POV-Ray : Newsgroups : povray.off-topic : Small math/programming problem Server Time
2 Apr 2026 13:13:56 EDT (-0400)
  Small math/programming problem (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Small math/programming problem
Date: 1 Jul 2010 11:26:43
Message: <4c2cb3b3@news.povray.org>
Invisible wrote:
> So what's the answer? I make it
> .....1,549,498,368
I believe that answer is correct, although I'm not sure your reasoning
behind the algorithm was watertight.  In particular, since you're
applying modular exponentiation in each iteration, you're implicitly
assuming that a^b mod m == a^(b mod m) in the next iteration.
Fortunately this ends up bring very close to true in this case, so
everything still works out, but to be totally safe you should really
compute everything mod lcm(10^10,phi(10^10)) = 10^11.  Unless I was
overly conservative in my analysis somewhere.
Now for a tricker question, say I add another loop:
n = 2
for(a = n; a > 0; a--)
   for(b = n; b > 0; b--)
     for(c = n; c > 0; c--)
       for(d = n; d > 0; d--)
         for(e = n; e > 0; e--)
           n++
print n
What are the last five digits printed?
Note that I haven't actually worked through this yet to be sure that my
idea or solving it will actually work, so be forewarned that I'm not
positive it's possible.
Date: 1 Jul 2010 11:38:33
Message: <4c2cb679@news.povray.org>
scott wrote:
>> So the answer we seek is (approximately) 2↑↑↑2.
> Isn't that 4?
No, since 2^^^2 = 2^^2^^2 = 2^^(2^2^2) = 2^^16 =
2^2^2^2^2^2^2^2^2^2^2^2^2^2^2^2.
However, in this case you can very easily give a somewhat tighter lower
bound of 2^^2048, that is 2^2^2^2^ ... 2048 times ... ^2^2^2
Date: 2 Jul 2010 00:11:41
Message: <4c2d66fd@news.povray.org>
> n = 2
>           n++
> print n
Ok, I haven't been able to post today since I've been on airplanes on or
airports without wireless the whole time, but I implemented the solution
and it seems to work, so this problem is totally solvable, and only
takes a fraction of a second on my computer.
It turns out that the solution is actually quite simple too!  Possibly
even more so than that to the last puzzle -- although certainly not as
mathematically concise.
Actually pretty fun, so feel free to give it a shot knowing that it does
indeed have a relatively simple solution!
Date: 2 Jul 2010 00:16:19
Message: <4c2d6813$1@news.povray.org>
Invisible wrote:
>  (Assuming you meant the last 10 *decimal* digits...)
Man, meaning the last ten binary digits would have made this the lamest
trick question ever (so yeah, you're correct in solving for decimal
obviously).
Date: 2 Jul 2010 00:50:33
Message: <4c2d7019$1@news.povray.org>
scott wrote:
>> .....1,549,498,368
> I recognise those last 6 digits!  I think I got them from my program,
> but then my method was too slow to do any more digits in reasonable time.
It's interesting that you had an algorithm that could compute six digits
but not ten.  You might try running it on the second version of the
puzzle that I gave, since I only ask for the last five digits in that
case.  Maybe it'll work!
Date: 2 Jul 2010 02:10:10
Message: <4c2d82c2$1@news.povray.org>
>> Isn't that 4?
I understood from wikipedia that 2^^^3 = 2^^2^^2 and 2^^^2 = 2^^2.  Is that
wrong?
Date: 2 Jul 2010 02:13:24
Message: <4c2d8384$1@news.povray.org>
>>> .....1,549,498,368
>> I recognise those last 6 digits!  I think I got them from my program, but
> but not ten.
Well I simplified as far as Invisible did, and then didn't go through the
modular math to simplifiy it, just applied the mod operator at various
points in the code.  Using mod 1e5 took a fraction of a second, mod 1e6 took
about 10 seconds, and mod 1e7 never finished!
> You might try running it on the second version of the puzzle that I gave,
> since I only ask for the last five digits in that case.  Maybe it'll work!
Hmmm.
Date: 2 Jul 2010 03:56:09
Message: <4c2d9b99$1@news.povray.org>
I have a truly marvelous proof of this, which this forum is too small to
contain...
Date: 2 Jul 2010 05:31:02
Message: <4c2db1d6@news.povray.org>
>> or airports without wireless the whole time, but I implemented the
>> solution and it seems to work, so this problem is totally solvable,
>> and only takes a fraction of a second on my computer.
>> does indeed have a relatively simple solution!
> contain...
LOL ;-)
Best Regards,
Date: 2 Jul 2010 05:33:23
Message: <4c2db263$1@news.povray.org>
>> contain...
> LOL ;-)
You may laugh, but for 300 years mathematicians have been unable to
rediscover this "marvellous proof" - so excuse me if mathematicians are
a teeny bit skeptical about sweeping claims. ;-)
