POV-Ray : Newsgroups : povray.off-topic : Prehistoric dust Server Time
2 Jul 2026 17:24:17 EDT (-0400)
  Prehistoric dust (Message 56 to 65 of 145)
Subject: Re: Dusty
Date: 18 May 2010 15:20:03
Message: <4BF2E866.9090900@gmail.com>
On 18-5-2010 12:56, Invisible wrote:
> I had always assumed that the first computers were like current
> computers, just using relays or whatever instead of transisters, and
> with vastly inferior specifications.
> However, it appears that this isn't the case.
> For example, I thought they all used latch circuits for memory, but
> apparently not. There were things like core memory, which I'd never
> heard of. Presumably it's faster and cheaper to make core memory as
> opposed to wiring up thousands of latch circuits?
> Another example. According to legend, there was a time when if you
> wanted to run a program, you used a machine not unlike a typewriter to
> punch holes into a card. You "type in" the program onto punch cards like
> this, and only once the entire program and all its data has been punched
> do you even go near the actual *computer*. You feed the cards into a
> reader. It reads them all, and then spends the next six months running
> the program. Finally, you get a stack of new punched cards representing
> the results.
> Does anybody know approximately when this time was?
1980, except that it was the next day and not six months later.
> For that matter, does anybody have a broad timeline of when various
> technologies were in use? What are the dates for things like core
> memory, drum memory, punch cards, magnetic tape, relays, vacuum tubes,
> transistors, ICs, etc?
There is probably a wikipedia page about that, have fun searching.
> Was there ever a time when programs were entered into memory via
> switches rather than some other medium?
Yes. Use a hex pad like scott myself in 1984 and had a friend who had
build his own computer and booted it by manually starting the booting
process using a row of binary toggle switches.
New programs were enetered the same way.
> Was there ever a "punched tape" medium similar to punch cards?
Yes. E.g used for boot loading the machine in my former department until
1987 or so.
> Similarly, you hear people talk about the VAX, the PDP, the varouis IBM
> mainframes and Cray supercomputers. Does anybody know the timeline for
> these, the technologies used and the basic design and performance details?
Wikipedia again I assume
(Some answers on http://www.computerhistory.org/timeline/?category=cmptr)
> (Sure, you can look up individual questions on Wikipedia, but the
> articles tend to contain huge amounts of minute detail about specific
> things. I'm trying to get a general overview of an entire era.)
The page you are looking for must be there also.
Subject: Re: Dusty
Date: 18 May 2010 15:30:00
Message: <web.4bf2ea0fecb621efaba2b8dc0@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> >>>> It still somewhat blows my mind that you could do anything useful with
> >>>> so little memory. Presumably for processing large datasets, most of
> >>>> the data at any one time would be in secondary storage?
> >>> Large datasets then were also very tiny compared to large datasets of
> >>> today. :)
> >> Sure. But 1MB is such a tiny amount of memory, it could only hold a few
> >> thousand records (depending on their size). It would almost be faster to
> >> process them by hand then go to all the trouble of punching cards and
> >> feeding them through a computer. So it must have been possible to
> >> process larger datasets than that somehow.
> > You never read the entire dataset into memory. You process it a record at a
> > time.
> Right. That's what I figured.
> > The only limit on file size is the media, not memory.  There is no difference in
> > memory consumption between processing 10 records or 10 million records.
> If you're trying to, say, sort data into ascending order, how do you do
> that? A bubble sort? (Requires two records in memory at once - but, more
> importantly, requires rewritable secondary storage.)
Right, you read as many records in as you have memory for, and use rewritable
secondary storage for work files.  Preferably disk, but if your not in a hurry
mag tape will work.  When VIPs would come around for a tour of our datacenter,
we would always start up a sort using tape for work files.  It was fun to watch
the sort program read, read backwards, rewind, and forward space the tapes.
Slow but fun to watch.
> http://blog.orphi.me.uk/
> http://www.zazzle.com/MathematicalOrchid*
Isaac
Subject: Re: Prehistoric dust
Date: 18 May 2010 15:33:37
Message: <4bf2eb91@news.povray.org>
> >>>>>   There were no children many hundred billion years ago.
> >>>> I was waiting for that one... *sigh*
> >>>   It's a so-called mathematician's answer.
> >> Technically, 1 hundred billion years is about 7.3 times the estimated
> >> age of the universe
> >   Depends on whether you are using American billions or European billions.
> NAAAAAARGH!! >_<
> I never did like Americans... (Then again, they probably don't like me
> either.)
  Then why are you using the American billion above?
Subject: Re: Dusty
Date: 18 May 2010 15:45:18
Message: <4bf2ee4e$1@news.povray.org>
On 18/05/2010 7:20 PM, Clarence1898 wrote:
> Stephen<mca### [at] aolDOTcom>  wrote:
>> On 18/05/2010 4:44 PM, Invisible wrote:
>>>> As I recall about 60 characters per second.  The tape was paper, was 8
>>>> holes
>>>> wide, and easily broken or scrunched.
>>> Mmm, that's fairly fast for an optical system.
>> Was it optical? I seem to remember it was mechanical with spring loaded
>> teeth.
>> Best Regards,
>>   Stephen
> I was thinking it was optical.  I don't ever remember having maintenance on the
> read head.
and down. Of course the high speed tape readers must have been optical.
> But that's been over 35 years ago. Now I sometimes have a hard time
> remembering what I had for breakfast.
I get round that problem by having the same thing every day. ;-)
Best Regards,
Subject: Re: Dusty
Date: 18 May 2010 15:51:32
Message: <4bf2efc4$1@news.povray.org>
>> Yes. That's why DEL is up at 127. Think about it.
> Oh... oh dear god. You *are* kidding me, right??
He is not. It the smart thing to do. Is it not?
Oh! on second thoughts you could glue the chad back into the holes. :-P
Best Regards,
Subject: Re: Dusty
Date: 18 May 2010 16:22:52
Message: <4bf2f71c$1@news.povray.org>
Orchid XP v8 wrote:
> It still slightly frightens me that Haskell is actually this old... Just
> think how much better the world could be today if its ideas had caught
> on back then?
A lot of the stuff you take for granted wasn't possible back then.
It's like "how much cooler would movies be if the ideas behind modern GPUs
caught on back when we were still using discrete transistors and core memory?"
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Subject: Re: Dusty
Date: 18 May 2010 16:26:04
Message: <4bf2f7dc$1@news.povray.org>
Orchid XP v8 wrote:
> Files only on disk? Or on tape too?
Obviously tape files were contiguous.  I must be misunderstanding what
you're asking.
>>> Interesting. So the system actually "knows" where each field of a
>>> record is then?
>> Records were fixed size, so it was trivial to calculate.
> OK. But does the system know where the *fields* in a record are? Or just
> what size the records are?
You compiled it into the program. Often when they weren't actually fixed
size, they were fixed size anyway and padded (like cards).  Or the size was
stored in the header of the file.
> Yeah, I think the term "mainframe" is probably obsolete now. There are
> probably more exact ways to describe what type of computer you mean.
Could be.  There's something clearly between "small" and "large" now.
Subject: Re: Dusty
Date: 18 May 2010 16:27:14
Message: <4bf2f822$1@news.povray.org>
Clarence1898 wrote:
> You can run Linux on an IBM z/series machine, just like on a PC.
Actually, last I read, you could run some 300 Linux VMs on a z/series
machine without noticing a slow-down. :-)
Subject: Re: Dusty
Date: 18 May 2010 16:28:28
Message: <4bf2f86c$1@news.povray.org>
Orchid XP v8 wrote:
> So it must have been possible to process larger datasets than that somehow.
http://en.wikipedia.org/wiki/External_sorting
Subject: Re: Dusty
Date: 18 May 2010 16:31:09
Message: <4bf2f90d@news.povray.org>
To be clear, they pretty much stopped making that sort of machine in the
late 70s, but many of them lasted into the 90s before they ahd to be
retired, often for lack of parts.
