POV-Ray : Newsgroups : povray.off-topic : Try Haskell Server Time
4 Jul 2026 18:40:27 EDT (-0400)
  Try Haskell (Message 53 to 62 of 62)
Subject: Re: Try Haskell
Date: 16 Mar 2010 03:43:38
Message: <4b9f36aa$1@news.povray.org>
> simulations,
I heard Haskell has OpenGL capability, how easy is that to get running -
then we might be talking :-)
Subject: Re: Try OpenGL
Date: 16 Mar 2010 06:48:32
Message: <4b9f6200$1@news.povray.org>
Heh, OK, it's just taken me the entire morning to figure this out.
(Documented? What do you mean documented? Why would it be documented??)
First: The Haskell Platform includes OpenGL out-of-the-box, so it should
Just Work(tm).
Second: The documentation for OpenGL is missing, which made me spend 20
minutes trying to figure out why it wasn't there. Querying the package
list confirms that OpenGL actually *is* there, it's only the
documentation that's missing. (Thanks, guys...)
Third: I compiled a simple OpenGL program, and it crashed with "cannot
find glut32.dll". I don't know if that's because I don't have a 3D card
on this machine or what. Anyway, it took a while to fix it! YMMV.
Start with this:
module Main where
import Graphics.Rendering.OpenGL
import Graphics.UI.GLUT
myPoints :: [(GLfloat,GLfloat,GLfloat)]
myPoints = map (\k -> (sin(2*pi*k/12),cos(2*pi*k/12),0.0)) [1..12]
main = do
   (progname, _) <- getArgsAndInitialize
   createWindow "Hello World"
   displayCallback $= display
   mainLoop
display = do
   clear [ColorBuffer]
   renderPrimitive Points $ mapM_ (\(x, y, z)->vertex$Vertex3 x y z)
myPoints
   flush
Save that lot as Test.hs or something. Then execute
   ghc --make Test
That should generate Test.exe. Now run it.
If it whines about not finding glut32.dll, go here:
   http://www.transmissionzero.co.uk/software/freeglut-devel/
Download the "FreeGLUT MinGW" package, and unpack glut32.dll from it.
(You can ignore all the other files; you only need the DLL.) Drop the
DLL into your search path or just into the same folder as Test.exe, and
then try and run it.
If it works, you should get a black window with some white dots.
Assuming all of that works, you now just need to learn the whole Haskell
programming language, including how to do I/O, and learn the OpenGL
binding, and then you can do stuff. ;-)
And now if you'll excuse me, I'm going to go file a bunch of tickets
with the bugtracker. :-P
Date: 16 Mar 2010 07:05:01
Message: <web.4b9f64b5e7b75d5a1c2a3d200@news.povray.org>
Yup, OpenGL doesn't ship with GLUT (OpenGL Utility Toolkit). You need to
download it separately.
Date: 16 Mar 2010 07:29:05
Message: <4b9f6b81@news.povray.org>
> myPoints
>   flush
>   ghc --make Test
I get:
Test.hs:20:0: parse error (possibly incorrect indentation)
I guess something with the indentation is not correct at the end of the .hs
file?  What does it need?
Date: 16 Mar 2010 07:31:49
Message: <4b9f6c25$1@news.povray.org>
scott wrote:
>> myPoints
>>   flush
>>   ghc --make Test
> I get:
> .hs file?  What does it need?
The "myPoints" is supposed to be at the end of the previous line.
Apparently it got wrapped...
Date: 16 Mar 2010 07:44:26
Message: <4b9f6f1a$1@news.povray.org>
Cool it works!  (I had to rename freeglut.dll to glut32.dll)
Now to learn Haskell...
Date: 16 Mar 2010 07:58:28
Message: <4b9f7264$1@news.povray.org>
Oh, yeah, I forgot to mention that part. o_O
LOL! Um, yes. ;-)
You'd probably be best learning the pure part of Haskell first, since
this is the primary objective of Haskell. The impure part of Haskell is
just like any other language - but far, far more wordy. Thing is, OpenGL
is all *about* the impure part, so...
Date: 19 Mar 2010 05:53:56
Message: <4ba349b4@news.povray.org>
scott wrote:
> You're also quite good a writing tutorials, you should definitely write
> a book.  Haskell for Imperative Programmers.  :-)
If I write it, will you help review it?
Date: 19 Mar 2010 06:05:24
Message: <4ba34c64$1@news.povray.org>
>> You're also quite good a writing tutorials, you should definitely write a
Of course! But I expect 50% of the profits :-D
Also it will be a good excuse to hold off learning Haskell for now, as then
I'll still be a real beginner when you finish the first draft...
Date: 19 Mar 2010 06:12:23
Message: <4ba34e07$1@news.povray.org>
>>> write a book.  Haskell for Imperative Programmers.  :-)
> then I'll still be a real beginner when you finish the first draft...
Hehehe, OK then. :-)
