POV-Ray : Newsgroups : povray.off-topic : Stupid question time Server Time
27 Feb 2026 03:22:16 EST (-0500)
  Stupid question time (Message 11 to 20 of 32)
Subject: Re: Stupid question time
Date: 21 Jun 2010 08:43:44
Message: <4c1f5e80$1@news.povray.org>
>> Given what the machine does, it seems plausible that the conversion is
>> perfectly linear.
>> A more important question is whether the conversion factor is *constant*
>> or not...
> If it is linear then the conversion factor must be constant.
What give you that idea?
It may be that the conversion is perfectly linear, but that the
conversion factor depends on the chemical composition of what you're
analysing. So each time you analyse a set of samples, there is a linear
conversion, but it's different each time.
> You need the input specs for the software.
It turns out the software itself can do the necessary conversion, so
problem solved...
Date: 21 Jun 2010 12:26:09
Message: <4c1f92a1$1@news.povray.org>
Invisible wrote:
> What's the difference between tab-delimited and pipe-delimited? Well,
> let me see now... one of them is a file who's fields are delimited by
> tab characters, and the other uses pipe characters instead. What, you
> couldn't figure that out all by yourself?
If one doesn't know that "pipe" is a character or that the file has fields
or whatever, then no. Plus, of course, the question isn't "what's the
difference" but "which should I use?"  If you haven't figured out that
mapping of "what I asked" to "what information I'm looking for", then *you*
are the one that's silly. ;-)
> Should you leave the card for me to sign? Actually no; just hand it over
> blank. It'll be fine, right?
Better than if it arrives too late perhaps.
> The final question is less stupid. Although trying to convert milivolts
> to microseimens would be like trying to convert miles per hour into
> pounds per square inch. (But in SI units at least...)
You're not even spelling it consistently, so who are you to argue? ;-)
And in this case the right answer is "multiply by ..." to convert the units.
Again, you're thinking the question asked is silly, while what's actually
likely to be happening is you are answering the question asked rather than
providing the information requested. I used to be really bad and did this
all the time, until I figured out that every time someone asked a "silly"
question, what they wanted was for me to figure out first what confusion
would cause them to ask that question, *then* answer the question they
*should* have asked.
The right answer to *this* question is likely "what are you trying to do
that you would need to convert those units, because I can't think of any
measurement that would involve both sets of units."
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 21 Jun 2010 12:28:12
Message: <4c1f931c$1@news.povray.org>
Invisible wrote:
> I'm still trying to figure out why the hell she wanted to know, but
> anyway...
Because a program asked, or someone asked her for the file in one of those
two formats, etc.
Date: 22 Jun 2010 03:55:52
Message: <4c206c88$1@news.povray.org>
> the difference" but "which should I use?"  If you haven't figured out
> that mapping of "what I asked" to "what information I'm looking for",
> then *you* are the one that's silly. ;-)
I'm still trying to think of any software that's capable of producing
such files. (And, therefore, where the hell this person even found those
names from...)
>> over blank. It'll be fine, right?
There's no possibility of that. I'm personally going there anyway, so...
*gasp* You mean some guy who was sent to a school for people with
learning difficulties due to his total inability to read and write
actually spelt something wrong? GIVE ME A ****ING BREAK! It's old, OK? I
can't spell. We get it. Can we please move on now?
> units.
Fortunately, since I'm having this conversation with a scientist who
comprehends how SI units work, I didn't have much difficulty explaining
what the problem was. We both quickly concluded that there is no
universal way to do the conversion, although in the specific instance
we're looking at there probably is a conversion (but that doesn't help
because we don't know what it is).
> actually likely to be happening is you are answering the question asked
> rather than providing the information requested.
As I say, this is the least-silly question I got asked. It's more in the
relm of "dude, that's really quite random" than "that's a stupid thing
to ask".
Date: 22 Jun 2010 07:22:03
Message: <4c209cdb$1@news.povray.org>
>>> perfectly linear.
>>> or not...
Because hat's what linear means.
> analysing.
For measuring mho's?
That is what you are measuring in the machine.
Only if the cross sectional area or length of the sample is different.
You really need to read up on the physical properties of materials.
Best Regards,
Date: 22 Jun 2010 08:16:07
Message: <4c20a987$1@news.povray.org>
I think he was just teasing ... hence the smiley. But, yeah, spell
checkers and all :) <-- See the smiley ... no insult intended.
Actually, you spell better than most people on the net... (in general,
here is another story, but the people here appear rather intelligent.)
~Mike
Date: 22 Jun 2010 08:18:23
Message: <4c20aa0f$1@news.povray.org>
Mike Raiford wrote:
> But, yeah, spell checkers and all.
I have tried on multiple occasions to make the Thunderbird spellchecker
work. It's not having any of it. I have no idea why...
(I also cannot make Firefox spell-check in English, only American. It
doesn't seem to matter how many times I install the UK dictionary, it
will not correctly spell-check.)
Date: 22 Jun 2010 08:36:39
Message: <4c20ae57$1@news.povray.org>
T-bird's spellchecking works for me, albeit sometimes the dictionary is
a bit anemic.
Did you make sure the language selected is English - UK? Sometimes I
wish the English - US dictionary accepted both spellings of words, such
as realize vs realise, since I'm constantly tripped up by the "z"
spellings of such words, I prefer the "s" spelling. Though for things
like color vs colour, I prefer dropping the unnecessary "u" ;)
~Mike
Date: 22 Jun 2010 08:50:46
Message: <4c20b1a6$1@news.povray.org>
> a bit anemic.
Nope. Every time I spell-check something, it tells me that *every* word
is mis-split. (I.e., the dictionary is empty.) No matter how many times
I install a dictionary, I can't make this work. I've given up trying.
 From what I remember, sometimes there's an error and the dictionary
doesn't even install, and sometimes it does install but then there's no
option to select it or any evidence that it was ever installed.
> Sometimes I
Sometimes I think we should just nuke the whole English language and
design something that actually ****ing works.
Unfortunately, this is impossible.
Date: 22 Jun 2010 10:46:36
Message: <4c20cccc$1@news.povray.org>
> names from...)
Excel? Pretty much every program that exports tabular data can do it with
tabs, and most UNIXy programs wind up putting pipes in when necessary.
(Basically, systems that generated tabular data intended to go over the
internet as email before the abomination of using XML for that became common
has an option to use pipes.)
So she was asking if she should bring it so you can sign it there, or
whether you're going home first. Seems easy.
It just makes it hard to look up what the question is when you don't spell
the critical word right, is all. :-)  If he was actually asking how to
convert volts to seimands, yes, it would be silly. :-)
> to ask".
And my point is that there's almost no question that's a stupid thing to
ask. There's only literal interpretation of questions that someone is asking
without enough information to know what question they should be asking. If
you think a question is stupid, it's because you already know the answer. So
give it to them. :-)
