Mike Raiford wrote:
> Right. The bigger the aperture, the more glass (And in high-end lenses
> it's exotic glass with exotic coatings) ergo, the more cost.
> Remember, the glass has to be a special type (and in most lenses, there
> are a couple different types of glass being used) to eliminate
> dispersion effects. Also, its expensive to grind some of the profiles on
> the glass to counter geometrical distortions. Again, adding to the price
> tag.
I bet a £7,000 lense is really, really heavy...
(I couldn't tell from the picture, but it looked like it was 30cm across
or something!)
http://blog.orphi.me.uk/
Jim Henderson wrote:
> On Wed, 05 May 2010 12:35:02 +0200, scott wrote:
>> And typically pros will not let the camera do *any* processing, and
>> import the raw sensor data to their computer for manual colour,
>> sharpness and exposure control.
> Exactly - the adjustments I made were pretty basic with GIMP (similar to
> the ones you made), but if RAW format images were available, there'd be a
> lot more room to adjust things like exposure.
...but once the image has been taken, the exposure has already happened.
How can you change it after the fact?
Sabrina Kilian wrote:
> You can fix it with the aperture and exposure, blurring out the
> background. You can fix it in post, just pushing the hue and saturation
> values around. You don't fix this in camera with menu options. Skip the
> color correction in camera, if you can. Skip jpeg if the camera has the
> option to shoot raw. You want some dark in there, so one fix in camera
> might be to under expose the images if you can not set the shutter speed
> directly.
Just FYI, the camera doesn't have any option to save anything but JPEG
format. You can adjust the colour balance (but not very much), and
exposure and IIRC you can manually set the shutter speed in case you're
insane.
I still want a new camera. It's a PITA that I can't leave the batteries
in this one...
In film cameras, exposure means how much time the film is exposed to light.
In digital cameras, the sensor is receiving light all the time. What does
"exposure" mean there?
"Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote:
> On Wed, 05 May 2010 20:21:15 +0200, Darren New <dne### [at] sanrrcom> wrote:
>> I just got PSP X2 working again.
>> What is with these companies? PSP8 had a perfectly good mechanism for
>> browsing pictures.
> Very different companies. Jasc good; Corel bad.
I remember using Jasc Paint Shop Pro 5... Now that had no bloat :)
> browsing pictures.
> </rant>
Thanks for the heads up :-D
Best Regards,
First, it's not. At least in DSLRs. :-)
I suspect in things like the little cameras where you aim thru the LCD,
there's either a non-mechanical shutter, or there's a wire that clears the
sensor, you let it accumulate for some number of miliseconds, and then you
read the sensor.
Second, if you're talking about the ISO setting rather than the exposure,
that's about how much you pre-bias the electrons in the sensor. Basically,
you load up each pixel of the sensor with some electrons, and if light kicks
out an electron, you add one to the intensity of the light there. Adding
more electrons makes it easier to get kicked out.
Linux: Now bringing the quality and usability of
open source desktop apps to your personal electronics.
>>> browsing pictures.
I can still use 8. The only reason I even bought the new one is that when
working on vacation photos, I tend to open up a bunch from the same scene
(so to speak), do the adjustments, pick which ones I want to keep, then exit
out and tell the paint program to save everything. This fails on PSP8 under
Vista for some reason. Otherwise I was perfectly happy with the program.
> insane.
> in this one...
What kind of camera have you got? (I suppose I could look at the EXIF
tags.....Fujifilm FinePix S304 it looks like.
Changing the shutter speed, though, that's not insane, that's sensible
when you can tell how it will affect the image.
Jim
>> to the ones you made), but if RAW format images were available, there'd
>> be a lot more room to adjust things like exposure.
I've actually wondered this myself - raw editing software gives you the
option to adjust the exposure; obviously, you can't pull details out
doing this that are completely washed out or completely underexposed, but
it is possible to bring additional detail out by making changes to the
exposure setting (ev) after the photo has been taken.
I've done it, so clearly it's possible, I just don't understand the math
behind it.
Jim
