POV-Ray : Newsgroups : povray.off-topic : Why is Haskell interesting? Server Time
26 Jun 2026 07:16:08 EDT (-0400)
  Why is Haskell interesting? (Message 71 to 80 of 87)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Why is Haskell interesting?
Date: 2 Mar 2010 12:14:26
Message: <4b8d4771@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   *That* is the beauty of encapsulation.
> OK. So you agree that Python also has encapsulation?
  Does the compiler enforce it?
> >   Do you really think that the compiler telling you "you must not access
> > this member, I refuse to compile it" is not a better way to enforce
> > encapsulation than just some documentation that nobody is going to read
> > anyways?
> Not if you're not going to enforce it the other ways as well.
  Right. So if it's possible to modify the data by having some wild pointer
bug in the program, then it's not worth having compiler checks at all and
just have everything public.
  As you said, we'll just have to agree to disagree.
> >   If you must have "visible" members in the class declaration for technical
> > and/or efficiency reasons, it's better if the compiler offers a tool for
> > telling the user "even though you can see this you really shouldn't be
> > referencing it directly" rather than relying solely on a comment line.
> Sure. What about a naming convention that "comes with the language"? I.e.,
> not just a naming convention you made up, but one in common for every single
> program written in the language from day one?
  By that reasoning you could argue that C is an object-oriented language.
After all, you can get OO'ish behavior if you follow certain coding
conventions.
> >   So yes, it's much better if the compiler tells the user he is accessing
> > what he shouldn't.
> I agree it's better. But since you seem to like binary definitions, and you
> don't like me saying "C++ has a little bit of encapsulation but not much",
> I'm curious if you think that (say) Python has encapsulation, given that
> everyone knows that names with _ are private to the class they're in?
  How is it encapsulation if everything is public?
> >   But where do you draw the line between what is and isn't encapsulation?
> I don't make it a binary choice. I say "C has no encapsulation, Python has
> very little (more modularity than encapsulation), C++ has a little more than
> Python (because the compiler refuses to compile stuff that violates the
> language rules)
  That actually contradicts what you said originally. Originally you said
that C++ has *no* encapsulation. Clearly you were drawing a clear line
somewhere.
> >> In contrast, C++ has well-defined mechanisms for bypassing the encapsulation
> >> that are used as a normal part of programming in that language.
> >   Actually it doesn't. You can read the binary representation of an object
> > in memory, but the standard gives no guarantees as to which byte means what.
> I don't believe that's true. It certainly wasn't in C.
  What wasn't in C?
  As for the C++ standard, it does certainly not give any guarantees about
the bit representation of objects in memory. It's implementation-defined.
You can read the bits, but there's no guarantee about their meaning (nor
that the meaning won't change from class to class).
> > The memory layout of objects is completely implementation-defined
> Nonsense. Arrays are contiguous.
  Arrays are not objects. Arrays are a collection of objects.
> The elements of a structure are all between
> &x and &x + sizeof(x).
  No, they aren't. The standard doesn't specify how much padding there may
be between struct elements. The compiler can add as much padding as it wants
(or none at all).
  Also, the standard doesn't guarantee that the first member of a struct
starts from the same memory address as the struct instance itself. (In
practice this can actually differ if the struct has virtual functions.
In that case the pointer-to-struct-instance will not point to the first
member of the struct. There will be some implementation-dependent vtable
pointer there instead.)
  If a member is private, you have no safe, portable way of accessing it
from the outside.
>  There's lots of guarantees. And I'm pretty sure that
> if you have "struct x {int a; int b} y;" that the standard guarantees
> &b > &a.
  Probably, but if a and b are private, you have no portable way of getting
an address to them. You don't know the offset.
> Positive integers are represented in twos-complement coding.
  I'm not completely sure the standard guarantees that.
> Unsigned integers occupy the the number of bits indicated by multiplying
> sizeof(unsigned) by bits_per_char or whatever the appropriate #define is.
  Well, duh, because sizeof(type) is *defined* as telling the amount of
bytes that the type requires.
  That still doesn't help you accessing private data of an object portably.
> Now, if you're going to argue those guarantees don't count, Ok.
  Don't count to what? The issue was whether it's *well-defined* to break
encapsulation in C++. Your own words.
  It's not well-defined. You can try, but the results are not guaranteed.
> >   The standard allows doing that even if it's undefined behavior simply
> > because imposing restrictions on that would mean that compilers would
> > have to generate significantly less efficient code even for programs
> > which don't even attempt doing that. Many people don't mind.
> Can I get you to come work for my company? :-)
  You mean C++ is causing problems there?
  I suppose I should consider myself lucky in that I get to work in
projects where I don't have to go fixing existing code made by incompetent
C++ programmers...
Date: 2 Mar 2010 12:55:34
Message: <4b8d5116$1@news.povray.org>
Well, sure, it's a little bit better. Not a whole lot better. As I said,
it's a sliding scale.
For me, not sufficiently important that it's worth worrying about. The fact
that I can use a pointer to step through the data of a class with private
members is no better than the fact that I can iterate over the members of a
Python instance by groping thru the hash table that implements it.
> conventions.
Well, that's what I'm asking. I find it odd that "encapsulation" covers
exactly everything that C++ does, no more no less.
>>> what he shouldn't.
A language construct that facilitates the bundling of data with the methods
operating on that data.
Again, it's the definition you pointed to.
> somewhere.
It has so little encapsulation (in the "restricting access" part of the
definition) that it might as well not have encapsulation. If you're talking
about the data hiding part, I'd say that unsafe languages don't have that.
Many have the other "bundling data and code" kind of encapsulation.
In other words, I find that marking something as "private" doesn't give
significantly more protection to private data than marking something with an
underline does in Python, in practice. In practice, both are trivial to get
around, accidentally or on purpose.
>   What wasn't in C?
That the standard said there's no guarantees as to which bytes mean what or
how things are laid out in memory.
Funky. I was pretty sure at least unsigned had a guarantee that they were
represented in two's complement binary (e.g., that the bit pattern 0x11 was
the integer value 3).
Yeah, I figured that would be your answer.
> (or none at all).
That doesn't invalidate the formula. I didn't say there was nothing else there.
I didn't say that it did.
Wasn't one idea of C++ was that structs without vtables would layout the
same way as C structures?
> from the outside.
Right. But I'm not talking about the safe parts. :-)
In any case, yes, there is, because the class can return a pointer to the
private variable. You might say "that means it's not private any more", but
it's still accessing the program's private variables. (Uh, that *is* legal
in C++, right? Returning an int* that points to a private instance variable?
If not, then color me suitably impressed. :-)
>> &b > &a.
You do inside the class. :-)  And besides, I'm just disputing your assertion
that the language makes no guarantees about the layout of data.
I've worked with languages that make *no* guarantees about the layout. Where
the lowest bit of *every* integer was 1, regardless of its value. Where
pointers have reference counts and type flags in the high bits. Stuff like that.
Trust me, C++ makes some guarantees. :-)
Yes. And then you multiple by bits_per_char to find out the range, which
means unsigneds don't have padding in the middle, for example.
That's not what I'm discussing at this point. Besides, you can *access* them
portably. You can't *interpret* them portably, perhaps, if the structure is
complicated enough.
Don't count the guarantees I listed. You said "C++ makes no guarantess on
layout" and I listed a bunch it makes.
And breaking encapsulation is portably accessing private members from
outside the class. Which I can certainly do using memcpy for example.
So write(out, &xyz, sizeof(xyz)) where xyz is a class or struct with private
members might actually crash?
memcpy(myarray[0], myarray[1], sizeof(myarray[0])) isn't well-defined?
There's no meaning for that statement when myarray[0] is a struct with
private members?
Regardless of whether you know which private variable is laid out where,
you're still "accessing private variables" in ways that more secure
languages disallow.
Oh, you wouldn't believe. Not C++ per se, but unsafe languages in general,
poorly organized and badly documented.
> C++ programmers...
Yep. Well, honestly, the whole development chain is screwed. Not only is the
code buggy, but the authors are unwilling to fix it, describe it, document
it, or really take any responsibility at all for its sorry shape.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 2 Mar 2010 14:36:31
Message: <4b8d68be@news.povray.org>
  Only if you ignore the data hiding part, which is essential for
abstraction.
> > somewhere.
  You are exaggerating. On purpose.
  You can't bypass the access rights in C++ if you want to write a program
which is correct and portable. If you try to bypass it, your program will
not be portable, will be against the standard, and thus incorrect. C++ allows
you to write incorrect programs which will compile and run (on one given
system) for efficiency reasons, but that doesn't make the program correct.
  That's a *completely* different thing than having everything public and
only using a naming convention to denote "private" members. If the member
is public, then there will be a 100% correct way of accessing it from the
outside which is not implementation-defined.
  There's a huge difference. You make it sound like there was no difference
at all. Just for the sake of argument.
> >   What wasn't in C?
  I don't think the C standard guarantees how much padding there will be
between members of a struct either. The bit representation of a struct
instance may change from system to system, and even from compiler to
compiler, and hence you must not make assumptions if you want your program
to be portable.
  (Moreover, C doesn't guarantee endianess either.)
  An unsigned is not an object, mind you. (We are talking, after all, about
accessing the private members of an object. An unsigned integer has no such
thing.)
  Also the standard doesn't guarantee word endianess, so the bit pattern
may actually differ from one system to the next even when we are talking
about unsigned integers.
> > (or none at all).
  So you said that "a given type, all by itself, will require sizeof(type)
bytes of memory". Well, duh, that's how sizeof() is defined, after all.
  However, the subject in question here is objects and accessing their
private members. You have no portable way of knowing the offset of members
inside objects because their layout is not guaranteed. The first member
might not start from the same address as the object's pointer, and the
amount of padding between members is implementation-defined. Just because
you know that a member requires n bytes of memory doesn't help you much
in resolving its location inside the object.
  (That doesn't mean you can't have a pointer pointing to a member of an
object, in a portable way. However, that requires either for the member
to be public or for the object to give you the pointer.)
  But we are talking about accessing private members here.
  But the C standard doesn't give guarantees about padding between members
either, AFAIK.
  Of course if the object exposes the private member in its public interface,
then the outside can have access to it. Returning a reference or pointer to
a member exposes it to the outside.
  (There's still the minor difference that it's slightly more abstract than
having the member in the public part of the class in that you could change
the method to return a reference/pointer to something else.)
  It is possible to return a pointer to a member variable. (It's generally
regarded as bad design, though. Returning a const reference is a borderline
case, though. Sometimes used because returning big members by value can be
quite inefficient.)
> >> &b > &a.
  "From the outside" implied that the struct doesn't want to expose them.
  Well, it doesn't. Not any that would help you accessing them from the
outside if they are unexposed.
  (Btw, I didn't mean "doesn't give any guarantees whatsoever". I meant
"doesn't give any guarantees that would help you resolving the address of
a private member from the outside in a portable way".)
  But if you had, for example, an array of two unsigneds, I'm not sure the
standard guarantees they will be at consecutive memory locations, with no
padding between them. (I could be wrong on this one, though.)
  Not that any compiler in the universe would put padding between them,
mind you, but it's probable that the standard doesn't *force* compilers
to not to use padding (eg. because an exotic hardware requires it).
> complicated enough.
  Well, if "access" means "reading their bit pattern in memory", then yes,
you can "access" them portably.
  The context in which I said it implied "no guarantees which would help you
resolve the address of a member variable from the outside".
  What you are using with memcpy is copying the bit pattern of the object
as it is stored in memory. It's arguable whether that's "accessing the
private members" of an object.
  To me, accessing means that you actually read (or even write) a private
member variable and write code which depends on it. You can't do that with
memcpy because it doesn't tell you the value of *that* member variable in
question. It only gives you the byte data of the entire object. You can't
start interpreting that byte data in a portable way.
  Exactly which member variable did you just access? "All of them" isn't an
answer.
  What you did was take the bit pattern of the object in memory and write
it somewhere.
  Only in a very limited set of cases, actually. If myarray consists of
class instances, the result is undefined behavior (because you are
bypassing copy constructors).
  With basic types it's well-defined, and maybe for PODs with trivial
constructors and destructors.
> private members?
  It depends on what kind of constructor/destructor/copy constructor the
struct has.
> languages disallow.
  Well, C++ doesn't stop you from reading the bytes of an object in memory.
Nobody is denying that.
  Whether that constitutes "accessing a private member" is arguable.
  Safe languages never cause problems, then?
  (If I'm to believe thedailywtf.com, I don't think that's the case either.)
> > C++ programmers...
  I'm not sure using a "safe" language would fix those problems either.
Date: 2 Mar 2010 17:23:18
Message: <4b8d8fd6$1@news.povray.org>
> abstraction.
Really, Python isn't noticeably less private than C++. C++ shows you
everything. The compiler says "don't reference that by name", instead of the
IDE doing it.
I disagree. I'm simply expressing an opinion that differs from yours. If I
know something is private, I don't try to access it.
Again, I disagree. I disagree that C++ refusing to compile when you access
by name something marked as private is significantly more encapsulated than
Python's naming convention that you shouldn't access fields marked with an
underscore by name.
In practice, I disagree. I recognize the difference. I'm just of the opinion
that the difference is so small as to be irrelevant. You think that having
the compiler complain is important. I don't.
Do you think Java doesn't have private members because there's a way of
accessing them via reflection?
> to be portable.
Right. But that's far from "makes no guarantees" you see. You often make a
broad sweeping statement, and when I call you on it, you backpedal and then
say I'm exaggerating "on purpose".
>>> (or none at all).
You said "there are no guarantees". I said yes, there is at least the
guarantee that the elements of a class even with private members are laid
out in the space between the start and the end.
What you mean to say is "there aren't enough guarantees on layout to ensure
that you can do something reasonable in a portable way by breaking
encapsulation."  That's far different from "there are no guarantees."
You exaggerate, on purpose. ;-)
Yep. Fully agreed.
I can still do that. I can't do something *useful* with them, but *in
practice*, I can zero out your object by mistake. You may discount that as
irrelevant, but I don't. I don't think that any amount of definition
wrangling is going to resolve *that* disagreement.
Unsafe languages don't keep code from accessing your private variables. They
keep you from reliably portably accessing private variables in a correctly
written system where every piece is bug free.  You're taking the latter to
mean the former. I'm not.
See what you did there?
OK. I'll agree with that. :-)
I'm not sure.
Certainly there are machines where floats, for example, need to be on
particular boundaries and which might not be packed to those boundaries.
Stupid design, but conceivable. :-)  Of course, on such machines, you
usually can't get a C compiler.
And, as I said, you can overwrite them, which *I* feel violates
data-security encapsulation.
OK. And to me, "accessing" means reading it or writing it without going thru
the interface defined by the class.
Fair dinkum.
And for structs or classes with no vtable, as those are defined to have the
same layout as in C, and it works in C, yes?
Right. I think it is, because if you can change the values of my private
variables without going thru my member functions, I have no way of enforcing
my code's correctness or my invariants.
Safe languages merely make it easier to prove who has the bug. It also tends
to catch the bug when (say) you open the file, instead of 10 minutes later
when you try to parse what you read from it.
Not completely, no. But at least you could assign blame. Right now, if I
write code that invokes their libbrary and it segfaults, yet it doesn't
segfault in their trivial test application that only ever invokes one
operation in the library before exiting, then it must be my fault.
In a safe language, you could say "Look, it throws an exception in your code
. Find where that exception is, and see what causes it."
Date: 2 Mar 2010 17:29:34
Message: <4b8d914e$1@news.povray.org>
> the IDE doing it.
Or, to phrase it a different way, I've never had a problem caused by someone
intentionally accessing a private member in a Python-like environment that
would have been solved by making the code not compile when that happens.
I have never known someone to accidentally reference x._y and think they
were supposed to be accessing _y as a normal part of the functioning of the
program.
Have you ever known someone to accidentally name a C function __XYZ__ and
not be aware they might be stepping on the compiler's namespace? Is it
really a problem that the compiler doesn't prevent you from using names like
that?
Date: 2 Mar 2010 18:15:54
Message: <4b8d9c2a$1@news.povray.org>
Actually, just thinking about it a bit more, if the class returns a pointer
to a member variable, and you can look in the header and see that pointer is
in an array, then you have a well-defined way of accessing the other private
data in the same array.
Like, if the class returns a FILE* from open(), and you look in the class
declaration and there's something along the lines of
    FILE open_files[MAX_OPEN_FILES];
then chances are you can wander up and down that array as you like. :-)
I wouldn't say that particularly breaks encapsulation tho. Just a thought.
Date: 2 Mar 2010 18:32:56
Message: <4b8da028@news.povray.org>
> underscore by name.
  Then show me correct C++ which reads a certain private member variable of
a class, eg. by reading its value to a variable of the same type, without
the class deliberately exposing it. (Note that the class may have eg. virtual
functions.)
  In practice? Well, then show me in practice. Some actual code, please.
> > to be portable.
  You are calling me a liar now? Like, when I said "the standard offers no
guarantees about the layout of a class" I was really meaning "the standard
offers no guarantees whatsoever about the memory layout of any type" rather
than "the standard offers you no guarantees about the layout which would
allow you to access the private members of a class", but later I claimed
otherwise? I was always talking about accessing private members and why
you can't access them in a portable way. Calling me a liar is offensive.
  I might well claim that you "backpedaled" when you first claimed that
C++ has *no* encapsulation, and later changed it to "little" encapsulation.
  I was talking about the memory layout of an object. There *are* no
guarantees about it.
  You seriously don't understand the difference between "size" and "layout"?
  Then, as said in earlier posts, there are no languages with encapsulation
because you can't physically protect data from being corrupted. There can
always be a glitch somewhere that corrupts it.
  (By your principle of "if it can't be protected from everything it's not
worth protecting at all", all these "safe" languages are useless. They can't
protect themselves from everything, hence why try it at all? Better, to just
go back to C, then. No useless protection there.)
  No, if they or any of the members have a non-trivial copy constructor.
  You don't use a debugger to resolve where the crash happens?
Date: 2 Mar 2010 18:37:32
Message: <4b8da13c@news.povray.org>
> > the IDE doing it.
  And I have never had a problem with a wild pointer modifying the private
members of a class either.
  Is your anecdotal evidence better than mine?
  Actually it's quite common in C and C++ out there to have names starting
with underscore even though the standard says it shouldn't be done.
> Is it
> that?
  Well, it is quite a common objection in C++ groups when people post code.
Date: 2 Mar 2010 18:39:35
Message: <4b8da1b7@news.povray.org>
  Only if you also know which array element it's pointing to. (If you know,
then the class is, effectively, exposing the entire array.)
Date: 2 Mar 2010 19:05:41
Message: <4b8da7d5@news.povray.org>
>> underscore by name.
> functions.)
Do you understand what I mean by "significant"?
Look, you understand what I'm saying, I'm sure. I understand where you're
coming from. Now you're just trying to tell me my opinion of what's
important is incorrect, simply because you don't find it to be important.
*I* just don't see any practical advantage of having the compiler enforce
that. You gave an example from your function library. I contend that the
same thing could have been done with Python's level of encapsulation. It
would be no more of an error for me (say) to change how variables that start
with "_" work than it would be for you to change the size of the class you
wrote.
*Correct* Python code doesn't rely on "_" members remaining the same from
one release of code to the next. Just because the compiler doesn't enforce
it doesn't mean it's "correct".
For what, writing to private variables, or reading from them?  In practice,
bugs clobber data they shouldn't in unsafe languages.
No. Merely noting a trend. You don't always say precisely and clearly what
you mean, and when I give counter-examples, you clarify and then act
indignant that I addressed what you said instead of what you meant.
I did indeed. It has a small amount of encapsulation, but not enough (IMO)
to be significant. I granted you that one.
Yes, there are. There's even one I pointed out to which you said "Well, duh,
that's the definition."  Remember?
You weren't talking about "guarantees about the memory layout of an object."
You were apparently talking about "guarantees about the memory layout of an
object that would let you safely and portably access private member
variables of an arbitrary class without invoking undefined behavior."
And *I* am saying those qualifiers reduce the utility of the form of
encapsulation that C++ provides.
I do. Do you seriously tell me that knowing there isn't data from another
object between the lowest-addressed private member and the highest-addresses
private member isn't a guarantee about the layout of the data of a class?
If I take the sizeof a child class, it's always going to be at least as
large as the sizeof a parent class. If I have a class with two members of
class X, it's going to be at least twice as large as class X, even if that
means there are two vtable entries where one would be enough. If I have
class X that inherits multiply from class A and class B, I know that I can
take a pointer to class B and not worry that there are bits of A mixed up
inside.
What you're seeing as "so obvious it doesn't need to be mentioned" is
exactly what I'm saying are the guarantees. :-)  These sorts of things
certainly aren't guaranteed in any number of other languages. (For example,
IIRC, member variables in C# that are shared amongst multiple lambda
expressions in the same class wind up being allocated in an area outside
what would be the "sizeof" area of an instance of the class they're declared
in, because they have to outlast the actual instance variable.  Again, IIRC.)
I'll grant you that there are no language implementations on real computers
that guarantee 100% encapsulation. However, that doesn't mean that any
amount of encapsulation is equivalent to any other amount.
What's more isolated? A thread, or a process, or multiple independent
processes all running in the same address space? Well, certainly, if all
your code is 100% correct, you don't need separate processes at all, right?
All you have to do to keep from having to reboot your 8086 is just write
correct code, and no problem.
You may argue that encapsulation hasn't anything to do with correctness. I
disagree. That's OK. We can agree not to agree on that point.
That's not my principle. My principle is "if you write your combination on
the outside of the lock, it's not a very secure lock."  Sure, it has all the
attributes of a good lock, and it might be impossible to pick, but I'll take
the one that doesn't come with the combination painted on it.
That's the thing, see. When someone comes along and stomps all over the
stack, you can't really prove what's happening very easily, even with a
debugger.
I suppose if we went out and bought a few hundred thousand dollars worth of
hardware debugging hardware, JTAGs and stuff like that, we could find who is
writing outside the stack. Unfortunately, clobbering stuff you shouldn't
clobber doesn't really cause a detectable error until much later sometimes.
More importantly, there's no way to ensure that *your* code isn't clobbering
*their* code, so there's always an excuse not to look at it if it works for
their test code.  I.e., if there's a bug in my code that clobbers their
private/static variables before they even get called, the same symptoms
might manifest.
Unfortunately, running a device driver under a debugger works poorly without
hardware support. Plus, we barely fit the system under test in the address
space, let alone the debugger as well.
Apparently the entire industry is this screwed.  Which would certainly
explain why in the time the phone system has evolved from cell phones that
take two hands to carry into iPhones, the set top box industry still can't
get digital video or even web pages onto the television.
