POV-Ray : Newsgroups : povray.off-topic : BPM Server Time
14 May 2026 21:46:33 EDT (-0400)
  BPM (Message 58 to 67 of 77)
Subject: Re: New BPM
Date: 10 Jun 2010 04:33:39
Message: <4c10a363$1@news.povray.org>
>> Well just start it at roughly the right time and have the thread loop
>> until it's exactly the correct time.
> I'm not keen on burning shedloads of CPU power just because of a
> deficiency in the thread library. But we'll see...
Well issue a sleep command at the top until you are roughly at the correct
time, then loop until you are exactly there.  You shouldn't be burning more
than 0.1 or 0.2% CPU this way.
Subject: Re: Microcode
Date: 10 Jun 2010 12:00:41
Message: <4c110c29$1@news.povray.org>
Invisible wrote:
> Darren New wrote:
>> Invisible wrote:
>>> Note also that the 6502 doesn't have any microcode.
>> Given how the instruction sets decoded, I'm not sure it's really valid
>> to say it had no microcode.
> And you actually know how it was wired up internally, do you?
Yes. There was a very interesting article on it showing how it worked,
somewhere.  I'll see if I can find it.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 10 Jun 2010 12:16:26
Message: <4c110fda@news.povray.org>
http://www.pagetable.com/?p=39
Actually, I'll grant it's not microcode per se, but it's a table-driven
system with a multiple-cycle-per-instruction clock that steps thru the
table, so now it's an argument more over "what is microcode" than it is over
whether a 6502 has microcode.
I'd say anything that steps thru a ROM with a counter during one instruction
is probably microcode, myself.
Date: 10 Jun 2010 12:17:39
Message: <4c111023$1@news.povray.org>
Invisible wrote:
> I believe the problem is that the library won't let me specify an
> absolute time, only relative times. So if I was "wait 100 ms", but the
> other processing that the program does takes 1 ms, the delay ends up
> being 101 ms, not 100 ms.
Well, yeah.
> Still, since no other API is available, there's not much I can do about
> it. (Other than whinge at the developers and see if it gets fixed in the
> next release of the library...)
No, you do your processing, then you look at the highest resolution clock
you have and figure out how much *longer* you have to wait, then you wait.
Adjusting for the length of time it takes to figure out how much longer you
have to wait.
Date: 10 Jun 2010 13:25:04
Message: <4c111ff0$1@news.povray.org>
...Christ that's complicated! o_O
> over whether a 6502 has microcode.
Yeah, well, that figures. ;-)
> instruction is probably microcode, myself.
Well, a "ROM" can be just a grid of wires, some connected and some not.
http://blog.orphi.me.uk/
Date: 10 Jun 2010 13:25:51
Message: <4c11201f$1@news.povray.org>
>> about it. (Other than whinge at the developers and see if it gets
>> fixed in the next release of the library...)
> clock you have and figure out how much *longer* you have to wait, then
> you wait. Adjusting for the length of time it takes to figure out how
> much longer you have to wait.
Except that figuring out how long you need to wait would *itself* take
time...
Date: 10 Jun 2010 14:39:27
Message: <4c11315f@news.povray.org>
Yes?  I was saying something with a program counter that runs mulitple
instructions per CPU instruction would count as microcode, regardless of how
you stored the code it's running.
Date: 10 Jun 2010 14:39:53
Message: <4c113179$1@news.povray.org>
> time...
You missed the second sentence of the two-sentence paragraph, didn't you?
Date: 10 Jun 2010 15:15:45
Message: <4c1139e1$1@news.povray.org>
> time...
Here's another funny thing:
In CDMA cell phones (at least), not only do they have to figure out how long
they have to wait, they have to keep track of how long different parts of
the chip have been turned on, to compensate for the fact that the crystal
will vibrate at different speeds depending on how warm it is. So if you have
to read two packets before turning off, you have to plan to wake up slightly
later than if you only read one packet before you turned off, because the
chip will be running warmer and faster.
Date: 11 Jun 2010 04:00:19
Message: <4c11ed13$1@news.povray.org>
> how you stored the code it's running.
So if it doesn't use a counter it's not microcode?
As you say, we're just arguing about semantics now. I always thought of
microcode as being a block of ROM (or even some kind of EPROM) which
actual address decode circuitry, so that you can execute jumps and so
forth. By contrast, the CPU I'm designing has no such thing. It's just
that on each clock pulse, a different control line becomes active, and
that line connects to one or more control lines (possibly via logic
gates that pass the signal only if the opcode has certain bits set). I
wouldn't call that microcode; it'd call that "a custom arrangement of
gates".
