POV-Ray : Newsgroups : povray.off-topic : Prehistoric dust Server Time
2 Jul 2026 02:38:00 EDT (-0400)
  Prehistoric dust (Message 21 to 30 of 145)
Subject: Re: Dusty
Date: 18 May 2010 10:58:08
Message: <4bf2ab00$1@news.povray.org>
>> We added 1MB of memory to an IBM 370/168 in the mid 70s.  Price? $50000.
> Ouch! o_O
> It still somewhat blows my mind that you could do anything useful with so
> little memory.
You could do useful stuff with *far* less.
> Wow. I had no idea it persisted that long. In the mid 1980s, I had a C64
> to play with, which stored data on audio tape - for more data than any
> stack of punch cards. And I don't think the C64 was even particularly
> expensive... (I know of a few people who actually used the C64 for work
> purposes, would you believe.)
I can remember when I was younger (mid 80s) my dad writing a program to
simulate the 2D flow of cylindrical shaped objects into different shaped
channels (with graphics) - that was with 32K of RAM.  Useful work (even if
it took about 10 seconds to eventually figure out where each one went!), and
I'm sure there are loads more examples of doing useful stuff with just a few
KB of RAM.
Subject: Re: Prehistoric dust
Date: 18 May 2010 11:14:14
Message: <4bf2aec6@news.povray.org>
On Mon, 17 May 2010 16:08:29 -0500, Mike Raiford wrote:
> On 5/17/2010 2:54 PM, Orchid XP v8 wrote:
>> Was anybody actually there? Did any of you guys see this happen? What
>> was it like? And did mainframes really come in bright orange cases with
>> inch-square glowy buttons on the front that randomly twinkle?
> ;) I remember as a kid in the 80's walking into an office that had a
> computer room. A real-life room-sized mainframe. One wall had a bank of
> tape machines, the CPU was a box the size of a Smart car sort of in the
> middle of the room, and there was a huge array of disks that took up the
> rest of the room.
> All controlled by a tiny terminal in the corner flanked by an 8" floppy
> drive, and a few other binders and such.
> It was quite neat to see!
My university had an IBM 4361 mainframe (IIRC), and I can remember in 6th
grade going to a class where I got to play in the server room with some
PDP mainframes (I helped with the backups one day).
My first job out of college had a fairly large AS/400 system (D40?  I
think) and an IBM System/34.
The S/34 didn't have very many lights on it, but the AS/400 lit up light
a Christmas tree when we turned the lights off in the bunker that was our
computer room.
Jim
Subject: Re: Dusty
Date: 18 May 2010 11:25:01
Message: <web.4bf2b072ecb621efaba2b8dc0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> How about drum memory? Or the various delay lines?
Don't know, was before my time.
> As in, whole memory chunks on a single IC? Or just two latches per IC?
> Or...?
I don't know very much about the actual electronics. You will have to go to
google or wikipedia for that info.  I remember the 3081 had what were called
TCMs.  Fully encased, water cooled modules with about a thousand pins on the
back.  The CEs had lots of fun replacing them without bending a pin in the
process.
> so little memory. Presumably for processing large datasets, most of the
> data at any one time would be in secondary storage?
Most really large files were on tape, you just read the data serially.
For highly accessed files, or files that needed random access were kept on disk.
> Heh, sounds line fun. According to the account I just read, you actually
> put one statement per punch card. Is that right? I always assumed that
> each card just held X characters of data, and you type until the card is
> full, then move to the next one. I didn't realise there was an actual
> "significance" to card bounderies. Or is that just for the benefit of
> the humans?
The file system for IBM mainframes are record oriented, not stream.
Files are created with a defined record format and record length.
There is no end of record indicator such as CR or LF as in PC files.
Since cards were 80 columns long, many source files today are also 80 byte
records.  The norm was for program source files was column 1 to 72 was data
and column 73 to 80 was sequence numbers. For most COBOL programs the sequence
numbers were in cols 1 to 6.
> What sort of access speeds do you get for reading or writing punched
> card or tape?
As I recall about 60 characters per second.  The tape was paper, was 8 holes
wide, and easily broken or scrunched.
> As in, discrete transistors on PCBs?
Again, I don't know much about the electronic packaging.
> Any ideas on typical memory capacity / clock speed? Data path widths?
On some of the older machines I worked with:
  360/50 128KB
  370/158 1MB
  370/168 3MB
  3033U 4MB
  3081Q 8MB
On the latest machine:
  z/9 BC S03 - 16GB
> Nice consistent naming scheme. Heh. :-/
You can always depend on IBM to be consistent.
> Now if I could figure out what a typical MIPS rating for a normal PC
> today is, I'd have something dissimilar to compare it to. :-}
It is rather difficult to compare since they have such different architectures.
I doubt that the internal processor speed is that much different than current
PCs, but the i/o bandwidth is much higher in the mainframe.
For example our two machines, which are on the small side for mainframes, are
connected to a disk storage unit containing 15TB of data.  There are 4 high
speed fiber optic channels from each processor to this unit. We can easily
sustain i/o rates of over 10000 i/o operations per second, with peaks in the
20000 to 40000 range.  It is very rare for any single job to saturate the cpu.
By running many jobs concurrently we make full use of the machine.  If I could
port POVRAY to our mainframe, I'm sure it would be slower than most current PCs.
 But cpu intensive work is not what the mainframe does best.
Isaac
Date: 18 May 2010 11:25:44
Message: <4bf2b178@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Many hundred billion years ago, there existed a bizzare world that most
> of us have only read about in books. Plastics did not yet exist, so
> small children's toys were made of wood or metal, because there was
> literally nothing cheaper.
  There were no children many hundred billion years ago.
Date: 18 May 2010 11:36:35
Message: <4bf2b403$1@news.povray.org>
I was waiting for that one... *sigh*
Subject: Re: Dusty
Date: 18 May 2010 11:44:01
Message: <4bf2b5c1@news.povray.org>
OK. So care is newer than either of those.
OK.
So the concept of a filesystem storing named files already existed at
this time?
Interesting. So the system actually "knows" where each field of a record
is then?
>> card or tape?
Mmm, that's fairly fast for an optical system.
>   360/50 128KB
>   370/158 1MB
>   370/168 3MB
>   3033U 4MB
>   3081Q 8MB
>   z/9 BC S03 - 16GB
I should probably go plot that on a graph against date or something... ;-)
Consistently inconsisten. ;-)
Still, some things never change:
   nVidia GeForce 8xxx
   nVidia GeForce 9xxx
   nVidia GeForce 2xx   <- WTH?
Yes, that's what I meant by "dissimilar comparison". It all rather
depends on how many registers you have, how wide the various data busses
are, what operations you can perform in hardware (e.g., is
multiplication a hardware or software operation?), and so forth.
Really? I didn't think anybody had mainframes any more... just big
server farms.
Sounds expensive.
The *original* purpose of multitasking operating systems. ;-)
> If I could
Out of curiosity, what *do* you use it for?
Subject: Re: Dusty
Date: 18 May 2010 12:10:00
Message: <web.4bf2bb37ecb621efaba2b8dc0@news.povray.org>
> this time?
Yes, its been around long before I got into this business.
> Sounds expensive.
Its not cheap.  But for the volume of data we process, its not that much more
expensive than a server farm
All company information is kept on mainframe disks and maintained by mainframe
programs.  All customer information, product information, personnel information,
sales information etc.  This company started in the early 1900s selling its
merchandise from a store.  Then expanding sales to mail order catalog, then via
telemarketing, and now by internet.  The web front-end is handled by a small
server farm, but all back-end work is done on our mainframe.
Isaac
Subject: Re: Dusty
Date: 18 May 2010 12:24:28
Message: <4bf2bf3c$1@news.povray.org>
Invisible wrote:
> Does anybody know approximately when this time was?
1970's. By about 1980 most of those machines were likely retired.
> For that matter, does anybody have a broad timeline of when various
> technologies were in use? What are the dates for things like core
> memory, drum memory, punch cards, magnetic tape, relays, vacuum tubes,
> transistors, ICs, etc?
Yes. Google.
> Was there ever a time when programs were entered into memory via
> switches rather than some other medium?
Yes.
http://en.wikipedia.org/wiki/Front_panel
The first personal computers worked that way.
http://en.wikipedia.org/wiki/Altair_8800
> Was there ever a "punched tape" medium similar to punch cards?
Yes. That's why DEL is up at 127. Think about it.
> Similarly, you hear people talk about the VAX, the PDP, the varouis IBM
> mainframes and Cray supercomputers. Does anybody know the timeline for
> these, the technologies used and the basic design and performance details?
http://en.wikipedia.org/wiki/Computer_history
> (Sure, you can look up individual questions on Wikipedia, but the
> articles tend to contain huge amounts of minute detail about specific
> things. I'm trying to get a general overview of an entire era.)
So you want someone else to read the 10 pages and summarize it into 10 lines
for you?  You need a job in management.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Subject: Re: Dusty
Date: 18 May 2010 12:28:37
Message: <4bf2c035$1@news.povray.org>
>> Ouch! o_O
>> so little memory.
We ran an entire school district on 32K of RAM and 16M of online disk.
Core memory, so cycle time close to a milisecond, let alone nanosecond.
Date: 18 May 2010 12:30:43
Message: <4bf2c0b3@news.povray.org>
  It's a so-called mathematician's answer.
