POV-Ray : Newsgroups : povray.off-topic : Linear regression Server Time
4 Jul 2026 07:59:09 EDT (-0400)
  Linear regression (Message 11 to 15 of 15)
Subject: Re: Linear regression
Date: 8 Jun 2010 15:43:15
Message: <4c0e9d53$1@news.povray.org>
Orchid XP v8 wrote:
>>> Any idea how to get a confidence estimate?
>> You could take a look at the section labeled "Confidence Intervals" on
>> the page that scott linked.
> Yes. Except, as originally explained, I don't understand it.
Considering that you're only looking for an implementation it doesn't
really matter that you understand what's going on so long as you can
just type in the equations.  Everything is pretty straightforward except
for determining t*_(n-2), for which I suggest either finding an existing
implementation of the inverse cumulative Student's t-distribution
function or looking up the appropriate value from the table on
http://en.wikipedia.org/wiki/Student's_t-distribution.
In case you're still having trouble, I whipped up some Python code to do
what you want.  It's almost pseudocode, so hopefully it'll be pretty
easy to follow even if you don't know Python.
from math import sqrt
from scipy.stats import t as tFcn
def linRegress(X, Y, conf):
	# maximum likelihood estimates
	n = len(X)
	Sx = sum(X)
	Sy = sum(Y)
	Sxx = sum(x*x for x in X)
	Sxy = sum(x*y for x, y in zip(X,Y))
	Syy = sum(y*y for y in Y)
	b = (n*Sxy - Sx*Sy)/(n*Sxx - Sx*Sx)
	a = Sy/n - b*Sx/n
	# confidence interval stuff
	ve = (n*Syy - Sy*Sy - b*b*(n*Sxx - Sx*Sx))/(n*(n-2))
	vb = n*ve / (n*Sxx - Sx*Sx)
	va = vb*Sxx / n
	tstar = tFcn(n-2).isf(1-conf)
	return (a, tstar*sqrt(va)), (b, tstar*sqrt(vb))
if __name__ == "__main__":
	# example data from the Wikipedia page
	X = [1.47, 1.50, 1.52, 1.55, 1.57, 1.60, 1.63, 1.65, 1.68, 1.70, 1.73,
1.75, 1.78, 1.80, 1.83]
	Y = [52.21, 53.12, 54.48, 55.84, 57.20, 58.57, 59.93, 61.29, 63.11,
64.47, 66.28, 68.10, 69.92, 72.19, 74.46]
	a, b = linRegress(X,Y,0.975)
	print "intercept:  mean=%f min=%f max=%f" % (a[0], a[0]-a[1], a[0]+a[1])
	print "slope:  mean=%f min=%f max=%f" % (b[0], b[0]-b[1], b[0]+b[1])
Date: 9 Jun 2010 05:12:33
Message: <4c0f5b01$1@news.povray.org>
Gilles Tran wrote:
> Here it is. Have fun figuring that out.
Heh. On line 300 it says
   ' Holy cow!
So I'm guessing that's a code comment then. I've also just spent 20
minutes sorting out all the indentation so that it's actually possible
to follow the flow control. We'll see if I can deduce anything further...
Subject: Re: Code regression
Date: 9 Jun 2010 05:27:32
Message: <4c0f5e84$1@news.povray.org>
Public Function FACTLN(N)
   Dim A(1 To 100) As Double
   Dim I As Integer
   For I = 1 To 100
     A(I) = -100
   Next I
   If N < 0 Then End
   If N <= 99 Then
     If A(N + 1) < 0 Then A(N + 1) = GAMMALN(N + 1)
     FACTLN = A(N + 1)
   Else
     FACTLN = GAMMALN(N + 1)
   End If
End Function
Uh... anybody want to venture a guess is to how this is different from
   IF N < 0 Then End
End Function
 From what I can tell, it creates an array, initialises it with negative
values, then checks to see if a given cell is negative (which it will
be, 100% of the time), and if so, calculates a value, puts it into the
array, and returns it.
It _looks like_ it's trying to cache previously-computed results. Except
that the array gets recreated each time the function is called. (Unless
I've missed something.) And even if it doesn't, each call to the
function zeros out the whole array anyway! WTF?
Date: 9 Jun 2010 10:54:02
Message: <4c0fab0a$1@news.povray.org>
4c0f5e84$1@news.povray.org...
> I've missed something.) And even if it doesn't, each call to the function
The source is here:
http://books.google.com/books?id=gn_4mpdN9WkC&pg=PA208
It seems to make sense in Fortran 77 (possibly due to the way it handles
arrays?), so I just adapted it to VBA without bothering to streamline it. In
any case it doesn't make much sense in VBA for sure. Perhaps the FACTRL
function can be simplified as well.
When I wrote that, the whole Fisher part seemed to run on pixie dust anyway
and I was in a hurry. It worked, so I didn't change anything for fear of
breaking stuff.
G.
Date: 9 Jun 2010 12:05:28
Message: <4c0fbbc8$1@news.povray.org>
> arrays?),
Due to the statement that says
   data a
That's the fortran equivalent of "static" in C, sort of.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
