POV-Ray : Newsgroups : povray.off-topic : Coding in ___ is like ___ Server Time
16 Jul 2026 11:16:36 EDT (-0400)
  Coding in ___ is like ___ (Message 41 to 50 of 66)
Subject: Re: Coding in ___ is like ___
Date: 26 Feb 2010 14:31:32
Message: <4b882194$1@news.povray.org>
Warp wrote:
>   You don't have to deal with constructors. You can simply say "if you create
> a string without initializing it, it defaults to an empty string".
And they ask "what does an integer default to?"  And then they ask why.
>   As opposed to char*, which defaults to... what?
Uninitialized. Like every single automatic variable in C, nothing gets
initialized before you assign to it.
>   You seriously claim that eg. pointer arithmetic, null-terminated strings
> and the standard C string manipulation functions are easier for a beginner
> to understand than C++'s std::string? (And that's just one example.)
Yes, if you actually want to understand it. If you want to treat std::string
as magic, then no.
>> It would be easier to explain what's happening.
>   Does the beginner really need to know what the compiler is doing under
> the hood in this case?
If you want to treat the standard template library as magic, no.
>> I don't have to explain the syntax for method invocation
>   There was no method invocation in my example. (Ok, operator+() *is* a
> method, and it's being called, but the beginner doesn't need to know that
> in order to use string concatenation.)
strings.size() isn't a method invocation? And in this case, += and [] are as
well, but I agree you could probably skip over that bit.
>> the differences between method invocations on
>> references and pointers
>   My example didn't need any such thing.
>> overloaded operators
>   The beginner doesn't need to know that to implement that example.
So you're arguing that the complexity can be brushed off as "magic you don't
have to worry about."  That's OK, but in my experience that's not a good way
to teach beginners.
I wasn't talking specifically about your example in some of these cases, but
about the difference between teaching C++ and C in general.
>> or what namespaces are.
>   Is it really a bad thing that the beginner is introduced to namespaces
> from the very beginning? It's not like they are very hard to understand.
To beginning programmers, *everything* is hard to understand.
>   No. The C version would require explaining lots of things about how C
> null-terminated strings work internally
True.
>   You would also need to explain that if the function returns a pointer to
> a new C string it allocated itself, how the calling code needs to make sure
> that it's not leaked. (Again, no such need with std::string.)
Yes yes and yes.
>   So the C++ version is enormously simpler than the C version in all possible
> regards. The newbie needs to learn a lot less and can start doing some
> practical (and safer) code much more quickly.
We'll just have to disagree.
>> Basically, in the C equivalent, the
>> only *confusing* part is that C doesn't allocate multi-word objects for you.
>   No, it isn't. You have to understand null-terminated strings, how to
> calculate the length of strings, and how to manually manage the memory
> for the strings before you could write such a function in C.
Yep. Those aren't confusing, tho. They're tedious, and may seem like silly
rules, but not *confusing*. You can explain that stuff with pictures.
Based on my experience teaching classes, treating something as "magic you
don't have to understand", and having several elements that perform the same
role differently, is what leads to confusion. You immediately start down the
cargo-cult programming path, where you do it like this not because it's
right, but because that's what the teacher said to do and you don't know why.
Plus, the concatenate example is a terrible example for teaching. There's no
I/O, it's not a stand-alone program, and it's not complete.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 26 Feb 2010 14:44:15
Message: <4b88248f@news.povray.org>
>>> He missed "Pseudocode", which I'd write as:
>>> Coding in pseudocode is like a metaphor.
>> I like it! (although given your sentence construction shouldn't that be
>> "simile", or alternatively "Coding in pseudocode is a metaphor"?)
> Technically, I guess "simile" would be correct there - I always get the
> two mixed up.  :-)
Analogies are endofunctors in the category of bad explanations.
http://blog.orphi.me.uk/
Date: 26 Feb 2010 15:37:48
Message: <4b88311c$1@news.povray.org>
>>> be "simile", or alternatively "Coding in pseudocode is a metaphor"?)
>> two mixed up.  :-)
Now, of those, which is the hypernym and which is the hyponym? ;)
Jim
Date: 26 Feb 2010 16:55:37
Message: <4b884359$1@news.povray.org>
One would *presume* that analogy is a hyponym of bad explanation...
Date: 26 Feb 2010 17:28:35
Message: <4b884b13$1@news.povray.org>
Certainly from your sentence construct, that would seem to be the
case. :-)
Jim
Subject: In pictures
Date: 1 Mar 2010 06:53:38
Message: <4b8baac2@news.povray.org>
I believe this to be vaguely relevant:
http://i.imgur.com/hF6mS.jpg
Date: 2 Mar 2010 23:25:01
Message: <web.4b8de39cadada4adb54c01350@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> One of the better ones I've seen.
> http://web.mit.edu/~axch/www/writing_rant.html
my gosh!  So many messages and all of them irrelevant!
what is truly amusing about this is that it was written by Peter Parker himself!
o_0
Date: 4 Mar 2010 17:45:06
Message: <4b9037f2@news.povray.org>
Darren New wrote:
> Warp wrote:
>>   Exactly which part of C is simpler for newbies than C++?
> You don't have to deal with constructors, destructors, exceptions, the
> difference between casing classes and casting pointers to classes, etc.
Right; instead, you have to deal with a dozen different library
implementations of object construction, destruction and error handling;
such as GObject :)
Another example: POV-Ray 3.6 has virtual functions reinvented in C (to call
"intersect with ray" on any Object* without knowing if it's a Sphere or an
Isosurface). It's harder to figure out what's going on than if you just had
a C++ class with virtual methods, because no other C program does it
**exactly** the same way as POV 3.6.
Date: 4 Mar 2010 17:58:01
Message: <4b903af9@news.povray.org>
Invisible wrote:
> I'm not familiar with Ruby, Scheme, or Mozart. Of course I've heard of
> all these things, but I don't know anything about them.
http://en.wikipedia.org/wiki/Ruby_(programming_language)
http://en.wikipedia.org/wiki/Scheme_(programming_language)
http://en.wikipedia.org/wiki/Wolfgang_Amadeus_Mozart
Date: 4 Mar 2010 18:20:59
Message: <4b90405b$1@news.povray.org>
Actually, I don't. Note the term "newbies". :-)
I honestly wouldn't teach either one as a first language. Even Pascal is
pushing it, IME.
Yep. And the problem is that no C program can possibly do it the same way as
C++ in any sort of portable way. So every C++ library that uses any of this
sort of feature is incompatible with being called by any sort of C program.
Hence, the proliferation of such faux-OO libraries.
