POV-Ray : Newsgroups : povray.off-topic : Baffling Server Time
15 Jun 2026 21:40:22 EDT (-0400)
  Baffling (Message 47 to 56 of 216)
Subject: Re: Baffling
Date: 26 Apr 2010 11:13:06
Message: <4bd5ad82$1@news.povray.org>
>> I mean, if you're going to force everybody to buy a new TV, new
>> receiver, new type of disk and a new machine to play it, why it increase
>> the resolution *significantly*? Why only increase it by a small amount?
>> I don't understand that.
> Partly bandwidth related. The UHF/VHF frequency space has only a certain
> amount of bandwidth per channel. Now, while a HD broadcast in 1080p at
> an "acceptable" compression ratio might fit nicely within the allotted
> bandwidth for a channel, doubling the horizontal and vertical
> resolution, for example quadruples the number of pixels on the screen.
> Eventually, the video would need to be compressed to the point where the
> image would be nothing more than a macroblock-fest.
Quadrupling the number of pixels doesn't necessarily mean that the
*compressed* signal takes more bandwidth. I'm sure I'm not the first
person to notice that using higher resolutions tends to make the video
more compressible. (Although, sure, I imagine there's a limit to how far
you can feasibly go.)
Then again, since we replaced our old CRT with a shiny new LCD, suddenly
I notice that just about *everything* on TV has DCT artifacts all over
it. (I guess the CRT was too blurry to show this.) It's quite annoying.
Date: 26 Apr 2010 11:15:28
Message: <4bd5ae10$1@news.povray.org>
Ooo, here's a random thought: Do you think there will ever be a day when
the Internet becomes fast enough to watch TV-quality video in realtime?
When do you think that day will be?
Date: 26 Apr 2010 11:19:09
Message: <4bd5aeed$1@news.povray.org>
On 4/26/2010 4:49 AM, Invisible wrote:
> I especially love how I have a widescreen TV, but you have to manually
> flip between 4:3 and 16:9 aspect. Even though it's connected by a
> digital link, so you'd think it could *detect* which kind of signal it's
> receiving...
Heck, the device producing the signal even does this:
http://en.wikipedia.org/wiki/Widescreen_signaling
There is a slight issue, of course with HD signals, since they're only
intended for the 16:9 aspect ratio, if a program was originally intended
for the 4:3 ratio, it will be "pillar-boxed", but the signal is still
16:9, so you must manually change the TV's widescreen mode if you want
to fill the screen.
> That being the case, it's not entirely easy to tell whether you're
> watching a widescreen broadcast, or a normal one with the top cut off.
> (Unless of course you configure the TV to show black bars at the side -
> but it's my mum's TV, and she always complains when I configure it that
> way.)
I don't care for the stretching, though when viewing 4:3 full-screen on
my TV it's not as severe as some, the only reason I do stretch it,
though is because my TV is an old-school CRT projector and prone to
burn-in. If it weren't for that, I'd display 4:3 in its native format.
Perhaps your mother has the same concerns?
~Mike
Date: 26 Apr 2010 11:23:29
Message: <op.vbrzpfg37bxctx@toad.bredbandsbolaget.se>
About five years ago.
Are you sure you are not living in the jungle?
FE
Date: 26 Apr 2010 11:25:32
Message: <4bd5b06c@news.povray.org>
On 4/26/2010 8:28 AM, Invisible wrote:
>> Maybe the fact that Windows is not good at scaling has meant that
>> making a 150 or 200 dpi monitor that is used from "desktop" viewing
>> distances would be impossible to use due to the tiny physical size of
>> the fonts and other GUI items?
> Plausible.
>> I was running it for a while on my laptop with a non-standard dpi
>> setting. On the whole Windows and Office was fine, but IIRC my CAD
>> software screwed up, with some buttons being shifted outside of the
>> window so you couldn't get to them!
> Haha! And I bet that CAD software was the most expensive thing on the
> whole PC, by a mile... ;-)
That's the biggest part of the problem out there, many apps were written
without regard to a higher DPI setting, and do some wacky things if
they're used with a higher DPI. I think Windows 7 has some compatibility
settings somewhere to help alleviate some of these issues. So, high-dpi
display may be coming soon.
~Mike
Date: 26 Apr 2010 11:25:36
Message: <4bd5b070@news.povray.org>
>> when the Internet becomes fast enough to watch TV-quality video in
>> realtime?
Really?
And where the hell does this happen?
Yes, quite sure. (I hate the outdoors, remember?)
Date: 26 Apr 2010 11:29:18
Message: <op.vbrzy4xu7bxctx@toad.bredbandsbolaget.se>
>>> realtime?
> Really?
Here.
I thought you enjoyed skiing. Is it just plants that you hate?
FE
Date: 26 Apr 2010 11:31:08
Message: <4bd5b1bc$1@news.povray.org>
On 4/26/2010 8:00 AM, Invisible wrote:
> 2. A stretched image where everybody has elliptical heads.
I don't know how things are in the UK, but over here, everyone generally
has an elliptical head. ;)
> 3. One of the various "zoom" modes which distorts the image non-linearly
> to supposedly give a better picture than a linear distortion.
Mmm, my father in law had a TV that did this. It was quite literally
nausea-inducing. I always wound up with a nasty headache after watching
anything in 4:3 on that TV.
> 4. Cut the top and/or bottom off the picture to make it fit.
Depending on the program, this is acceptable, of course if there's
titling or a crawl across the bottom of the screen... it's a nuisance.
> Everybody seems to hate #1, but lots of people apparently see nothing
> wrong with #2 or #3. *shudders*
Yeah, I don't get it. The only reason I really want the screen filled is
so my CRT doesn't burn-in.
~Mike
Date: 26 Apr 2010 11:32:17
Message: <4bd5b201$1@news.povray.org>
> Really?
Virgin have a system called On Demand in the UK.  Here in Germany we have
T-Home.  Obviously you need a fast internet connection (about 6 MBit/s or
higher IIRC) to receive broadcast quality video.
http://en.wikipedia.org/wiki/IPTV
http://en.wikipedia.org/wiki/Video_on_Demand
Date: 26 Apr 2010 11:38:03
Message: <4bd5b35b$1@news.povray.org>
>> Really?
> Here.
Who is it?
It's me.
OK, I rephrase: I hate being outside for no particular reason. Like,
"hey, let's go for a walk outside". (Or rather, "let's wander around at
random for no purpose when I could be coding stuff".) Apparently some
people like to look at the view or something...
