POV-Ray : Newsgroups : povray.off-topic : FizzBuzz Server Time
26 Feb 2026 21:13:02 EST (-0500)
  FizzBuzz (Message 1 to 10 of 24)
Subject: FizzBuzz
Date: 4 Jul 2010 05:50:14
Message: <4c305956$1@news.povray.org>
http://www.codinghorror.com/blog/2007/02/why-cant-programmers-program.html
Oh, *that's* fizzbuzz? Hmm, OK.
Also... that's really kinda scary. o_O Let's hope plumbers are better...
uh... hmm, OK, maybe not. Well let's hope to **** that medical
professionals are better! O_O
http://blog.orphi.me.uk/
Subject: Re: FizzBuzz
Date: 4 Jul 2010 06:10:24
Message: <4c305e10@news.povray.org>
  As I have commented previously somewhere, I have heard about this here
as well. What's worse, at least in the past companies actually hired people
for programming positions just on the basis that those people *claimed* to
be competent programmers even though they hadn't ever written a single line
of code.
  Why do people apply to programming jobs even though they have no experience
whatsoever? My guess is that their rationale goes like: "I need a job badly.
Programming is really easy; heck, even kids can do it, so how hard can it be?
I'll ensure the job first, and learn the programming part later. It'll
probably take just a week or two."
  On a side note, interviewers should, on the other hand, be careful with
what they consider "trivial" assignments. Sometimes a problem might sound
quite easy and trivial, when in fact it isn't.
  As an example, the basic principle between binary searching (searching an
element in a sorted array in O(log n) time) sounds quite trivial. However,
it's surprisingly difficult to implement correctly.
  Take 100 experienced, competent programmers and give them the task of
implementing binary search on paper in the programming language they are
most fluent with, and perhaps 5 of them will give you a correct
implementation. (The rest will fail in some cases mostly due to off-by-one
errors.) A correct implementation requires surprising amounts of attention
to detail, and a quick&dirty naive implementation will most probably be
incorrect. And this for a piece of program that requires maybe 10 lines of
code at most.
Date: 4 Jul 2010 07:06:27
Message: <4c306b33$1@news.povray.org>
> of code.
I don't think this is unique to programming. From what I've seen, most
managers get hired based on their ability to spout impressive-sounding
BS rather than their ability to actually manage a department.
I would imagine that quite a few of then know damned-well that they
can't program, and expect to be able to just con somebody into hiring
them. I imagine this is the same for every profession.
The difference is that if, say, you claim to be a brick layer, and they
ask you to build a small wall, and it looks like a piece by Picasso,
then you don't need to be an expert builder to tell that this person is
lying out of their arse. On the other hand, a broken program doesn't
look "obviously" different to a working program. An expert can tell
immediately, but to the casual observer, it's not so clear. So it's
harder to tell whether somebody can program.
In a similar vein, there's probably a greater opportunity for
self-delusion. If you try to build a wall and it's rubbish, you start to
realise that building a wall is far more complicated than you expected.
But if your program doesn't compile... it there just some small thing
you need to fix? Or is it because your code is gibberish?
I'm sure I must have told you the tale of the MSc student who begged me
to "fix me Java, yah?" He claimed it was nearly working, but it just
needed a few small tweaks. So I sat down and read his "Java". What he
had written was a bunch of Java language keywords, lots of curly
brackets, nice indentation, but... IT WAS NONESENSE! It wasn't Java. It
was gibberish that bore a superficial resemblance to Java. Lots of
hopeful-sounding variable names, but not even approaching being
syntaxually correct.
To this day, I'm genuinely not sure whether the guy was just writing
gibberish and hoping to bluff his way through (or get somebody to do it
for him), or whether he actually believed his code was nearly correct...
Finally, if you sculpt a work of art, everybody looks at that and goes
"oh, that's great, it must have been really hard to make that". It's not
nearly so obvious that programming is hard. (Especially when vendors
keep trying to sell whizzy tools that make it all "easy" for "anybody to
do".)
If the interviewer asks you to solve the Travelling Salesman Problem so
that it can find a route between 500 cities in just a few seconds, you
probably don't want to work for them. ;-)
> code at most.
Hmm, OK. This doesn't sound especially hard. So let me see if I can
implement it, and then everybody can laugh at how badly I got it wrong...
   find :: (Ord y) => (x -> y) -> y -> IArray x -> (Int,Int) -> Maybe x
   find field target array (base,size)
     | size <  0 = error "invalid subrange size"
     | size == 0 = Nothing
     | size == 1 = if field (array ! base) == target then Just (array !
base) else Nothing
     | otherwise = find field target array (base, size `div` 2)
`mappend` find field target array (base + size `div` 2, size `div` 2)
Now I suppose I better go run that and see if it actually works.
Subject: Re: Binary search
Date: 4 Jul 2010 07:11:18
Message: <4c306c56$1@news.povray.org>
>     | size == 0 = Nothing
> base) else Nothing
>     | otherwise = find field target array (base, size `div` 2) `mappend`
Well, the final line is wrong for a start. (Due to rounding, if the
array size isn't even, one element gets elided from the search.)
   | otherwise =
     let size2 = size `div` 2
     in  find field target array (base, size2) `mappend` find field
target array (base + size2, size - size2)
That should work better. The division of a range into two subranges is
still unequal, but at least all elements are included now...
Subject: Programming failure
Date: 4 Jul 2010 10:48:46
Message: <4c309f4e$1@news.povray.org>
I few clicks away from this, I got to here:
http://www.eis.mdx.ac.uk/research/PhDArea/saeed/paper1.pdf
I don't know about you, but *I* have always wondered why some people
find programming hard. It is a "well known" fact that there seem to be
two types of students: those who "get" programming, and find
introductory courses ridiculously easy, and those do "don't get"
programming, and find even the simplest exercises insummountably difficult.
I haven't finished reading this paper yet, but it throws some
interesting ideas out there. One particular paragraph leaps out at me:
capabilities of computers could have a massive negative impact on their
success at programming. Many of their subjects tried to use meaningful
names for their variables, apparently hoping that the machine would be
able to read and understand those names and so perceive their intentions."
Oh I have *so* seen this! People who seem to think that if they write
their code with obvious-enough names and syntax that's near-enough to
being correct, the computer will "just know" what they mean. They fail
to grasp that the syntax must be EXACTLY CORRECT, even if it seems silly
or unnecessary.
I guess it's because they're used to talking to humans. If you say
something to a human with somewhat incorrect grammer (or even
horrifyingly broken grammer), they can usually still figure out what you
mean.
Computers are far, far more stupid than humans. But decades of advances
in computing technology have brought us to the point where computers
*look clever*, even though they aren't. I suspect this might be why some
people have trouble learning to *use* a computer too.
Date: 4 Jul 2010 10:55:01
Message: <web.4c309fba99168f123cfb39c30@news.povray.org>
the real problem is that many people who should really be plumbers or medicals
are into programming careers.  well, plumbing may still have its uses... :)
Date: 4 Jul 2010 11:05:54
Message: <4c30a352$1@news.povray.org>
Well, hey, at least getting programming wrong doesn't kill people...
...oh, wait:
http://en.wikipedia.org/wiki/Therac-25
Hmm. Oh dears.
Well, at least if a plumber or medical person does their job wrong, you
can get compensation? :-}
Date: 4 Jul 2010 11:08:39
Message: <4c30a3f7$1@news.povray.org>
One could argue that The Real Problem(tm) is that IDE vendors keep
claiming to have made programming "easy" now. ;-)
Date: 4 Jul 2010 15:35:02
Message: <4c30e266$1@news.povray.org>
> of code.
I usually ask them to print out the prime numbers less than 100 or something.
Yeah. I had one that was something like "print the lowest N values from a
binary tree, in C". When's the last time I did recursion in C? And doing it
over the phone? Bleh.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 4 Jul 2010 15:50:01
Message: <web.4c30e58b99168f12c91dc5c20@news.povray.org>
still waiting for the magical "Make Solution" button... ;)
