![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 6/4/2010 1:22 PM, Orchid XP v8 wrote:
> The thing is, you don't have a transformer like that IN YOUR HOUSE. And
> yet, my dad for some reason DOES have this monster transformer...
I have one about the size that you mentioned. It's a neon sign
transformer that puts out several kilo-volts. I used to have it hooked
up to a rather large Tesla coil. The coil was dismantled many years
ago, but I still held onto the transformer, just in case. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would imagine that to HOLD ON TO a transformer like that would be...
inadvisible. (!)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> hooked up to a rather large Tesla coil. The coil was dismantled many
>> years ago, but I still held onto the transformer, just in case. ;-)
> inadvisible. (!)
Only while there is still some power left in it.
That kind of voltage and current is safe if you respect it. Had a
impromptu band play on campus, where the bass line was a jacob's ladder
sticking out of the back of a microwave. The drum stick was a metal tip
glued on to a good length of acrylic. No Tesla coils, yet.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
People who have moved from 110V countries to 220V ones (or vice versa) often
have a chunky transformer like that so they can run their old equipment.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> ... although I also found ... a small bottle of white powder marked
> "KNO3"...
A little charcoal and sulfur and *you* *are* *in* *business* *!*
> Some capacitors are small brown things like little chocolate buttons.
> (But significantly less tasty.) Then there's the "electrolytic" ones,
> which are small blue things that look like they belong in a licorish
> all-sorts bag. Some a really small (about 5mm diammeter). Some are a bit
> bigger (15 mm diammeter).
> When I was in my dad's loft, I found capacitors the size of friggin'
> soda cans! o_O WTF are *those* for??
> (I mean, are they that size because they have a higher capacitance or
> something? I gather a capacitor is one of the few components where the
> physical size of the device determines its electronic characteristics...)
A capacitor consists of a piece of electrolytic material sandwiched
between two conducting plates. The capacitance is proportional to the
area of the plates, is inversely proportional to the distance between
the plates, and is factored by the capacitance of the electrolytic
material between the plates. To get up to where capacitance is measures
in farads (instead of microfarads), you need large plates, the thinnest
possible spacing between them, and the best material to go between (as
to which material is the best, I am not in the know). The most reliable
manufacturing technique is to take a thin layer of flexible electrolyte,
plate it with metal on both sides, insulate one of the two sides, and
roll the plates up so that they take less room.
If they're old components, it may be that manufacturing techniques
didn't allow the two plates of the cap to be closer together. To make
up for a lack of precision, you have to increase the area of the plates.
It all comes down to how thin the electrolyte can be and still
physically separate the two plates (because if the plates make
electrical contact, the cap becomes a wire).
> We also found a box containing more 14-pin DIL sockets then it is
> humanly normal to have. And a bunch of 7400-series chips. In particular,
> these are the original, obsolete, 7400 chips. 7400, 7408, 7402, etc. Not
> 74LS00 or even 74S00, but vanilla 7400 TTL. They're that old.
> We also found a stack of unopened boxes containing LEDs. Now when I was
> at Maplin I bought a bag of mixed LEDs - which is great, because you get
> a lot of LEDs for not much money, but OTOH they're all different. Now I
> have a matching set!
Good. Now you should be able to build a small, functioning processor.
With pretty lights to show the data states.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> "KNO3"...
And why did you *think* my dad had this? ;-)
>> particular, these are the original, obsolete, 7400 chips. 7400, 7408,
>> 7402, etc. Not 74LS00 or even 74S00, but vanilla 7400 TTL. They're
>> that old.
>> was at Maplin I bought a bag of mixed LEDs - which is great, because
>> you get a lot of LEDs for not much money, but OTOH they're all
>> different. Now I have a matching set!
Negative.
I tried to solder the LEDs to a board, but for reasons beyond my
comprehension, there's a short-circuit somewhere. I've checks and
re-checked the board. I can't see the short. But there is one.
I think I need to go buy some solder that isn't 30 years old...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You know... a $15 multimeter with a continuity tester ....
Heh. I proudly proclaimed to my dad that I just repaired my USB
thumbdrive's connector all by myself.
His first response was "Does it still work?"
It does! Hehe.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have one. That's how I know there's a short circuit. I just can't
figure out *why*.
When I was soldering one of the components, the solder spilt onto the
adjacent track. I've tried to fix at a dozen times now, but I'm still
getting continuity somehow...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Do you have some copper braid or a solder pump? that should clean it off.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There was a blob of solder between the tracks. So, as per the
instructions in my trusty old electronics book, I ran the point of the
iron down the groove between the tracks.
In three cases, this fixed the problem. In the forth case, a short
circuit still exists somehow.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
