Jim Henderson <nos### [at] nospamcom> wrote:
> That was the point Randi was making - some of the dilutions that were
> being advertised were less than one molecule per 6x10^23 atoms of water -
> or, as he also described < one molecule of caffeine (or whatever) per
> *more atoms of water than would fit in the space provided in the
> packaging*. IOW, it wasn't a *diluted* solution, it was to the point of
> placing odds on one molecule being even *in* the container, and those
> odds weren't particularly good.
Remember that the active ingredient is something that *causes* the
symptoms, not something that *cures* them (for example in a homeopatic
sleeping pill the active ingredient is usually caffeine). Hence taking
this ingredient *away* from the water likewise takes the *symptoms* away
from the person. The more of it you take away, the more effective the stuff
is. It makes perfect sense.
Well, I'm guessing that water that has almost no benzene in it is fairly
healthy, yeah... But that's some pretty simplistic reasoning.
Obligatory XKCD quote:
http://xkcd.com/641/
http://blog.orphi.me.uk/
Warp is quite right, as ever. He is just trying to emulate the reasoning
behind homeopathy.
As far as I could follow the topic on wikipedia, the whole thing has quite a
lot of occultism in it. Dilution is just the physical side of preparation of
medicines, the stuff has to be "dynamized" by the ritual shaking of
waterbottles and so on.
It is as sound a concept as that of Victor Schauberger's "natural flows"
(supposedly able to create anything from free energy to anti-gravity to
healing medicine) or the theory that water has a memory. I find it
astonishing what people actually can believe in...
Apart from this all: the strangest thing is the (scientifically proven)
effect of a placebo - it is strange that it actually works. If you just
really, truely and completey believe that a thing will work it can cure you:
be it homeopathy, accupuncture (here I see at least in some cases a physical
reason that might work - the needles blocking nerves >might< have effects -
though I am sceptical), faith healing, imbibing water at Lourdes or sleeping
below a pyramid.
On 3/23/2010 2:20 PM, Jim Henderson wrote:
> On Tue, 23 Mar 2010 14:17:58 -0700, Darren New wrote:
>> Warp wrote:
>>> Some people argue that since homeopathic substances amount to
>>> placebos in
>>> practice, the entire phenomenon of homeopathy is more or less innocuous
>> Homeopathy is innocuous. Believing it works is the danger. :-)
> Point to Darren. :-)
> Jim
This thread is reminding me of this, which I just had pointed out to me:
http://www.youtube.com/watch?v=aAYVY2eLMck&feature=player_embedded
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
> behind homeopathy.
> reason that might work - the needles blocking nerves>might< have effects -
> below a pyramid.
Yeah, needles blocking nerves that are a) never in the same precise
physical place in every person, and b) where the practice seems to work,
when it does, whether you use the "correct" points at all, or c) even
one that could legitimately be connected to the part you are trying to
cure, might be plausible. Well.. except for the three things I
mentioned... lol
void main () {
else
On 3/24/2010 2:22 AM, Invisible wrote:
> scott wrote:
>> I really wonder whether the people who make this stuff really do
>> believe in it, or whether they are just laughing at all the idiots
>> giving them lots of money for tap water?
> My guess would be that both types of people exist. The interesting
> question is in what proportions they exist...
Better question is, how many may realize it is fake, but fear the
consequence to all the people they are *helping* by admitting that it is
fake? Was an article in a paper recently with this and religion, where
they found and interviewed like five priests who a) don't being in
***any*** of the Bible, including god, but did believe that the
consequence of admitting they don't believe in it, to those that do, or
need the church, was too high for them to admit they don't to their own
parishioners.
But, unfortunately, its also true that one of the things people are good
at is taking a lie, telling it often enough, and getting enough
"apparent" positive results from doing so, that they provisionally, then
finally completely fall for it themselves.
void main () {
else
> below a pyramid.
The placebo effect seldom *cures* any disease. What it does is to alleviate
symptoms within the limits of what the human body itself can do.
This is especially so if the symptom is caused by the body itself. For
example, placebos can sometimes quite effective alleviating things like
astma attacks because an astma attack is, in fact, caused by the organism
itself as some kind of oversensitive protection mechanism. The placebo
effect can "convince" the body that there's no need for the "protection"
anymore, and thus the astma attack subsides. The same is true for many
other symptoms caused by a hypersensitive self-defense mechanism.
Another effect that placebos can have is to induce the body to produce
endorphins and other similar stuff which alleviates pain. This can be
quite effective sometimes. It's curious how it works, but somehow it just
works: If the brain strongly believes that the pain will go away, then it
subconsciously *makes* it go away by secreting endorphins.
Of course there are limits to what the body can do. A placebo cannot make
the body destroy a bacterial or virulent agent any faster than it would
normally do (if it's capable of doing it at all without the help of actual
medicine). A placebo cannot cure a genetic disease or disability, or cure
injuries any faster than normal. And so on.
That reminds me of Obama-care.
Warp wrote:
> Some people argue that since homeopathic substances amount to placebos in
> (unless you count people spending money on it for nothing).
> Not so:
http://www.news.com.au/national/babys-eczema-death-was-parents-fault/story-e6frfkvr-1225708504277
Actually, homeopathy did have one enormous benefit in the past.
Until around 170 years ago, allopathy (what we recognize as conventional
medicine) was still stuck in the quackery that characterized medicine
during the Dark Ages; Mark Twain mentions in one of his essays that the
shift from the ancient quackery to modern competence took place during
his lifetime. Most of the success that allopathy appeared to have back
then was due to the placebo effect, and some of the treatments did more
harm than good.
Then along came homeopathy. Allopathy was so ineffective (and in some
cases, downright harmful) that homeopathy was usually as effective, and
often better. This prompted allopathic practitioners to put aside their
Galen-worship and conduct some actual research, leading to the discovery
of the new, effective treatments that replaced the old, dangerous ones.
John
On 03/23/10 14:29, Stephen wrote:
> Believing it works for others, especially your children, is criminal.
And how, pray tell, will you enforce such a thing?
Mary had a little lamb, a little beef, and a little ham.
