text, you simply say "$x$". But by the power of MathML,
if you want to do this in DocBook, you write
<inlineequation>
<math xmlns="http://www.w3c.org/1998/Math/MathML">
<mrow><mi>x</mi></mrow>
</math>
<inlineequation>
which is somewhat more typing. There's probably some trick that removes
the need to keep typing in the XML namespace URL every time, but even
then you'd still have
<inlineequation><math><mrow><mi>x</mi></mrow></math><inlineequation>
which is a lot of typing considering that only one single character of
that will appear in the final output.
Now I see why people like to use specialised editors to write this
stuff. ;-) Typing HTML by hand is trivial, but this stuff is just
mental. (!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Glad to have helped!
You don't write much complex javascript, is all. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh, only a Mandelbrot plotter and an LZW demo and a Huffman
encoder/decoder and...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's not complex javascript until you start dicking with the DOM. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...and how do you think the Mandelbrot plotter, you know, plots? :-P
(I got the trick from Slime, by the way.)
Also, my cubic equation solver works by basically opening a new frame
and dynamically generating the entire content that should go in there.
(I don't even remember how now...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would think that a Mandelbrot plotter, an LZW demo and a Huffman
encoder/decoder would be a /lot/ more complicated than anything you
could do with the DOM.
http://isometricland.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> mental. (!)
I wish it were suipported by browsers though. I've got a handful of
equations scattered around my website, and it would make the equations
look a little flashier than plain text.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
