POV-Ray : Newsgroups : povray.off-topic : Context switching Server Time
5 Jul 2026 20:30:05 EDT (-0400)
  Context switching (Message 201 to 210 of 222)
Subject: Re: Context switching
Date: 24 Apr 2010 04:56:12
Message: <4bd2b22c$1@news.povray.org>
>> Or rather, I'd rather write my own program than use grep for a *complex*
>> search. (E.g., find anything that's a valid XML fragment.)
>   Don't start making unfair comparisons. 'grep' (as well as other similar
> tools such as 'sed') is a line-based tool. It can match individual *lines*
> of the input. It cannot be used to perform operations which would require
> interpreting several lines (unless it has some non-standard extensions).
>   Recognizing a valid XML fragment would require interpreting several lines
> of the input (if you want to be able to match all possible cases), and hence
> 'grep' cannot be used for that.
Right. And when I do text processing, this is the kind of task I usually
want to do. Which is perhaps why grep doesn't sound especially useful to me.
Still, if your goal is just to find out if (or where) a file contains a
particular word or code number, I agree that grep is probably the
fastest way to find it.
>   'grep' is most useful for finding things you know are all in one line,
> and for filtering files with a known format (such as httpd logs).
I gather line-based file formats are quite common in Unix. (E.g., fstab
is line-based, IIRC.) Such things are comparatively rare for Windows
though. About the closest thing is CSV files. But - as I recently
discovered - CSV isn't really line-based. (A single record can span
multiple lines. At least, according to the RFC.)
>   If you need more complicated things like that, then often 'awk' or 'perl'
> can be used (still usually with shorter commands and faster than writing
> your own program would).
I would debate that, but let's not start another argument...
http://blog.orphi.me.uk/
Date: 24 Apr 2010 05:37:45
Message: <4bd2bbe9@news.povray.org>
  Are you saying that you don't think one could write a significantly
shorter command using perl than with your favorite language? Maybe you
just don't know that perl can be used directly from the command line,
giving the "program" as an argument, and hence it can be used very much
like grep or sed. For example:
    perl -pe 's|\d+|$&+1|ge' file.txt
  This searches for any consecutive digits in 'file.txt', interprets them
as numbers and outputs the contents of the file but with each of these
numbers incremented by 1. (Thus if the file had a something like
"value = 123;" somewhere, the result would have "value = 124;" instead.)
  I don't know Haskell too well, but I'm pretty certain it takes a bit
more code to do that (and additionally you probably can't just write the
code on the command line).
  (And yes, I know that the string given to perl looks gibberish to you.
It's not gibberish when you understand what it means.)
  Of course this is just a simple example. Perl can be used to make
significantly more complex substitutions (and other things) in a similar
way.
Date: 24 Apr 2010 06:02:46
Message: <4bd2c1c6$1@news.povray.org>
...alternatively, let's start another argument... *sigh*
It does. (If only because of the difficulty of number parsing.) But a
more relevant question would be... why would you want to do this? Is
Haskell (or anything else) easier or harder for textual manipulations
that actually do something useful?
Actually you can. (But obviously you *only* want to do this if the code
is short...)
> way.
Again, I guess it depends on what you want to do. For example, some guy
invented "markdown", and wrote a Perl script to turn it into HTML or
whatever. And then a bunch of Haskell guys wrote their own
implementation, which was faster, had fewer bugs (i.e., it matched the
documentation more closely), and had more features.
Then again, not every task is as complicated as markup conversion...
Date: 24 Apr 2010 07:11:15
Message: <4bd2d1d3@news.povray.org>
  Why would one want to do pattern substitution?
  Obviously nobody wants to do that, which is why there are no tools to do
that from, like, forever, like eg. 'sed' or 'perl'.
  I'm sure even you have used search&replace. This is the same, except that
it's significantly more expressive and can be automated.
Date: 24 Apr 2010 13:00:47
Message: <4bd323bf$1@news.povray.org>
On Sat, 24 Apr 2010 09:04:40 +0100, Orchid XP v8 wrote:
> Nicolas Alvarez wrote:
>> Yesterday, the 'parted' tool was giving me a totally cryptic error
>> message.
>> $ apt-get source parted
>> $ cd parted-2.2
>> $ grep -rn "error message here" .
>> -r makes search recursive, -n makes grep output line numbers next to
>> the filenames. Then I opened a text editor on the file and line number
>> that grep mentioned, and tried to figure out the code :)
> Isn't trying to figure out why an arbitrary piece of code doesn't work
> formally equivilent to the Halting Problem? (With non-termination simply
> being the most basic kind of program bug...)
You're not asking grep to tell you why it failed, just to tell you where
in the code the error is so one can manually inspect the file and see if
one can determine why the failure occurred.
Done that many times myself.
Jim
Date: 24 Apr 2010 13:52:56
Message: <4bd32ff8$1@news.povray.org>
No.
The code works, in the formal sense. It just doesn't do what you want it to do.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 24 Apr 2010 13:56:27
Message: <4bd330cb$1@news.povray.org>
Orchid XP v8 wrote:
> Such things are comparatively rare for Windows though.
INI files is about it. Anything more complicated either goes in the registry
or into an XML file, if it's configuration. Some log files actually go into
text files, but that's mostly things like httpd logs there, too.
Using Perl *is* writing your own program. And I expect the parser generator
in Haskell isn't a whole lot harder than an equivalet program in Perl.
Date: 24 Apr 2010 14:01:10
Message: <4bd331e6$1@news.povray.org>
Personally, I usually wind up wanting to do complex pattern manipulation on
file names, rather than file contents.
Stuff like "go through these directories full of image files, figure out
whether it's months, days, or hours that's changing, rename all the files to
match the time they were taking excluding the parts of the date that's the
same for all the files, tack on a letter saying which camera took the
picture, then another letter to disambiguate multiple photos taken within
the same minute.   Also, copy any sequence of three or more photos taken
within 5 seconds of each other with a one-minute gap on either side to a
separate directory to be stitched together as a panorama."
That's gonna be rough to do with command-line tools too. Not impossible, but
certainly something easier in an actual scripting language better than Bash.
Date: 24 Apr 2010 14:15:40
Message: <4bd3354c@news.povray.org>
> No.
> to do.
Or, to clarify...
If by "works" you mean "obeys the formal specification", then yes, you can
prove it.  Write a formal spec for what sequence a Haskell program can
output, such as a BNF grammar. Now analyze your Haskell program to see if
the parser you wrote follows the BNF.
Computers do this all the time. There's an input language the compiler
accepts. It can tell whether the input matches the language spec, and if so,
the program "works", in some sense.
And indeed, this is called the field of "program verification", pioneered by
those who invented structured programming and such.
Date: 24 Apr 2010 14:20:33
Message: <4bd33671@news.povray.org>
>> Invisible wrote:
>>> 3. It really takes that much code just to do the same task as DIR /B C:\
>>>  C:\FileList.txt?
>> Says the guy who would rather write his own program to do specific
>> searches than figure out grep :)
Well, sure. Regular expressions are almost always the wrong tool for XML.
