POV-Ray : Newsgroups : povray.off-topic : Why is Haskell interesting? Server Time
26 Jun 2026 03:33:03 EDT (-0400)
  Why is Haskell interesting? (Message 51 to 60 of 87)
Subject: Re: Why is Haskell interesting?
Date: 28 Feb 2010 17:33:27
Message: <4b8aef37@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
>    (+5) is a function.
  But I thought you said you couldn't have symbols as unary functions.
Date: 28 Feb 2010 17:35:00
Message: <web.4b8aeeacb2efd740fa5d1ec00@news.povray.org>
> >> Perhaps you're forgetting that Haskell is also 20 years old?
> >   Hence a complete newcomer as programming languages are concerned.
> Not nearly as new as the likes of Java, Python, Ruby, etc. But sure, not
> as ancient as Lisp or C...
I believe Haskell is older than those.  Haskell was to be a kind of open
reimplementation of Miranda, which was developed in the early 80's.  It adopted
most of Miranda's syntax, and if some of that sounds weird, it is because C++
was still being developed back then as well...
Date: 28 Feb 2010 17:36:41
Message: <4b8aeff9$1@news.povray.org>
>>    (+5) is a function.
It's a curried function.
If you take any N-argument function and call it with 1 argument, you get
a new (N-1)-argument function as the result. Since (+) is a 2-argument
function, giving it one argument (here 5) yields a new 1-argument function.
http://blog.orphi.me.uk/
Date: 28 Feb 2010 17:37:55
Message: <4b8af043$1@news.povray.org>
Apparently Miranda was released 1985, making it "only" 5 years older
than Haskell. So even Miranda is "only" 25 years old.
To me, 25 years sounds like a hell of a long time in computing terms.
But what do I know?
Date: 28 Feb 2010 18:10:00
Message: <web.4b8af76ab2efd740fa5d1ec00@news.povray.org>
still, older than all of those, born in the 90's from C and Unix ideas mostly.
> But what do I know?
It is in terms of processing power, but not in how people tap that processing
power.  Things evolve a lot slower in the software side, thanks to the same old
ideas that drag around...
Date: 1 Mar 2010 04:26:08
Message: <4b8b8830$1@news.povray.org>
Darren New wrote:
> Orchid XP v8 wrote:
>> just mildly curious to know whether you can implement your own
>> tokenising rules or not.
> You're actually reading the input from the file. How could you *not*
> implement your own tokenizing rules?
If it hands the input to you one token at a time, then it's already been
split into tokens. If, on the other hand, it lets you take one character
at a time, then you can do whatever you want.
Date: 1 Mar 2010 04:46:20
Message: <4b8b8cec$1@news.povray.org>
>>> Hell, even Fortran is OO for the last 10 years.
>> People use Fortran? I thought that was only for scientific applications.
> And scientists aren't people?
[There's gotta be a joke in there somewhere...]
Scientific applications are a vanishingly small market segment.
>> Look at job adverts, or websites which talk about programming.
> That's not "mainstream", that's "popular". :-)
There's a difference?
>> If you specifically want a binary tree, the simplest and most logical
>> OO way would be to make leaves and branches different subclasses.
> Not especially. What about a branch with only one child node?
Why would a branch have only one child? I've not seen that in too many
algorithm descriptions. Usually a node has 0 or 2 children, not 1.
> And yes, even if leaves and branches are separate classes, it doesn't
> mean that they both aren't of type "treenode", or the leaf could be a
> subclass of branch or vice versa.
Sure, depending on what kind of tree you want, leaf and branch aren't
necessarily sibling classes.
>> I meant I've never seen it done like that in an OO language.
> You've never seen a N-ary tree in an OO language that used the same
> class for branches and leaves?  Wow.
I haven't seen an N-ary tree in an OO language. ;-) Only strictly
*binary* trees.
>> My point is that something like a parse tree usually doesn't need to
>> be dynamically extensible. If you make an extension to the language,
>> you typically need to rewrite all the code for processing the parse
>> tree anyway, so the fact that it's monolithic isn't too much of an issue.
> I disagree. The whole point of giving you the list of passes was showing
> you how modular each pass can be, as well as showing you how modular
> each parse node type needs to be.
Well, I guess no matter what I say everybody will conclude that I'm just
a moron who doesn't know what he's talking about anyway, so...
>> And you can take a C++ program and use pointer arithmetic to access
>> private member variables. Does that mean C++ doesn't provide
>> encapsulation?
> Yes.
Right. So any programming language that runs on a digital computer
inherantly lacks encapsulation then?
That's a stupid definition. Encapsulation is about whether the language
tries to limit your access to the internal implementation of an object,
not about whether it's physically possible to circumvent the restriction
by some suitably elaborate route.
> What is this?
>    (lambda (x) (x + 1))
> It's a lambda expression.
>    y = (lambda (x) (x + 1))
> What is y?  It's a closure.
I still don't get it. (But then, I don't even know what language that is...)
>> OK. So in what way does this mean that "functions are not first-class"?
> I didn't say it did. I said that everything in Javascript is an object.
OK. So even a function is an object. Since objects are first-class, that
means objects are first class.
> OK, you said
>  > The difference is that Haskell functions work on data, while
> Smalltalk only has objects. In other words, you can't invoke a function
> without knowing what object that "function" is a method of. (This is
> also the case for Javascript, btw.)
You wanna go back and check that?
YOU wrote this paragraph, not me. ;-)
>> I can imagine there are product written in Java that somebody has to
>> support, or that there are Java compilers that somebody has to
>> support. But the Java language itself?
> Well, no, there's nobody who has to support the spec, as such. I meant
> there are major systems where someone is paid to make sure the Java it's
> based on keeps working.
And this isn't the case for Haskell?
As I said, the likes of Galois and Well Typed make their money primarily
designing systems where correctness is vital. What kind of systems do
you suppose those are?
(It's also conspicuous that both Galois and Well Typed employ people who
are also GHC developers... so maybe that's your answer!)
Date: 1 Mar 2010 12:10:44
Message: <4b8bf514$1@news.povray.org>
I'm not so sure about that.
Yes.
Populate the tree one element at the time. At least half the time, you'll
have a node with only one child.
Perhaps the reason you don't see it a lot in Haskell is because the
definition of a node with only one leaf would be ugly. :-)
> *binary* trees.
Wow. You need to read more code.  You've never seen a hashtable full of
hashtables, or a parse tree?
Nope. If the language defines what happens when you try to violate
encapsulation, then you have encapsulation.
Right. But in unsafe languages, it's not a matter of "suitably elaborate."
Let's ask this: what good is encapsulation? Why do people think
encapsulation is a good thing?
Answer: because it limits where you have to look to understand the behavior
of code. If your language has encapsulation, you can look at the class of
that object to determine what accesses and modifies its internal state. If
the language has encapsulation but also an escape to an unsafe language
(like JNI or P/Invoke or so), then you have to look at your class and all
unsafe code that might change the contents of your class.
Let's ask this: Why doesn't C++ have encapsulation?
Answer: Where in your code might lie a bug that is causing your class to
violate its invariants? If you have two variables in your instance, one of
which must always be two times the other, where do you have to look if that
is not the case? How much of your code base might cause that change?
>> What is this?
> is...)
Do you understand the difference between classes and instances?
Yes, and yes.  And functions have the class "Function".
OK. My bad.  Altho that would certainly explain why I was confused. ;-)
I don't know. Maybe it is, but you don't make it sound that way.
I couldn't guess. Galios has an empty web site and Well Typed are consultants.
I'd honestly be quite surprised if either one builds systems in Haskell
where correctness is actually vital. As in, an error in the program means
people die.
Yep.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 1 Mar 2010 14:31:15
Message: <4b8c1603@news.povray.org>
  Clearly we have a different definition of "encapsulation".
Date: 1 Mar 2010 14:52:29
Message: <4b8c1afd@news.povray.org>
I explained why encapsulation is important and why unsafe languages don't
have it.  What's your definition of encapsulation, and why does it make a
difference to the programming productivity?
