On Mon, 17 May 2010 20:37:18 +0100, Orchid XP v8 wrote:
> I haven't seen anything else that does that.
IPX/SPX did that. DECNET, AFAIK, did that.
Jim
On Mon, 17 May 2010 12:15:13 -0700, Darren New wrote:
> Jim Henderson wrote:
>> What do you mean by "2-way broadcast"?
> Well, FM radio would be a one-way broadcast. Coax ethernet would be a
> two-way broadcast.
OIC what you're saying, that the filtering is applied by the receiving
end (either filtered by software or hardware).
>> Yes, but from a standpoint of multicast, there again, you get some
>> savings (and increased scalability). I imagine (but don't know for
>> sure) that cable uses some sort of multicast scheme
> Well, look, there really isn't something that's a multicast physical
> layer.
Maybe Sirius radio? Dunno, you might be right on that.
> Either the bandwidth is scaled per user, or it isn't. If we're
> all talking at the same frequency on a coax cable (say like old
> ethernet) and I'm transmiting, it's a broadcast, regardless of the
> destination address.
> AFAIK, cable systems run fiber to a box in each neighborhood, and then
> have a tree of cables coming out from there, all carrying the same
> signal.
Would have to find someone who works for a cableco to confirm,
obviously. (Or a good article describing the technology)
>> all people who are watching channel 657 are likely part of a multicast
>> group of some sort,
> Sure. And all people watching channel 657 are also receiving channel
> 652. They're just not tuning it. Just like FM radio. (And I was talking
> about IP over cable, actually, not TV per se. :-)
That implies a pretty enormous total bandwidth on the coax cable coming
into your house, then. If you figure 40 SD channels and 40 HD channels,
for example, that several megabits of digital broadcast being sent out to
be filtered.
I was using cable TV as an example because it's data being sent over a
network. Data is data is data is data, after all. :-)
Jim
>> I was simply pointing out that multicast (in particular) isn't
>> necessarily point-to-point from an IP standpoint.
> Sure. And it's not point-to-point from an ISDN or even POTS perspective
> either. Dialing into a conference bridge is the equivalent of putting
> the destination address as the multicast address in IP. It's lower-layer
> technology that actually does the multicasting, not IP itself.
Arguably, it would be a technology - not a protocol - implementation.
>>>>> You need to duplicate the packets at least once per physical wire.
>>>>> Same as any network. IP doesn't force you to duplicate anything
>>>>> less.
>>>> True.
>>> That's my point. IP is still point-to-point, by necessity, when you
>>> don't have a broadcast network.
>> This is where I think you're talking at the physical or network layer,
>> not the transport layer.
> The transport layer isn't involved in multicast in IP, per se. Multicast
> transport layer is just UDP. The messages maintaining the spanning three
> modify things in the network layer.
I may need to read more on this.
>> and the network hardware understands which ports to send the multicast
>> data to,
> Then it's not broadcast, and the switch is duplicating the data once for
> each subscriber. That's what I'm saying. *If* there's any bandwidth
> savings (i.e., more than one NIC reads the same packet), it's because
> every NIC in the broadcast area is reading the same packet and some of
> them are throwing it away.
But that isn't the case, necessarily. The switch is allowing the packet
to get to those subscribers who've requested it. Whether that's
duplication or filtering is really just semantics.
>>> The ISDN router (known
>>> as the conference bridge) is doing the duplication, just like in IP.
>> Depends on whether you're talking unicast to *each* destination node or
>> multicast IP. Therein lies the difference (and the bandwidth savings).
>> In a multicast scenario, at the transport layer, the switch isn't
>> "duplicating" the packet, it's forwarding it (which may be a semantic
>> debate).
> It's duplicating it for each outward link the packet goes over. If you
> have a router with someone upstream sending a multicast session and
> three routers downstream receiving it, how much bandwidth, total, is
> that taking up?
That depends on a lot of different factors. If there's 10 stations at
the far end of the third router hop, the amount of bandwidth between
routers is still a constant 1:1; the initial sender isn't sending the
data 10 times, it's sending it once - and that doesn't matter if there's
10 targets at the end of the 3rd router, or 10 at the end of router 3, 50
between router 2&3, and 100 between router 1&2.
>>>> the switches also typically have logic so they don't have to fill
>>>> their buffers with multiple copies of the same data (for those that
>>>> have a buffer).
>>> True, but now we're talking about something far below the level of IP.
>> Not in a Layer3 switch we're not. ;-)
> I'm pretty sure IP says nothing about how you implement copying a packet
> from one NIC to another. :-)
That's because the switch provides the implementation details; the
protocol doesn't implement itself.
>> Yes, physical layer (or network layer), not transport layer. It feels
>> like you're conflating the two.
> No. I'm pointing out that talking about the bandwidth savings, or "point
> to point" ness of IP implicitly is talking about the network and
> physical layers. Multicast *is* point to point, *unless* you're on a
> physical broadcast network. Multicast is point-to-point between any two
> elements of the network where there's a non-broadcast cable between
> them.
I think that made sense to me.
>>> The only place that multicast saves bandwidth is on a unicast network
>>> (like between routers) where nobody downstream of the receiver wants
>>> to receive the data. If you have a separate wire to each PC with
>>> bandwidth dedicated to that PC, multicast is 1:1 on any given segment
>>> of the network.
>> The destination "1" is a single multicast address that the specific
>> targets subscribe to - that's what makes it not 1:1, but 1:many.
> Yes. And 858-102-1137 is a single multicast address that hosts a
> conference bridge. Is that not 1:many, if many phones call into that
> address?
It is, sure. Each phone is a "subscriber" to the bridge. The "data"
isn't sent to phones that aren't subscribers.
>> There again, though, mixing up physical/network layer with transport
>> layer.
> Only because I'm trying to understand in what possible sense IP is
> 1:many and ISDN isn't. Sure, if a conference bridge is 1:many then so is
> an IP multicast. But I don't think you can say an IP multicast is 1:many
> and an ISDN conference bridge is 1:1, because it's doing the identical
> thing in the identical way.
I don't think I was saying that. I haven't commented on ISDN, only on IP
multicast.
>>> Yes, the kind that carry IP via broadcast. Something like IP over CDMA
>>> or GSM is much closer to having a wired connection than a broadcast
>>> connection, since nearby nodes aren't listening to you.
>> Well, if it's DSS then that's true, but otherwise, the other nodes can
>> cause interference with you, so if they're doing CSMA-CD, then they are
>> listening to you, if only to see if the channel is clear to transmit.
> I said CDMA, not CSMA. I'm not sure what DSS is here, but in CDMA
> everyone talks at the same time, and in GSM (afaik) nobody talks at the
> same time, so there's no interference (of the type we're talking about)
> in either one.
Oh, right, I missed that (I'm used to talking strictly in terms of CSMA).
>> Not with multicast IP; again, if you don't subscribe to it, you don't
>> receive it, at least that's my understanding (http://
>> www.multicasttech.com/faq/ provides a good explanation).
> If you're on a broadcast network, you have no choice but to receive it.
True, because you see everything, addressed to your or not. That's why
hubs are used for sniffing, generally.
> If you're on a network where each connection is 1:1, then it's the same
> as an ISDN conference bridge.
I think that's a matter of semantics.
>>> However, I strongly suspect that none of this discussion has anything
>>> to do with whatever Andrew meant when he said IP isn't 1:1 like ISDN
>>> is.
>> Well, quite possibly, unless he was talking about multicast as a
>> reason.
> I don't think so...
In which case the discussion has been an 'evolution'. ;-)
Jim
>> two-way broadcast.
Right.
>> layer.
Different frequencies, sure. I'd more likely call that lots of independent
networks.
Yeah.
>>> group of some sort,
> be filtered.
Yep. A cable can carry huge amounts of data, depending on its length. The
closer the fiber hubs out to the houses, the more channels you can carry.
Exactly.
Ada - the programming language trying to avoid
you literally shooting yourself in the foot.
>>> Depends on how the router implements forwarding for multicast
>> Or, to phrase it differently, multicast is somewhat more point-to-point
>> than a telephone party line is.
> Not really, a party line is many-to-many, but multicast is one-to-many.
Nope. If you're on a party line and I'm not, and I call you, I have one
person on my end and you have every party on your end. Exactly like going
thru a router with one connection that's CAT5 and the other connection
that's coax ethernet. If you connect two party lines thru the switch, then
anyone on either side can hear everyone, just like having a switch with two
ports and a broadcast network on each side.
Orchid XP v8 wrote:
> Interesting. Because from what I've seen, all the earlier technologies
> allow you to connect together maybe a few dozen nodes, and then stop
> working after you try to scale much beyond that.
Um, you *are* aware that we had a global telephone network *before* we had
computers, right?
> They all use their own
> perculiar addressing scheme, and there's no way of referring to a node
> that isn't on the local network.
Tell me. When you (or your boss) needs to talk to someone in America, how
do they do it? What steps do they follow?
> To me, it seems that the major contribution of IP is that it gives you
> an addressing system which is independent of the underlying transport
> technology, and has routable addresses (and definite rules for how to
> use them). I haven't seen anything else that does that.
You ... haven't picked up a phone lately?
> Oh, and then people whine that it doesn't map cleanly to the ISO/OSI
> 7-layer model. Oh well...
Exactly. It doesn't map cleanly to the global network that was already
around for decades before IP was even conceived. It is difficult to manage
and debug and route compared to the world-wide telephone network everyone
takes for granted. And they're running out of addresses (actually, probably
already ran out of addresses) long before every person has an address, let
alone every piece of communications equipment.
Yeah, basically.
Yep. There's (IIRC) ICMP messages to control the routing (via expressing
interest), and just UDP with multicast destination addresses to deliver the
data.
Sure. As is "1:1" vs "1:many" when every pair of receivers had an
independent connection, which was my point. :-)
Yep. And if there's 10 people on the conference call, my phone is only
sending my voice once. I completely agree with you. I'm simply stating that
ISDN and all those other network technologies work the same way, so IP
multicast isn't a distinguishing feature.
Hmmm. You seem to be disagreeing with yourself. Unless you were joking and
saying a layer 3 switch is only a little below IP and not far below.
That's all I've been trying to express. IP multicast is equivalent to ISDN
conference bridge, where the bridge serves as the router doing the routing
to multiple outgoing segments.
>> address?
OK. That was what I was trying to express. Saying IP multicast is 1:many and
ISDN conference bridge isn't is not a reasonable comparison.
> multicast.
Fair enough. That's where this came up, and why I'm talking about layers
below IP. Otherwise, I think we both understand how IP handles multicast.
Exactly my point. That's why I said multicast in that case doesn't "save"
bandwidth.
>>> reason.
>> I don't think so...
From his other message, I think he doesn't realize that an ISDN connection
has an address at all, or something.
Then you get a busy signal. ;-)
Jim
> "save" bandwidth.
Bottom line, we're both in violent agreement again without realising
it. ;-)
Jim
> The closer the fiber hubs out to the houses, the more channels you can
> carry.
It's not just a function of the cable length, though; encoding the data,
attenuation, other forms of interference, etc - but that's all outside
the scope of discussion. :-)
Jim
Are you allowed to use real life examples, here?
Do you still have party lines in 2010?
Best Regards,
> had computers, right?
And, for the 17th time, you *are* aware that I'm talking about earlier
_computer_ network technologies, right?
My point, which you seem determined to ignore, is that everybody who
designed a way to connect computers together designed it to only handle
a small handful of computers. It seems to me that it wasn't until IP
came along that you could connect very large collections of computers
together.
> manage and debug and route compared to the world-wide telephone network
> everyone takes for granted.
I'm fairly sure the telephone network connects vastly fewer nodes. It
was also originally analogue, not digital. Not to mention being managed
by a very small number of companies. But anyway...
> (actually, probably already ran out of addresses) long before every
> person has an address, let alone every piece of communications equipment.
Isn't that why IPv6 was invented?
BTW, how come nobody uses that yet? And does it replace just the IP
layer, or the entire protocol stack?
It's all telecommunications, which is what I think Darren is saying.
IP address blocks are managed by IANA - a single organisation. IANA does
delegate some administrative tasks, but overall they handle the larger
picture.
>> equipment.
Yes.
Some people do use it. IPv6 runs at the same OSI level as IPv4, so yes,
it's a direct replacement.
Jim
And what I'm saying is that it just seems that whenever somebody sat
down and designed a system for making computers talk to each other, they
invisiged a LAN with a quite limited number of nodes.
> picture.
That's roughly what I figured.
I mean, for example, does TCP work differently with IPv6, or is it the
exact same protocol just running over a different carrier?
The last party line was shut down in the late 1980s in the USA, if I recall
properly. It was surprisingly recent.
And what makes you think ISDN isn't a computer network technology?
From the very first sentence in the wikipedia page you claimed was too complex:
Integrated Services Digital Network (ISDN) is a set of communications
standards for simultaneous digital transmission of voice, video, data, and
other network services over the traditional circuits of the public switched
telephone network.
What do you think "Integrated Services" means?
Uh, no. How many computers do you think ISDN can connect together?
Or perhaps you mean http://en.wikipedia.org/wiki/X.25
> together.
You are mistaken. People were connecting together large numbers of computers
long before IP was around.
You are incorrect. Indeed, in 1999, there was more *fax* traffic than
internet traffic, let alone voice and data. Ten years later, probably less
so. But you're talking about "earlier" networks.
Just the number of telephones exceeded the number of IP addresses just a
couple of years ago. And that's not even counting the fact that IP allocates
multiple IP addresses to each router in the network and the PSTN doesn't
allocate phone numbers to the switches at all. If you actually allocated an
address to every endpoint like you do in IP, you'd have an order of
magnitude more addresses in the PSTN than you do in IP.
> It was also originally analogue, not digital.
Yes, but irrelevant once you invent the modem. All underlying network
technology is analog until it gets to a modem.
Not particularly. Certainly not nowadays.
>> And they're running out of addresses (actually, probably already ran
>> out of addresses) long before every person has an address, let alone
In part.
Because they stupidly didn't design in any backward compatibility, so an
IPv4 machine can't talk to an IPv6 machine and vice versa.
No. ISDN is a computer networking technology. It really is. When you swipe
your credit card, it uses the D channel of ISDN to deliver the numbers to
your bank and get the auth back. It's digital. It's computer. It happens to
be common that you take those bytes and run them thru a DAC to a speaker.
That doesn't mean your phone isn't a computer.
> picture.
And telco numbers are managed by ISO, and then each country, then each
company, then each local office, because the telco has *way* too many phone
numbers and crosses *way* too many administrative domains to make it
reasonable to only have two levels of network allocation.
IANA allocates blocks to Tier 1 providers. Then *they* split up the blocks
smaller and smaller. IANA has no say in what /24 you wind up getting on your
individual cable modem.
And that's the problem. It's a replacement, not an upgrade.
And yet I've given you half a dozen examples to the contrary. I give up.
>> does delegate some administrative tasks, but overall they handle the
>> larger picture.
They handle the top-level allocations of blocks for people who connect to
the primary backbone. Your ISP isn't one of them.
Have you read up on IPX? Used in some of the first PC networks, and it
was designed with multiple networks in mind and routing.
I've actually talked with one the guys who came up with that stuff.
"Limited" wasn't part of the equation, in fact, quite the opposite.
The fact that IPv6 uses the MAC address of the NIC as part of its address
is something they "borrowed" from IPX, in fact.
>> yes, it's a direct replacement.
I imagine Google could answer that question for you; I don't know off the
top of my head.
Jim
Yes, but it's all about getting information from point A to point B,
which is essentially what telecommunications is all about.
>> larger picture.
> phone numbers and crosses *way* too many administrative domains to make
> it reasonable to only have two levels of network allocation.
> blocks smaller and smaller. IANA has no say in what /24 you wind up
> getting on your individual cable modem.
Much like the telephone system. ISO has no say about what my cell phone
number is. :-)
Yep, though there are ways of tunneling IPv4 through IPv6 and vice-versa.
Jim
It's what all electronic networking is about. (Physical networking is about
getting "stuff" from A to B.)
In what sense is IP not telecommunications?
> number is. :-)
Yes. I'm agreeing with that, unlike Andrew's contention that it's all
centralized.
Unfortunately, they require someone to provide you a server, so most such
servers aren't open to the public.
> about getting "stuff" from A to B.)
I didn't say it wasn't. I'm agreeing with you.
>> phone number is. :-)
> centralized.
We're doing it again. Violent agreement. :-)
>> vice-versa.
> such servers aren't open to the public.
True, at least at this point.
Jim
You don't use ISDN to network all the computers in the building
together. You use ISDN to connect one computer in your building to one
computer in some other building. If it weren't for higher-level
protocols, you wouldn't be able to use this for anything other than
letting those two solitary nodes converse.
>> handle a small handful of computers.
2, AFAIK.
>> together.
> You are mistaken.
Oh well. I guess that's the problem with being *alive*. :-(
> computers long before IP was around.
Interesting. As I say, all the technologies I've seen support only small
numbers of nodes.
> less so. But you're talking about "earlier" networks.
That makes no sense at all. There are people who don't even own a
telephone, but have multiple computers connected to the Internet. And
nobody uses fax anymore. What the hell...?
Now do you mean they didn't design IPv4 to be easily extensible, or they
didn't design IPv6 to be backwards-compatible?
And WTF happened to IPv5 anyway?
http://blog.orphi.me.uk/
> recall properly. It was surprisingly recent.
I think that it was a bit earlier than that in the UK but we are much
more closely packed.
Best Regards,
I'm not sure of the history, but a lot of times, things will go a lot longer
where they were invented.
For example, in the USA, we had 96%+ landline penetration in residences in
1980 or so. South Korea had essentially none. Forward to 2005, and we have
like 20% of the population having cell phones and 80%+ of south koreans
having cell phones.
I.e., I wouldn't be surprised that by the time the UK had widespread
residential phone service, the technology was cheap enough that party lines
didn't really make sense.
> together.
You don't use IP to network all the computers in your building together
either. You have one wire from your computer to the switch. You then run
wires between switches.
You're being kind of silly here, you know that?
I guess you can only connect a modem to one other computer, too, right?
When the other computer in some other building is connected to a worldwide
network of switching fabric, what do you think happens?
Higher-level protocols like dialing the phone? You know, you can't even
connect two ISDN machines together. You *need* a switch in between, even if
the two machines are sitting in the same room.
> 2, AFAIK.
So that explains, for example, BRI having two high-speed channels and 8
source addresses on the D channel, right?
Tell me, how many people can you talk to on your phone?
>>> together.
>> You are mistaken.
It is, in part, part of the problem of people showing you where to read up
on the subject and you saying "that would take too long."
>> People were connecting together large numbers of computers long before
>> IP was around.
> numbers of nodes.
TELEPHONES! Jeez, dude. How many nodes do you think is typical for one
switch in, say, downtown London? Hint: I'd guess somewhere between 500,000
and 1,000,000 subscribers per switch.
Interesting, perhaps, because you're not really thinking things through.
Given that IP isn't a physical networking technology, how do you think IP
gets all over the world if there isn't any network technology capable of
connecting to things all over the world?
Clearly nobody uses fax any more.
The latter.
It was allocated to an experimental realtime protocol that didn't get deployed.
> worldwide network of switching fabric, what do you think happens?
You use ISDN to transport some higher-level protocol that knows how to
do routing?
>>> You are mistaken.
> up on the subject and you saying "that would take too long."
Or maybe a result of thinking that just because you've been using
something for 10 years, you actually know something about it...
> deployed.
Now *that* at least makes sense...
> do routing?
ISDN already knows how to do the routing. As does ATM and X.25. You don't
need to layer anything on top of it to route packets or connections.
I dunno. I've been using my lymph system for a lot longer than that and I
know virtually nothing about it.
> longer where they were invented.
> in 1980 or so. South Korea had essentially none. Forward to 2005, and we
> have like 20% of the population having cell phones and 80%+ of south
> koreans having cell phones.
Crikey!
http://en.wikipedia.org/wiki/List_of_countries_by_number_of_mobile_phones_in_use
In the UK everyone has almost one and a quarter mobile phones each (2008).
South Korea - 97.24% 2009
United States - 91.0% Dec. 2009
> lines didn't really make sense.
You are probably right, I missed the transition tho’.
Although I tend to think that it was not cost but capacity in GB (as it
was known then). Remember* there was no profit requirement with the GPO
but a mater of “national pride”.
* You won’t remember of course as there was no reason for you to take
notice. :-)
Best Regards,
>> do routing?
> don't need to layer anything on top of it to route packets or connections.
Well that's news to me...
> I know virtually nothing about it.
Ah, but do you have qualifications about it? Did you get an A* in your
Lymph System Utilisation finals?
Exactly. And that's *mobile* phones. The US still has 90%+ penetration of
land lines *also*. It's not uncommon for a family of four to have 10 phone
numbers dedicated to their use. That's why I say the PSTN is way bigger than
the internet, because (A) that's not even counting addresses assigned to
switches, which IP has to count, and (B) not even counting commercial phone
numbers, fax lines, pagers, phone numbers assigned to modems, etc.
I'm not even sure if VOIP and cable telephone counts as part of the PSTN.
>>> to do routing?
>> connections.
You don't understand that ISDN carries phone calls as part of its Integrated
Services?
You didn't read the first paragraph of the wikipedia page I looked up for you?
> PSTN.
I think it probably does, as I understand a not insignificant portion of
the PSTN is VOIP-based these days.
Jim
>> PSTN.
Well, again, I'm just talking about the client endpoints. I.e., those bits
that have phone numbers as such. I know a lot of voice traffic between
switches is carried on VOIP at this point.
>>> PSTN.
>> of the PSTN is VOIP-based these days.
> bits that have phone numbers as such. I know a lot of voice traffic
> between switches is carried on VOIP at this point.
True; it would be interesting, for example, to know if my work number
counts as part of the PTSN; all of us in the office have VOIP phones
(mine is remote to the office switch most of the time) - from the trunk's
perspective, though, I don't think it knows one way or the other.
Jim
Yes, it does. If you have a phone number, you're part of the PSTN. If it
shares phone numbers with other phones (and you have to dial an extension or
something, or "dial 9 for an outside line and maybe get a busy signal"),
then it's still part of the PSTN, it's just all behind one phone number.
It has to know how to route your call to the rest of the network.
> it shares phone numbers with other phones (and you have to dial an
> extension or something, or "dial 9 for an outside line and maybe get a
> busy signal"), then it's still part of the PSTN, it's just all behind
> one phone number.
Makes sense, I thought that probably was the case.
>> all of us in the office have VOIP phones (mine is remote to the office
>> switch most of the time) - from the trunk's perspective, though, I
Yep.
Jim
>>>> to do routing?
>>> connections.
> Integrated Services?
> for you?
I was under the impression that the digital part of the system connects
to only one destination.
It's *all* digital.
