POV-Ray : Newsgroups : povray.off-topic : ReactOS Server Time
12 Jul 2026 18:06:44 EDT (-0400)
  ReactOS (Message 14 to 23 of 63)
Subject: Re: ReactOS (pictures)
Date: 22 Jun 2010 17:10:32
Message: <4c2126c8$1@news.povray.org>
Orchid XP v8 wrote:
> Well, again, Wikipedia asserts that the entire thing was done using 100%
> clean-room development,
Huh. Interesting. It's odd how they managed to get every little look pretty
much exact.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 22 Jun 2010 17:18:16
Message: <4c212898$1@news.povray.org>
>> 100% clean-room development,
> pretty much exact.
Well, if you get somebody to disassemble the code, write down the
*exact* rendering parameters, and then give just the parameters to the
guy who writes the new code, then you have "clean-room development", yet
it looks pretty identical.
But take a closer look: Notepad has a line/column count. The command
prompt has a different aspect ratio. A lot of icons are completely
different. And so on. (And let's not forget, a lot of the very basic
Windows stuff uses quite simple layouts, probably thrown together quite
quickly.)
http://blog.orphi.me.uk/
Subject: Re: ReactOS [also... WTH?]
Date: 23 Jun 2010 08:57:07
Message: <4c2204a3$1@news.povray.org>
On 6/22/2010 11:18 AM, Phil Cook v2 wrote:
> And lo On Tue, 22 Jun 2010 14:16:53 +0100, Invisible <voi### [at] devnull> did
> spake thusly:
>> Check out the shutdown message. What's with that?
> They Live!
I recall a similar quote from Duke Nukem 3D.
Date: 23 Jun 2010 13:19:25
Message: <4c22421d@news.povray.org>
On 6/22/2010 1:12 PM, Orchid XP v8 wrote:
> All of which is of course completely irrelevant, since every single tiny
> aspect of all M$ products are covered by 80,000,000 patents, so if this
> product ever starts actually working properly, the developers will still
> be sued off the face of the Earth.
How long do software patents last? I would guess that in the same amount
of time hardware and virtualization speeds would have increased so much
that you might as well just run the *actual* OS in VMWare or whatever.
http://isometricland.com
Date: 23 Jun 2010 13:22:32
Message: <4c2242d8@news.povray.org>
>> spake thusly:
>> They Live!
Yep, it's Dike Nukem.
Date: 23 Jun 2010 13:43:09
Message: <4c2247ad$1@news.povray.org>
lol More like, for so long, at this point, that you could build a VMWare
version that "mimics" 4 core processors, while running it on 64 cores,
while using only 2GB or the 16TB of memory available to your 5 year old
computer system. The patent system is that screwed up, from what I have
seen.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 23 Jun 2010 15:09:11
Message: <4c225bd7$1@news.povray.org>
> seen.
That sounds like way too many cores. AFAIK multi-core CPUs are just a
temporary "hack" to resolve heat issues. There's only so much room on a
motherboard, and with 64 cores you may run out!
Date: 23 Jun 2010 16:18:33
Message: <4c226c19@news.povray.org>
> pretty much exact.
What looks exactly?
Note that the GUI widgets are probably all rendered by Wine code...
Date: 23 Jun 2010 17:24:30
Message: <4c227b8e@news.povray.org>
The problem isn't technology, it's law. ReactOS exists so you can run
Windows software without actually paying for Windows. (Of course, as I
pointed out, this doesn't actually work yet.)
Date: 23 Jun 2010 20:38:17
Message: <4c22a8f9$1@news.povray.org>
I don't know, but I know a guy who just received one that the application
went in *8* years ago for.
Jim
