POV-Ray : Newsgroups : povray.off-topic : Why is Haskell interesting? Server Time
26 Jun 2026 05:23:02 EDT (-0400)
  Why is Haskell interesting? (Message 61 to 70 of 87)
Subject: Re: Why is Haskell interesting?
Date: 1 Mar 2010 15:02:44
Message: <4b8c1d64@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >> Let's ask this: Why doesn't C++ have encapsulation?
> >   Clearly we have a different definition of "encapsulation".
> I explained why encapsulation is important and why unsafe languages don't
> have it.  What's your definition of encapsulation, and why does it make a
> difference to the programming productivity?
  It seems that in your quest to belittle "unsafe languages" you have taken
some obscure definition of a term somewhere, treat it as if it was the
unversally accepted definition, and point out how your beloved "unsafe
languages" don't conform to that obscure definition.
  Encapsulation in object-oriented languages is not *my* definition:
http://en.wikipedia.org/wiki/Encapsulation_%28object-oriented_programming%29
  Nowhere do I see anything related to what you wrote.
Date: 1 Mar 2010 16:04:09
Message: <4b8c2bc9$1@news.povray.org>
Not at all. I'm simply explaining why safety is important to encapsulation.
Do you think Python encapsulates data?  If so, then C++ does too.
If you think Python insufficiently protects its data, then neither does any
unsafe-by-default language.
The whole "information hiding" bit, for one.
Under this definition, encapsulation means that the internal representation
of an object is generally hidden from view outside of the object's definition.
C++ fails this. Internal representation is in the header file. But that's
not what I'm talking about.
Typically, only the object's own methods can directly inspect or manipulate
its fields.
All unsafe languages fail this.  (Lots of safe languages do too, with
appropriate declarations of their unsafeness.)
Hiding the internals of the object protects its integrity by preventing
users from setting the internal data of the component into an invalid or
inconsistent state.
Unsafe languages fail at this. Either that, or you have never ever
encountered a wild-pointer bug. The fact that you don't frequently violate
encapsulation doesn't mean that encapsulation is enforced, any more than the
fact that people don't usually screw around with the internals of Python
instances doesn't mean Python has good encapsulation in that sense.
In theory, yes, if you don't violate the language mechanisms, then C++
provides encapsulation. In practice, it doesn't, because when some value in
your object is randomly changed by a bug in some code running in other
thread, you're fairly well screwed in terms of figuring out the
encapsulation.  That is, pretty much, the difference between safe languages
and unsafe languages: Safe languages *enforce* encapsulation. (And again,
most safe languages allow you to circumvent that by dropping into an unsafe
subset, but some don't.)
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 1 Mar 2010 16:42:15
Message: <4b8c34b7@news.povray.org>
  "Data hiding" doesn't mean "hidden from the programmer", but "hidden from
the outside scope". In other words, code out of the scope of the class has
no direct access to the internals of the class (in other words, you get a
compiler error if you try to access).
  You could as well argue that if you had an open source library in a language
with true data hiding (by your definition of the term), it stops being data
hiding because the programmer could just look at the source code of the
library and see the internal structure of the objects. Just because the
programmer can see the internal structure of the object doesn't stop it
from being data hiding.
  The purpose of encapsulation and data hiding is not to obscure information
from the programmer, but to offer an abstraction tool for the program design.
(In that way "data hiding" is perhaps slightly a misnomer, and something like
"scope access restrictions" would be better.)
  In other words, if you want to keep a good abstraction level in your
program, if something is marked as "private" then that something doesn't
interest you unless you are actually implementing the class which owns
that private member. Just because the class says explicitly "hey, I have
this private member" doesn't stop it from being encapsulation and data
hiding.
> its fields.
  Now you are deliberately confusing a general non-restriction of memory
access with the concept of data hiding.
  Again, data hiding is a tool offered by the language which you can use
to increase abstraction in your program. Just because the language doesn't
guarantee that modification of random memory locations using wild pointers
will always be caught doesn't make the tool nonexistent. The tool is still
there for you to use, and the compiler will enforce it as long as you write
your code as intended.
> inconsistent state.
  A wild pointer bug is at a completely different conceptual level than
data hiding. Encapsulation exists as a tool for *programming*, not as a
tool for the runtime. If you use encapsulation as intended, and your
program is correct, then the compiler will enforce the encapsulation.
> encapsulation.
  I think that your problem is that you somehow write like having bugs
in your program is some kind of valid programming technique. "Encapsulation
should be enforced even if there are bugs in your program" sounds quite
silly. It kind of implies that "your program should still run ok even if
there are bugs in it".
  Assume that you have a bug in your program in that you forgot to write
"private" in conjunction with a member declaration, making it public.
There's a bug in your program, which made the member accessible from the
outside. By your definition this programming language doesn't enforce
encapsulation because if there are bugs in your program it may allow
private members to be accessible from the outside.
  That's just silly. You cannot define the concept of encapsulation in
terms of buggy programming.
  No, they don't. If you make a programming error and inadvertedly make
a member public, the compiler will do squat about that.
  You are deliberately confusing a programming technique such as
encapsulation with a runtime technique such as memory protection.
Date: 1 Mar 2010 17:22:18
Message: <4b8c3e1a@news.povray.org>
> the outside scope".
Fair enough. If that's how you want to look at it.
The way I see it is that encapsulation is a mechanism to reduce the area you
have to look to understand or use or debug a particular part of a program.
It makes things modular. The less modular changes are, the less encapsulated
the changes are.
If you can't see or access the private variables at all, that's extremely
encapsulated. If you can see and access them only through reflection or
explicitly-declared unsafe operations, that's less encapsulated. If you need
to see them because changes in private parts mean you have to deal with it
in your own code (say, by recompiling or changing the size of structure
declarations), that's also less encapsulated. When a bug in one part of the
program can cause arbitrary changes elsewhere, that's really minor
encapsulation.
I find "the compiler tells you if you explicitly write code that tries to
access stuff you can see but is flagged private" as the weakest form of
encapsulation out there, in terms of "information hiding". Only something
like Python that doesn't even try is weaker than that.
And you understand why I'm disputing that this is the case, right?
*Correct* code has no direct access to the internals of the class *by name.*
Incorrect code has direct access to the internals of the class, and correct
code has direct access as long as it doesn't do so by name. (For example,
   write(outfile, &myInstance, sizeof myInstance);
No. I'm not talking about just the programmer.
That's one of many purposes. I think the primary purpose is not to say "this
is public and that is private", which could be done as easily by a naming
convention or comments, but to also allow for debugging, understanding,
production pipelines, etc.
This abstraction is the only encapsulation that C++ provides, so naturally
that's what you think the purpose of encapsulation is. But there's a whole
bunch of reasons for encapsulation.  Plus, these additional forms of
encapsulation have all kinds of other benefits, which is why (for example)
you don't see applets written in C++.
Now who is changing definitions? :-)
And in Python, if a variable name starts with _ then that variable doesn't
interest you. Does that mean Python has encapsulation like C++ does?
In languages where the private variables aren't exposed at all, this
question doesn't even come up. So C++ (and Ada, and the other languages that
increase efficiency by exposing the private declarations to client code)
isn't even very good at this. You wouldn't even *need* a "private"
declaration in the header file but for that. It wouldn't be a case of "the
compiler tells me that's private" as much as "the compiler tells me that's
not a member of the class."
No. You're confusing data hiding with encapsulation. You've changed the
subject from "encapsulation" to "data hiding", because data hiding is the
*only* kind of encapsulation C++ supports.
If you asked me if C++ supports data hiding, I would have said "Yes, poorly,
because you can see what's there and have to deal with it, but the compiler
enforces the private keyword."
I told you why encapsulation is important, listing several reasons. Data
hiding is just one of them.
That's correct. But that's not all that encapsulation encompasses. "Data
hiding" is not the only thing that encapsulation provides.
>> inconsistent state.
> data hiding.
Yep. Not the point tho. It's at a different conceptual level, which is
exactly *why* it is so hard to debug. You can't look at the assignments to
the variable and figure out which one might have set the denominator of your
Fraction class to zero.
Look, I'm just going thru the definition *you* pointed me at and showing
that unsafe languages don't meet the definition.
You don't need to hide the internal variables to prevent someone from
setting them to an invalid state. For example, Eiffel has clauses in the
source code that describe the valid states of internal variables, so you
could in theory check at each assignment that nobody outside the class is
breaking the internal consistency.
The only way in which hiding data prevents the consistency from being
corrupted is if it's actually inaccessible when it is hidden. Unsafe
languages fail at that. You can clobber and make inconsistent data that is
hidden at the "conceptual level" of the language.
I disagree. Considering what the compiler does without considering what the
runtime does says little about your language. You're the one that says C++
is superior to Java because of the runtime.
Runtime encapsulation is what made Java popular in the first place. Indeed,
runtime encapsulation was pretty much the entire point of Java's development.
I already granted that "if your program is correct" then C++ has a minimal
level of encapsulation. That's not really saying much, tho. "If your program
is correct" in Python, you don't screw with publicly-accessible members that
aren't documented.  That doesn't mean Python has as good encapsulation as
C++ does.
No. I write like someone who codes against libraries built by people who
aren't as good a programmer as I am. We're long past the point in computers
where people run "their program" in an environment where every bug is
guaranteed to be their own.
Heck, even *with* the runtime encapsulation that Javascript enjoys, people
*still* run separate tabs in separate processes.
> "Encapsulation
> silly.
Tell that to people running Java applets in their web browser. I mean, isn't
that basically the difference between Java applets and ActiveX?
You know something? There's an awful lot of software that falls into this
category. Know why? Because programmers aren't perfect.
Not at all. The difference is that when I go to my class where the problem
manifests as incorrect data in instance variables, and I look through the
code that references those ought-to-be-private variables and see that none
of them set it wrong, and then I look at the declaration and see it's
public, I can change that to private and see who is accessing it that
shouldn't.
On the other hand, when you have a wild pointer bug overwrite my instance
variable, the place I have to look in the code to find that is *everywhere.*
Including code I don't have source for.
You're either trolling me, or you're a really crappy and/or inexperienced
programmer if you don't understand the difference between the scale of
looking for a bug in those two places. The whole *point* of encapsulation is
not to serve as documentation as to what's public and what's private, but to
limit the amount of code you have to look at to understand the behavior of a
given variable.
Yes! You can! That's exactly the point. You're encapsulating who can change
what values, so it's easy to find.
That's like saying "You cannot define the concept of structured programming
based on not executing gotos to arbitrary locations, because if you're
careful with your gotos, it's the same code as structured programming."
Sure, that's exactly what it is, because you're *guaranteeing* that the
structure is there. You don't have to check every goto to make sure it's
only a goto from the end of "then" to the end of "else" or some such.
True, but now you're asking the compiler to detect errors in *correct*
programs, which is orders of magnitude harder than asking the compiler to
detect errors in incorrect programs. There are very few compilers that will
detect that the program doesn't match the spec, altho LOTOS and Eiffel both try.
Not really. Indeed, when taken to extremes, encapsulation enforces safe
language features. By using a "safe pointer" in C++, you've encapsulated the
operations on the pointer and ensure you don't do something like access it
after it's disposed. By using a "container" instead of just an array, you've
encapsulated access to the container's elements and can enforce that you
don't go out of bounds or throw an exception if you change it during
iteration or some such.
Date: 1 Mar 2010 18:16:49
Message: <4b8c4adf@news.povray.org>
> encapsulation.
  You are still confusing a runtime memory protection mechanism with the
programming technique of data encapsulation.
  "A bug in the program breaks encapsulation promises" doesn't imply there's
no encapsulation. It only implies that there's a bug in your program which
makes it misbehave.
  You might argue that encapsulation without runtime memory protection of
the modules is worthless (or at least less useful), but that's a different
thing from claiming that there's *no* encapsulation. Encapsulation is a
programming technique, not a runtime mechanism. The memory protection
encompasses a lot more than just protecting module members from being
trashed.
  You are still confusing runtime memory protection with the programming
technique of encapsulation.
  Suggesting a more descriptive term is not changing the definition.
Data hiding has always been about access rights.
  Does the compiler give you an error if you try to access the private
variable from the outside?
  Where the private members are specified is inconsequential.
  They are used as synonyms, and I'm not the only one to do so.
  As I said, you could as well argue that if you look into the source code
of a library and see the internal structure of the object, it breaks data
hiding and thus the programming language has "poor support" for it.
  Just because the programmer can see what the object is composed of doesn't
mean there's no data hiding. Data hiding is about access rights.
  Your definition of encapsulation is mixed with a runtime mechanism of
memory protection. I don't see that requirement anywhere.
> You're the one that says C++ is superior to Java because of the runtime.
  I don't even understand what you mean by that, or where I have said such
a thing. My complaints about Java are mainly based on its language features
(such as the inability to abstract a basic type away). These are basically
all compile-time features.
  No, what made Java popular was garbage collection (and lacking some
features which some people saw as "bad", such as multiple inheritance).
Also the idea of "write once, run everywhere".
> > "Encapsulation
> > silly.
  Now you are confusing it with sandboxing, another memory protection
mechanism.
  And this is related to the definition of encapsulation how?
> shouldn't.
  Some bugs are easier to find than others. This has what to do with the
definition of "encapsulation"?
  If there's a bug in the operating system which randomly trashes the
memory of a program, does that mean the programming language which was
used to create that program has no encapsulation?
  What if the runtime which executes the program has a bug which trashes
its memory. Does that mean the programming language has no encapsulation?
  If there's a faulty RAM chip in your computer which causes part of the
program's memory to be trashed, does that mean there's no encapsulation in
the programming language?
  You are confusing runtime memory protection with the programming technique
of encapsulation. They are different things.
> given variable.
  And you arbitrarily set the limit of what still constitutes as acceptable
"encapsulation" and what doesn't somewhere between the program's own runtime
and the OS.
  Well, in that case no programming language supports encapsulation, then.
If there's a bug in the runtime which trashes your program's memory, those
private members can be changed.
Date: 1 Mar 2010 19:20:38
Message: <4b8c59d6$1@news.povray.org>
>> encapsulation.
We will have to agree to disagree.
> no encapsulation.
It implies you have very little encapsulation.
Seriously, what is the value of encapsulation if a bug can disrupt it? I've
never found encapsulation in unsafe languages any more useful than a naming
convention is in a safe language.
Note that's a serious question. I'm not mocking or trying to prove a point.
I'm simply trying to figure out why you think "private:" is noticeably
better than a naming convention or documentation.
I'm also seriously asking why you think encapsulation is at all valuable.
What benefit does it give you in practice, that would be difficult to obtain
just by having decent documentation?
There's very *little* encapsulation. There's attempted encapsulation. :-)
> Encapsulation is a programming technique, not a runtime mechanism.
Right. But a programming technique that is designed to make debugging and
understanding the interactions of parts of a program easier yet that doesn't
  actually do so is a poor implementation, IMO.
What do you think is the benefit of encapsulation to the programming process?
I'm just going by the definition you pointed me to. If you want a different
definition, let's see it. Maybe I'll agree with it. :-)
Yes, but we're not talking about data hiding. We're talking about
encapsulation. I'll grant that C++ has a weak form of data hiding, yes.
Probably not. Do you think that would make a difference?  That when you're
typing in the name of the member variable, you don't notice it starts with
an underscore?
Well, I'll have to disagree again there. The fact that you can see them and
access them
Well, I'm making a distinction. You can have one without the other. People
make lots of mistakes by not knowing as wide a range of possibilities as
they should, thinking that (for example) static typing means you have to
specify the types of variables, or that object-oriented means you have
instances of classes, or etc.
Not really, because there are legal and valid ways of getting to those
private variables in C++, guaranteed to work by the language. If the private
variables really were private, you'd have no reason to specify how they're
laid out in memory, since the only code that could get to them is the class
itself.
OK. I disagree, but OK.
There doesn't have to be any memory protection involved. Java doesn't have
memory protection, but applets are encapsulated. Erlang doesn't have memory
protection, but it has encapsulation.
You complain that everything in Java has to be allocated on the heap, for
example. Which is purely a runtime mechanism that has little to do with the
language. (As shown by the newer compilers that don't allocate all objects
on the heap, yet compile standard Java, for example.)
And nobody would have heard of it if it weren't for applets. Trust me on
this one - I was there.
Anyway, Java stuff snipped, since it's irrelevant to the conversation.
Because if your definition only applies to bug-free software, claiming that
your program supports it isn't a very useful property.
Because encapsulation is there to help you find bugs!  It's there to help
you understand the program and to ensure that each piece works how it's
supposed to in isolation. To ensure that testing one piece and seeing that
it works means it works when combined with other pieces.
I.e., that a class is correct as implemented.
No, because that's outside the scope of the programming language's definition.
C++ on the other hand guarantees that you can access stuff by indexing
outside the defined boundaries of objects. Hence the assurance that things
are laid out in the order you declare them, the ability to use write() to
store data from classes into files, etc. ("Write()" still lets you write out
a class, doesn't it?)
No, but it means the encapsulation has failed. It also means that that
particular interpreter does not correctly implement the encapsulation that
the language defined.  You could say that if the JVM randomly scribbles over
private values, then that JVM did not correctly implement Java.
But C++ defines mechanisms for violating encapsulation, both accidentally
and on purpose.
No, it means your computer did not correctly implement the programming language.
I explained how they're not.
Because encapsulation is there to make finding bugs easier.
>> given variable.
> and the OS.
Because the language's runtime is part of the definition of the language.
The OS usually isn't. Sometimes it is, in which case yes, if the OS is
specific to the language you're using, then a failure in the OS is a
violation of encapsulation.
It's not a binary choice. Of course if your hardware fails and changes
random values in your program, then there's a problem you need to track
down. But if you can prove that no method of your class should be changing
one of Java's private variables set in the constructor but it changes
anyway, then you know the code that's broken isn't Java code. You know it's
the OS, or JVM, or hardware, or something.
In contrast, C++ has well-defined mechanisms for bypassing the encapsulation
that are used as a normal part of programming in that language.
Date: 1 Mar 2010 19:58:26
Message: <4b8c62b2@news.povray.org>
  I have found it extremely useful. For example, my FunctionParser library
(which has got some popularity) is, basically, one class with a relatively
brief public interface.
  During its history the library has gone through two major rewrites (the
second one almost completely from scratch, reusing only some portions of
the old version), yet without breaking the public interface and hence the
programs using it. This means that programs which use the library can safely
upgrade to a newer version of the library and still work just fine.
  As you might imagine, the almost complete rewrites have also entailed an
almost complete redesign of the private parts of the class, which have
usually ended up being completely unlike the older versions. The public
interface has stayed almost completely intact (except for some additions
which don't break backwards compatibility), which means that existing
programs don't break.
  *That* is the beauty of encapsulation.
  Of course I'm sure you have some obscure name from some obscure source
for that as well, just for the sake of disagreement.
  Do you really think that the compiler telling you "you must not access
this member, I refuse to compile it" is not a better way to enforce
encapsulation than just some documentation that nobody is going to read
anyways? Given that it's quite easy for compilers to do that, then why not?
  If you must have "visible" members in the class declaration for technical
and/or efficiency reasons, it's better if the compiler offers a tool for
telling the user "even though you can see this you really shouldn't be
referencing it directly" rather than relying solely on a comment line.
  It also makes it clearer in inheritance what the derived class can and
shouldn't access: The base class' private part is private, but it might
offer a 'protected' part for derived classes to use. The compiler then
explicitly checks that this abstraction level is obeyed. Easier and better
than just having some comments saying "this can be be used in derived
classes but should not be accessed from the outside".
  So yes, it's much better if the compiler tells the user he is accessing
what he shouldn't.
  But where do you draw the line between what is and isn't encapsulation?
  Clearly, a C struct offers no encapsulation. Also, clearly, a faulty RAM
chip trashing your program's memory doesn't mean there's no encapsulation
in the programming language. However, where is the line between those two
extremes, where encapsulation becomes non-encapsulation?
  If you call a library offered by the programming language, and that
library is buggy and trashes your program's memory, does that break
encapsulation? What if the library calls a system library (such as clib)
and *that* has a bug which trashes your program's memory? Does that break
encapsulation? What if instead of a language's own library it's a third-party
library? What if the kernel has a bug which trashes your program's memory?
Where exactly lies the line between a bug which trashes the program's memory
not breaking encapsulation, and doing so? And why?
  Actually it doesn't. You can read the binary representation of an object
in memory, but the standard gives no guarantees as to which byte means what.
The memory layout of objects is completely implementation-defined and thus
while you can read the individual bytes of the memory location where the
object is, you cannot safely make any assumptions about their meaning. And
trying to *modify* the memory occupied by the object is outright undefined
behavior.
  The standard allows doing that even if it's undefined behavior simply
because imposing restrictions on that would mean that compilers would
have to generate significantly less efficient code even for programs
which don't even attempt doing that. Many people don't mind.
Date: 1 Mar 2010 20:44:56
Message: <4b8c6d98$1@news.povray.org>
OK. So you agree that Python also has encapsulation?
Certainly that's one form of encapsulation, and indeed, it's a form also
supported by DLLs, client-server architectures, operating systems,
sandboxes, and many of the other things you said weren't encapsulation.
It's also very useful when designing the original program. But it's more the
modularity part than the data-hiding part. In other words, if you go back to
your original wikipedia link, it's the "language construct that facilitates
the bundling of data with methods operating on that data", not the
"mechanism for restricting access".
You can do that same sort of thing in any language, if you just make clear
what's the public API and what isn't. C does this with FILE* structures, for
example, as well as all the other standard libraries, without any real
features for encapsulation beyond incomplete types. You can also do it in
Smalltalk, which very clearly doesn't have anything beyond documentation to
enforce its modularity.
> anyways?
Not if you're not going to enforce it the other ways as well.
Sure. What about a naming convention that "comes with the language"? I.e.,
not just a naming convention you made up, but one in common for every single
program written in the language from day one?
> what he shouldn't.
I agree it's better. But since you seem to like binary definitions, and you
don't like me saying "C++ has a little bit of encapsulation but not much",
I'm curious if you think that (say) Python has encapsulation, given that
everyone knows that names with _ are private to the class they're in?
I don't make it a binary choice. I say "C has no encapsulation, Python has
very little (more modularity than encapsulation), C++ has a little more than
Python (because the compiler refuses to compile stuff that violates the
language rules), Java and C# have more (because you have to use reflection
or unsafe code), Erlang has a whole bunch (because only bugs in unsafe code
can violate it), and Sing# and Hermes have the most (because they have no
unsafe subsets at all)."
For me, the amount of benefit that encapsulation gives relative to
documentation is nowhere near the amount of benefit that encapsulation gives
relative to guarantees about relationships between code and data enforced by
the language.
Myself, I'd say when you can accidentally violate encapsulation, you have
poor encapsulation.
Those are all breaks of encapsulation, certainly. But those are in the
implementations, not the languages. A buggy RAM chip that randomly changes
values on the stack has nothing to do with whether C++ the language offers
valuable encapsulation.
I don't believe that's true. It certainly wasn't in C.
Nonsense. Arrays are contiguous. The elements of a structure are all between
&x and &x + sizeof(x).  There's lots of guarantees. And I'm pretty sure that
if you have "struct x {int a; int b} y;" that the standard guarantees
&b > &a. Positive integers are represented in twos-complement coding.
Unsigned integers occupy the the number of bits indicated by multiplying
sizeof(unsigned) by bits_per_char or whatever the appropriate #define is.
Now, if you're going to argue those guarantees don't count, Ok. I'd say some
do and some don't - I wouldn't argue that point very hard. But if they're
there, it's because enough people writing code in the language rely on them
being there that it was worth standardizing.
Can I get you to come work for my company? :-)
Date: 2 Mar 2010 04:25:45
Message: <4b8cd999$1@news.povray.org>
>> Scientific applications are a vanishingly small market segment.
> I'm not so sure about that.
How many people use computers to do scientific calculations?
How many people use computers to run their office suite?
Yeah, exactly.
>>> That's not "mainstream", that's "popular". :-)
>> There's a difference?
> Yes.
Care to elaborate on what it is?
>> Why would a branch have only one child?
> Populate the tree one element at the time. At least half the time,
> you'll have a node with only one child.
How do you figure that?
Tree with 1 element: L
Tree with 2 elements: L + L
Tree with 3 elements: L + (L + L)
Tree with 4 elements: (L + L) + (L + L)
Every node has either zero or two children.
> Perhaps the reason you don't see it a lot in Haskell is because the
> definition of a node with only one leaf would be ugly. :-)
No, it would be as trivial as the usual binary tree.
>> I haven't seen an N-ary tree in an OO language. ;-) Only strictly
>> *binary* trees.
> Wow. You need to read more code.  You've never seen a hashtable full of
> hashtables, or a parse tree?
I've never read the implementation of a hash table, for that matter.
Now a *parse tree* probably has a much more complicated structure than a
simple binary tree. I can well imagine it containing nodes with all
sorts of numbers of children. (And there might well be some complicated
inheritance relationships between the node types.)
> Let's ask this: what good is encapsulation? Why do people think
> encapsulation is a good thing?
> Answer: because it limits where you have to look to understand the
> behavior of code. If your language has encapsulation, you can look at
> the class of that object to determine what accesses and modifies its
> internal state. If the language has encapsulation but also an escape to
> an unsafe language (like JNI or P/Invoke or so), then you have to look
> at your class and all unsafe code that might change the contents of your
> class.
> Answer: Where in your code might lie a bug that is causing your class to
> violate its invariants? If you have two variables in your instance, one
> of which must always be two times the other, where do you have to look
> if that is not the case? How much of your code base might cause that
> change?
In just about any programming language imaginable, it would be possible
to look at the raw assembly code generated to figure out where some data
is physically stored in memory, and then link in some raw assembly to
directly access that data. So by this argument, because it's technically
possible to circumvent the language restrictions in just about any
programming language, no programming language exists which supports
encapsulation.
Which is, of course, nonesense. Real programs don't do this kind of
thing. If your program doesn't attempt to circumvent encapsulation, then
you get the benefits of encapsulation.
>>> What is this?
>>>    (lambda (x) (x + 1))
>>> It's a lambda expression.
>>>    y = (lambda (x) (x + 1))
>>> What is y?  It's a closure.
>> I still don't get it. (But then, I don't even know what language that
>> is...)
> Do you understand the difference between classes and instances?
Yes. (But I'm not sure how this is related to functions...)
>> YOU wrote this paragraph, not me. ;-)
> OK. My bad.  Altho that would certainly explain why I was confused. ;-)
Heh. Talking to yourself is the first sign of madness. ;-)
>> And this isn't the case for Haskell?
> I don't know. Maybe it is, but you don't make it sound that way.
I can't even remember what this statement refers to now...
>> As I said, the likes of Galois and Well Typed make their money
>> primarily designing systems where correctness is vital. What kind of
>> systems do you suppose those are?
> I couldn't guess. Galios has an empty web site and Well Typed are
> consultants.
> I'd honestly be quite surprised if either one builds systems in Haskell
> where correctness is actually vital. As in, an error in the program
> means people die.
No, I think it's more "failure would cost us craploads of money, very
fast". I believe that's the kind of area they work in. (They also seem
to do quite a bit of government work.)
>> (It's also conspicuous that both Galois and Well Typed employ people
>> who are also GHC developers... so maybe that's your answer!)
> Yep.
Of course, if you're the language implementers, you can implement
whatever you want. ;-) (Within reason, of course...)
I wonder if any of the other Haskell compilers will be production-ready
any time soon?
Date: 2 Mar 2010 11:33:16
Message: <4b8d3dcc$1@news.povray.org>
> Yeah, exactly.
Sure. I wouldn't say "vanishingly small", given the number of offices that
actually do science for a living.
Not especially. Let's just mention "COBOL".
Fair dinkum. I was thinking of a different algorithm.
You should. I expect things like skip lists and skip graphs and DHTs are the
sorts of things you'd get into.
So, because you can link assembly code to your Haskell, that means Haskell
isn't functional? Because assembly code isn't functional?
Uh, no. That's my point. You might get some of the benefits of encapsulation
(like correct code being easier to understand), but if neither the compiler
nor the runtime enforce encapsulation and you have no way of detecting
errors that violate encapsulation, then your language is doing a poor job of
encapsulation, at least for many of the benefits of encapsulation.
>>>> What is this?
>>> is...)
"Lambda" is the class. "Closure" is the instance.
Lambda is an expression. A closure is the value of the expression.
What is this:
    \ x . x + y
It's a lambda expression. It's not a value, because you don't know what "y"
is. It means different things depending on where it is in the program and
when you evaluate it. Every time you evaluate it, you'll get something
different back, depending on "y", yes?
That thing you get back, that encapsulates the value of "y"? That's a closure.
Oh, you can't help that. We're all mad here.
