POV-Ray : Newsgroups : povray.off-topic : Electronics research Server Time
15 May 2026 00:23:24 EDT (-0400)
  Electronics research (Message 31 to 40 of 104)
Subject: Re: Electronics research
Date: 19 May 2010 13:09:18
Message: <4bf41b3e$1@news.povray.org>
Darren New wrote:
> Cute. Is there a name for when you have a red LED in one direction and a
> green LED in the other and you use AC to make it yellow? I want to use
> that around my colleges and sound like I know what I'm talking about. ;-)
Most people call that a tri-colour LED - but sometimes that term is used
to refer to an LED with three different-coloured dies inside it (and
hence 3 pins). Which is obviously a different component.
http://blog.orphi.me.uk/
Date: 19 May 2010 13:14:08
Message: <4bf41c60@news.povray.org>
scott wrote:
>> I always thought of it as logic high meaning "connected to the +V
>> rail" and logic low meaning "not connected to anything".
> Logic "high" and "low" are just names given to a certain agreed range of
> voltages.  The difference between "not connected to anything" (floating)
> and "logic low" is very important when working with data busses.  If you
> have several devices all with their outputs connected to a data bus,
> then only one device at a time must be driving the data lines to logic
> low/high, the rest must set their outputs to floating.
OK, so if I'm understanding this right... The 74126 (go look it up)
contains 4 "buffers" - gates who's output is logically equal to their
input. But each gate also has an "enable" pin. When the enable pin is
high, the gate works like normal. When the enable pin goes low, it's
like the output pin isn't connected to anything any more.
And it seems that this allows you to connect several outputs together,
forming a kind of wired-OR configuration, provided that at all times
only one gate is "enabled".
Is that right?
Date: 19 May 2010 13:16:58
Message: <4bf41d0a$1@news.povray.org>
Am 19.05.2010 16:16, schrieb Invisible:
> While we're here, does anybody comprehend what VCC, VSS, VDD and related
> symbols mean?
According to JEDEC,
VBB = substrate power voltage (bias voltage), a voltage < VSS/GND.
VCC = logic power voltage, serving as a reference for high signal levels
(often sharing a common rail with VDD, in which case they may be used
interchangeably).
VCCQ = output stage logic power voltage, separate (positive) power rail
to drive output loads.
VDD = drain power voltage. separate (positive) power rail to drive the
chip's internals.
VDDQ = output stage drain power voltage. Effectively the same as VCCQ.
VEE = emitter power voltage. Only used for ECL devices.
VHH = special function enable voltage. An extra-high voltage to enable
certain special functions of a device.
VPP = programming voltage. An extra-high voltage to supply the power for
the programming function of a device (e.g. EPROM)
VREF = reference power supply, serving as a special reference voltage,
e.g. for ADC inputs.
VSS = GND = ground reference / source power voltage, serving as both
(negative) power rail and low signal level reference.
VSSQ = GNDQ = output stage source power voltage / ground reference,
serving as both a (negative) power rail and low signal level reference
specifically for output signals (should always be at the same level as
VSS=GND).
(This is just a subset of all the symbols used; for instance,
digital/analog devices such as programmable amplifiers or ADCs/DACs
often use separate voltage rails for the analog signals.)
Date: 19 May 2010 13:22:29
Message: <4bf41e55@news.povray.org>
clipka wrote:
> According to JEDEC,
> interchangeably).
> chip's internals.
> VSS=GND).
Suddenly the picture becomes even more complex than you feared...
Thank god I don't have to deal with anything analogue yet! ;-)
Date: 19 May 2010 14:45:54
Message: <4bf431e2$1@news.povray.org>
I spent hours trying to figure out why an op-amp wouldn't give me the
output I was expecting. It finally clicked when I read the warning on
the data sheet that pulling an input within 0.5v of V- would cause it to
latch-up and force the output to near V+ no matter the state of the
inputs. I went through a few chips thinking they were defective.... or
that I toasted one (got V+ and V- reversed, which is apparently bad for
op-amps...)
~Mike
Date: 19 May 2010 15:38:25
Message: <4bf43e31$1@news.povray.org>
>> Yes, that's the other fun thing. Depending on which type of gates
>> you're using, they supply about 20 mA. But some of the LEDs I'm
>> looking it draw 40 mA...
> What you mean is, they draw *up to* 40 mA?  How much they actually draw
> depends on what value series resistor you put in there.  Using Ohm's law
> and the V-I curve of the LED from the datasheet you can work out exactly
> what resistor size you need for a given current.
See for yourself:
http://www.maplin.co.uk/Module.aspx?ModuleNo=35702
"Forward current: 25 mA"
If you can figure out what the hell that means, be my guest...
Date: 19 May 2010 16:36:51
Message: <4BF44BE6.5010501@gmail.com>
On 19-5-2010 13:07, Invisible wrote:
> Ah yes. That's the fun thing about doing digital electronics. You can't
> just *buy* a 7400. No, you have to decide whether you want a 74LS00 or a
> 74HC00 or a 74HCT00 or...
> Reading the datasheets is like walking into another world. (Especially
> since the datasheets are usually poorly-scanned grainy PDFs that don't
> match the part number you actually asked about!)
> However, I just found the following pages:
> http://www.kpsec.freeuk.com/components/ic.htm#logic
> http://www.kpsec.freeuk.com/components/74series.htm
> http://www.kpsec.freeuk.com/components/cmos.htm
> Suddenly everything seems so much clearer. For example...
> "74LS series: Inputs 'float' high to logic 1 if unconnected."
> Oh crap. Well that would explain a thing or two! >_<
> (I foolishly assumed that being unconnected would register as 0V - i.e.,
> logic 0. Damn, this is going to make interactive testing *so* much harder!)
> Also, it's nice to have some indication of the power requirements,
> switching frequencies, and what the hell all the letter codes mean!
I think I resist any urge to comment on this. Other than "RTFM" and "buy
any 'electronics for dummies book'" before embarking on such a project.
Date: 19 May 2010 16:59:33
Message: <4bf45135$1@news.povray.org>
I don't think electricity comes with a manual. Neither do ICs, usually...
> and "buy
Hey, what do you *think* I've got a dad for? ;-)
Date: 19 May 2010 17:31:59
Message: <4BF458D2.9050601@gmail.com>
They do, they are called datasheets.
>> and "buy any 'electronics for dummies book'" before embarking on such
>> a project.
Hard to say, other than the obvious task of a father ;) . But I guess
you mean that he is the actual dummy that didn't know that a floating
input is seen as a '1'?
Have you ever looked at e.g.
http://en.wikipedia.org/wiki/File:TTL_npn_nand.svg ?
Date: 19 May 2010 23:41:53
Message: <4bf4af81$1@news.povray.org>
On Wed, 19 May 2010 20:38:21 +0100, Orchid XP v8 wrote:
> See for yourself:
http://wiki.answers.com/Q/What_is_forward_current
