POV-Ray : Newsgroups : povray.off-topic : Try Haskell Server Time
5 Jul 2026 00:26:58 EDT (-0400)
  Try Haskell (Message 21 to 30 of 62)
Subject: Re: Try Haskell
Date: 3 Mar 2010 11:30:18
Message: <4b8e8e9a$1@news.povray.org>
scott wrote:
>> Hmm, maybe I should write my own?
> It's very useful for an absolute beginner, these are the things you need
> to know that a lot of tutorials assume you somehow magically know already.
The hard thing about writing a tutorial is that by the time you're
experienced enough to be an authority on the language, half the stuff
that trips newbies up is so utterly "obvious" to you that you forget to
even mention it. (Plus you're all excited and you want to jabber
incoherently about the cool stuff, not the dry old "this is how you
escape a newline character".)
>> > :t fst
>> Take a look at this type signature. Can you figure out what it means?
>> > fst (5, 'x')
>> Did that do what you expected?
> Well it seems to return the first item from a tuple.
> Is it just a shorthand for "take 1"?
> Ah no, it seems those list operators don't work with tuples :-(
It's all in the type signature.
[Int] means a list of integers. It can contain any possible number of
integers (including zero or infinity). [Char] means a list of characters.
Tuples, on the other hand, have a different type for each size, and each
combination of element types. For example, (5, 'x') is of type (Int,
Char), but (5, 'x', False) is of type (Int, Char, Bool). As far as the
type system is concerned, these two types are completely unrelated.
Because of this, you cannot write a function that works on any possible
size of tuple. It's impossible. (You can write a *method* that works for
any size of tuple that you've manually written a definition for, but
that's about it.)
In truth, if you're using tuples bigger than about three or four
elements, you really ought to define a custom type for this stuff
instead of relying on tuples. Tuples are really for simple, quick things
like returning multiple results from a function, or for key/value pairs.
Stuff like that.
...and this whole explanation is a good example of the kind of thing
that's hard to explain in an interactive tutorial. ;-)
> So this means "let x = 5 in (the following expression)..."
Indeed yes.
> Now Step 7 in the original tutorial makes sense :-)
Yeah. It's simple, it's just explained badly...
>> OK, I'm going to stop now...
> OK I need to download the compiler if I am to actually learn any of this...
I can talk some more if you want?
But yes, this (alpha) web thingy lacks several important features:
- You can't define things and refer to them later. Each expression is
processed independently.
- You can't write multi-line definitions.
- You can't do I/O. (And the error message if you try is cryptic to say
the least!)
- You can't use all of the standard Haskell libraries, just the handful
the interpretter offers.
In a real Haskell interpretter, you can usually do stuff like
 > let factorial n = product [1..n]
 > let choose n k = (factorial n) / (factorial k * factorial (n - k))
 > choose 3 5
In the online interpretter, you'd have to do
 > let factorial n = product [1..n]; choose n k = (factorial n) /
(factorial k * factorial (n - k)) in choose 3 5
This, coupled with the horrifyingly buggy command history, is just no
fun at all.
Are you actually interested enough to want to play with it more?
Subject: Re: Try AJAX
Date: 3 Mar 2010 11:32:15
Message: <4b8e8f0f@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> I do, but it can only serve static HTML.
> Uh, no. Every major OS comes with a real web server.
Really?
> But if you're actually going to get into AJAX programming, you're going
> to have to learn more than you can by asking people here to explain it
> to you. ;-)
No, I'd just like to see if I can do a small proof-of-concept thing and
make it work. ;-) Let's face it, DOM is way too hard in the first place...
Date: 3 Mar 2010 12:50:23
Message: <4b8ea15f$1@news.povray.org>
Then take static files and request them via xmlhttprequest. That's how I do it.
Make up files text1.txt text2.txt text3.txt and so on, then write a loop in
javascript to sleep a few seconds, xmlhttprequest the next file in the list,
and when it shows up take the data and populate a DOM element with it. It works.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 3 Mar 2010 17:04:22
Message: <4b8edce6$1@news.povray.org>
> the least!)
They seriously should steal features from http://tryruby.org/
- You can define variables and refer to them later. Example, type a=1, press
Enter, then type a+a.
- You can write multi-line definitions. Try this one:
5.times {
    print "Hello"
When it parses the first line, it will notice the statement is incomplete
and let you continue it.
- You can do I/O (fake filesystem). The whole chapter 4 of the tutorial is
about I/O and file handling.
- You can do HTML and see the results via a custom library made for the
tutorial. Try:
require "popup"
Popup.make {
   h1 "Hello world"
   p "foo"
Date: 3 Mar 2010 17:10:45
Message: <4b8ede65$1@news.povray.org>
Well, the page even *mentions* Try Ruby.
I guess the guy just hasn't written the code yet... A few days ago, ":t"
didn't work. And now it does. (Annoyingly, GHCi uses ":t" as an
abbreviation for ":type", but the website doesn't accept ":type", only
":t".)
http://blog.orphi.me.uk/
Date: 4 Mar 2010 02:36:52
Message: <4b8f6314@news.povray.org>
> experienced enough to be an authority on the language, half the stuff that
> trips newbies up is so utterly "obvious" to you that you forget to even
> mention it.
Exactly.
> In truth, if you're using tuples bigger than about three or four elements,
> you really ought to define a custom type for this stuff instead of relying
> on tuples.
OK.  I take it a custom type is a bit like a struct in C-type languages, in
that it can hold any number of different types?
Once you know a few basic things I think it's best to move on to simple
examples (small multi-line samples, not those artificial ones needed for the
web).
> > choose 3 5
Exactly.  Even I can work out from that one how functions are defined now
BTW what would happen if I typed "choose 3 (-5)" instead?
I'm just trying to think of a subject for a good example ... how about a
card game?  Firstly how would you represent the cards (tuple or custom type
for the suit/value?).  Then I assume you would just create a list of "Cards"
to represent a group of cards that someone was holding (say 5 cards).  How
would you then check to see if any two cards in that list were the same
value, or all the same suit, etc?
I was interested enough in J to learn how to use it to write a mandelbrot in
1-line :-)  Haskell should be a doddle - at least you stand to pick up bits
and pieces based on English, rather than just almost random single
characters for everything!
Date: 4 Mar 2010 04:43:26
Message: <4b8f80be$1@news.povray.org>
>> to even mention it.
> Exactly.
This is one of the hardest things about technical writing - and one of
the things I most often see done wrong. Search around the Internet a
bit, and you'll find Haskellers writing things like "a monad is just a
monoid in the category of endofunctors - what's the problem?" like
normal human beings have any clue WTF that means. (I have *some* clue,
but the category theory definition of a monad doesn't even begin to
explain why it's useful in computer programming.)
> in that it can hold any number of different types?
It can be. The neat thing about Haskell is that it has "algebraic data
types". These can be like a struct or a record or whatever you want to
call it. Or they can be like an enumeration. OR THEY CAN BE BOTH!
(I guess this is what C would call a "union". But it's type-safe. You
cannot accidentally access a field that does not exist. Or use the wrong
field type.)
> the web).
Some things are easiest to explain by example. Like, some concepts are
so extremely abstract that without an example, it's difficult to
comprehend what's going on. Other things are quite tricky to demonstrate
with examples; you end up needing to use examples which are either
extremely complex, or very contrived. In depends what you're trying to
demonstrate.
I think for general familiarity with a programming language, lots of
small examples is probably the way forward.
>> > choose 3 5
> now :-)
Well, yeah, there is that too. ;-)
Well, it would execute
   (factorial 3) / (factorial (-5) * factorial (3 + 5))
Given the above definition of factorial,
   factorial (-5) = product [1..-5] = product [] = 1
Which I'm guessing means that choose gives the wrong answer.
(I also just realised that that should probably be integer division,
since choose is only supposed to work with integer inputs and yield
integer outputs...)
> type for the suit/value?).
At the most basic level, you can always use tuples and code numbers. But
why do that, when the language has extensive support for a better way?
The idiomatic way would probably be to do something like
   data Suit = Diamonds | Hearts | Clubs | Spades
   data Number =
     Ace | Two | Three | Four | Five | Six | Seven | Eight | Nine | Ten |
     Jack | Queen | King
   data Card = Card Suit Number
So Suit and Number are enumerations, and Card is a record with two
fields. The record syntax is probably the most perplexing part. I'm
using positional fields - which is common when there are very few fields
- but you can also use named fields:
   data Card = Card {suit :: Suit, numer :: Numer}
I should probably have thrown it into the tutorial, but "thing :: type"
is how you write explicit type signatures in Haskell. And you can do
 > 5 :: Int
 > 5 :: Double
 > 5 :: Rational
 > 5 :: Word64
 > 5 :: Complex Float
Unlike Java, "5" can represent any possible numeric type. Usually
Haskell deduces which type you want automatically (or makes it
polymorphic). The web interpretter seems to default to
arbitrary-precision integers - which is reasonable.
(Similarly, "5.3" is any fractional type - Float, Double, Rational, etc.)
> of "Cards" to represent a group of cards that someone was holding (say 5
> cards).
Sure, that'll work. Other representations are possible.
> How would you then check to see if any two cards in that list
> were the same value, or all the same suit, etc?
By default, you can't compare values. That's because it's possible to
define how to do comparison. (E.g., your data structure might have
several equivilent representations for the same thing, and you want
these different representations to be considered "the same".) However,
in the common case that you just want to do a vanilla structural
comparison, you just add "deriving Eq" to the end of the type definition.
Once you do that, you can write things like Hearts == Clubs (which is
obviously going to give you "false"). (By a similar arrangement, you can
auto-define comparison as well. The compiler uses the order you listed
the values in. Might be useful for deciding which card is "higher".)
Now, if you've used named fields, then "suit" and "number" are not only
field names, but also implicitly-defined functions that take a Card and
return the appropriate field. So "suit card1" tells you the suit of
whatever is in card1.
Are all the cards the same suit?
   length (group (map suit cards)) == 1
(This could be inefficient if "cards" is huge, but for a hand of 5 or 7
cards, it should be fine.)
First, you extract a list of suits. Then you group this list into a list
of sublists, such that each sublist contains only identical suits. If
*all* the suits are the same, clearly you will have exactly 1 sublist.
(Equally clearly, if you have 1000 cards, alternating between Clubs and
Spades, you will get a list with 1000 1-element sublists, which length
will have to completely traverse before giving you an answer.)
You can use pattern matching to solve the inefficiency, but due to the
limitations of the web interpretter, it's bloody awkward to demonstrate
pattern matching. So I haven't shown that to you yet.
> mandelbrot in 1-line :-)  Haskell should be a doddle - at least you
> stand to pick up bits and pieces based on English, rather than just
> almost random single characters for everything!
LOL! OK, well if you put it that way...
Although even Haskell has a few "interesting" symbol choices. ">>="
leaps to mind, but you might also mention "$", "&&&", ":" and so on.
Date: 4 Mar 2010 05:47:32
Message: <4b8f8fc4@news.povray.org>
So what's the preferred way to cope with runtime "errors" like that? (I
don't know if there is a technical term for such kind of errors that don't
actually make an error, if you know what I mean).  I suspect in a lot of
case some very low nested function detects an error, and needs to signify
this to a much higher level calling function (eg a "ParseFile" or
"ParseLine" function or something).
> So Suit and Number are enumerations, and Card is a record with two fields.
> The record syntax is probably the most perplexing part. I'm using
> positional fields - which is common when there are very few fields - but
OK, so I could also do something like:
data myRecord = myRecord {age :: Int, height :: Double, weight :: Double}
So in my example, if I had a list of myRecords, then "age MyList" would
return a list of ages?
> Then you group this list into a list of sublists, such that each sublist
What does the "map" do?  Clearly I need to download the proper
interpretter/compiler to answer these questions myself with a bit of playing
around :-)
OK so after Googling Haskell, implementations, GHC, go to the GHC page,
latest release, "STOP!" they recommend I get the Haskell Platorm instead, oh
goody a .exe installer link :-)  I'll let you know in 54 MB time how I get
on...
Thing is it's very rare that I find myself wanting to write something that
*I* think would be easier/faster with a language like Haskell.  But as I
don't really know much about the language, I'm not a very good judge.
You're also quite good a writing tutorials, you should definitely write a
book.  Haskell for Imperative Programmers.  :-)
Date: 4 Mar 2010 06:16:57
Message: <4b8f96a9$1@news.povray.org>
> don't actually make an error, if you know what I mean).
The correct thing to do here would be
   choose n k
     | n < 0     = error "choose: negative n"
     | k < 0     = error "choose: negative k"
     | k > n     = 0 -- According to Wikipedia.
     | otherwise = (factorial n) `div` (factorial k * factorial (n - k))
(You would also define it to accept only unsigned integers as arguments,
which neatly does away with most of the error checking.)
> I suspect in a
> lot of case some very low nested function detects an error, and needs to
> signify this to a much higher level calling function (eg a "ParseFile"
> or "ParseLine" function or something).
The standard idiom in Haskell is this:
- If it's a program bug, use the "error" function. In particular, if a
function is called with invalid arguments, this is probably a bug in the
caller.
- If it's a routine, expected occurrance, return a data structure which
indicates success or failure. For example, a parse failure is totally to
be expected, so we need to explicitly handle it. The error is returned
"as data". (This is where the "error monad" comes in...)
The "error" function, technically speaking, throws an exception. Other
actions (generally only I/O operations) may also throw exceptions, and
Haskell has the usual exception-catching machinery. (Although things
like "catch" are library functions, not language constructs.)
Yes, that'll work.
(Actually, I'm lying. The type name MUST begin with a capital letter.
This IS enforced by the compiler.)
The catch: Each field name is also a function name. Therefore, no two
types can have fields with the same name. (At least, not in the same
scope. Obviously types defined in different files can.) This restriction
becomes quite tedious at times.
>> 7 cards, it should be fine.)
No. "map age mylist" would though. You need "map" to apply "age" to
every element of the list.
(And variable names MUST begin with a lowercase letter. The compiler
will complain if they don't.)
See above. ;-)
> instead, oh goody a .exe installer link :-)  I'll let you know in 54 MB
> time how I get on...
Yes, it's... a tad large. It *does* contain a complete copy of GCC, gas,
ld, perl.exe (?!) and a big suite of precompiled libraries, with HTML
documentation, a profiler, a debugger...
Background: Installing GHC used to give you a complete environment. But
the GHC guys don't want to maintain a complete environment, they want to
maintain GHC. So now the Haskell Platform exists, and the HP guys work
on HP, so the GHC guys can focus on just GHC. The idea is that HP will
grow to provide more stuff. Currently there's not actually much
difference. Follow all that?
Oh, and yes, GHC has *always* been big. You just want to play with
Haskell, but what you're downloading has all sorts of bells and whistles
that you won't use. There's a powerful parser library, cutting-edge
parallel processing technology, a complete OpenGL binding, POSIX
bindings, cross-platform filename processing... need I continue?
> that *I* think would be easier/faster with a language like Haskell.
Well, yes, it completely depends on the kind of code you want to write.
If you want to write, say, a computer game, Haskell probably isn't the
best choice. In C or C++, you can probably just download a game engine
and start coding. In Haskell... there's an OpenGL binding? I guess that
helps? But it's going to take a loooong time to get to a full-featured
game from there!
Personally, I tend to write crazy algorithm stuff. Haskell is great for
that, even if performance is a little unpredictable.
> But
> as I don't really know much about the language, I'm not a very good judge.
Well, yeah. That's kind of what's exciting about the web interpretter,
unfinished as it is. Now anybody can play with Haskell and do basic
stuff without... waiting for a 60+ MB download. ;-)
> a book.  Haskell for Imperative Programmers.  :-)
Heh. I've attempted to write *several* Haskell introductions. Roughly
once every 2 months I start writing a new one. They never get finished.
Trouble is, lots of Haskell's features depend on Haskell's other
features, so... where do you start? Which thing do you explain first? I
write an example, and then I go "oh crap, that uses X, I haven't even
mentioned that yet. Bugger!"
It's not complicated, it's just difficult to decide where to begin.
But thanks for your encouragement. Go take a look at the other thing I
just posted. ;-)
Date: 4 Mar 2010 06:48:54
Message: <4b8f9e26@news.povray.org>
Invisible wrote:
> Of course, it's still alpha quality.
Strike a light... It seems the bit "alpha" sticker has gone. And the
command history seems to work properly now. Neat...
