POV-Ray : Newsgroups : povray.off-topic : Unicode Server Time
4 Jun 2026 21:18:27 EDT (-0400)
  Unicode (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Unicode
Date: 31 Jan 2010 12:50:01
Message: <web.4b65c1f1bf9260a53e9ff120@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Orchid XP v8 wrote:
> If you don't, the application under Windows is called "Character Map", an
> d I
> think it's under Accessories in pre-Vista windows.
yep, even Ubuntu got that, same location.
Date: 31 Jan 2010 13:05:04
Message: <4b65c650$1@news.povray.org>
Orchid XP v8 wrote:
> (For example, I've discovered that if I want to type, say, "ü", I can
> look up the Wikipedia article for "U" and the article for "ü" is linked
> from there. But that requires an Internet connection, and seems like an
> absurdly long-winded way of going about things...)
You don't even need unicode for that character, ISO-8859-1 has it.
I type it by pressing shift-´ (which is ¨), then 'u'.
For ñ I simply have a separate key.
On Linux, my keyboard layout has some useful Unicode stuff under AltGr +
letters. For example “proper quotes” (AltGr + V and B respectively) or the ©
symbol (AltGr + Shift + C).
Date: 31 Jan 2010 13:07:40
Message: <4b65c6ec$1@news.povray.org>
Le 31/01/2010 18:05, Orchid XP v8 nous fit lire :
> OK, so here's a question: How do you actually type in Unicode characters
> that aren't on your keyboard?
Depend on your application, i guess.
For instance, vi/gvim have a ctrl-v/u/4hex digit sequence as escape for
inputing such characters (as long as your font support it, and you're in
not in need of the extended pages (after 16 bits))
Date: 31 Jan 2010 13:08:31
Message: <4b65c71f$1@news.povray.org>
Darren New wrote:
> If you know the code number, it's some keyboard escape, like holding
> down the alt key while typing on the numeric keypad or something.
Sure. But there are zillions of Unicode characters you might want to
use. (I forget how many accented vowels there are. And then there's all
the mathematical symbols that somebody like me might use...)
> and I think it's under Accessories in pre-Vista windows.
Right. I guess that's probably the least clunky way to do things...
And of course, a decent text editor will allow you to bind shortcuts to
commonly used Unicode characters. [Now to go find "a decent text editor"
before somebody tells me to start using Emacs. :-P ]
http://blog.orphi.me.uk/
Date: 31 Jan 2010 14:20:53
Message: <4B65D814.7020400@hotmail.com>
if you have the right language installed. English in general has not
much use for ü so that is not default for Andy.
Date: 31 Jan 2010 14:27:43
Message: <4b65d9af@news.povray.org>
> I type it by pressing shift-?? (which is ??), then 'u'.
  I don't think the question was if Unicode is necessary to get the
character, but instead how to get the unicode character in question.
Date: 31 Jan 2010 14:28:53
Message: <4b65d9f5@news.povray.org>
> If you know the code number, it's some keyboard escape, like holding down
  Are you sure that supports unicode and not just the system default
character mapping (which in Windows would be that Windows extension to
ISO-Latin-1, at least in western countries)?
> If you don't, the application under Windows is called "Character Map", and I
  Likewise.
Date: 31 Jan 2010 14:31:24
Message: <4b65da8b@news.povray.org>
  You can switch keyboard mappings, you know.
  But I suppose that if you need some special character which is not really
part of any mapping (or any mapping you know or are familiar with), you use
some utility program. Some text editors might have such a feature built in.
  If you are writing HTML (or XML), you can write the unicode value directly
as &#xxxx; (IIRC). Might require proper HTML/HTTP headers for the client
program to interpret properly.
Date: 31 Jan 2010 15:25:35
Message: <op.u7ey0wsb7bxctx@toad.bredbandsbolaget.se>
On Sun, 16 Oct 2005 09:28:09 +0200, Fredrik Eriksson wrote:
> " Alt+<xxx>, where xxx is the decimal value of a code point, generates
> an OEM-encoded character.
>  Alt+<0xxx>, where xxx is the decimal value of a code point, generates a
> Windows-encoded character.
>  Alt+<+>+<xxxx>, where xxxx is the hexadecimal Unicode code point,
> generates a Unicode-encoded (UTF-16) character."
>http://www.microsoft.com/globaldev/reference/glossary.mspx
FE
Date: 31 Jan 2010 15:37:52
Message: <4b65ea20$1@news.povray.org>
> character mapping
"some keyboard escape like ..."
I know you can type unicode, and I know you can type ASCII, but I don't
remember how to invoke one vs the other.
GIYF
http://www.fileformat.info/tip/microsoft/enter_unicode.htm
Basically, type numeric plus first to get unicode.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
