POV-Ray : Newsgroups : povray.off-topic : 99 lines of C++ for an unbiased ray tracer Server Time
15 May 2026 11:54:24 EDT (-0400)
  99 lines of C++ for an unbiased ray tracer (Message 6 to 15 of 65)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: 99 lines of C++ for an unbiased ray tracer
Date: 14 Jan 2010 03:10:26
Message: <4b4ed172$1@news.povray.org>
Sabrina Kilian wrote:
> Stephen wrote:
>> Darren New wrote:
>>> nemesis wrote:
>>>> It was also the basis for SmallptGPU:
>>> Hey, I have an idea. Has anyone ever considered porting POV-Ray to the
>>> GPU? I bet it would be a lot faster.
>> Nice one! What a good idea. ;)
> Hey, I bet it couldn't take more than a few minutes to move all the code
> that direction. I mean, it can't be too much larger than 99 lines of code.
Not being a coder myself I will have to take your word on that. I’m sure
Chris could do it standing on his head or at least upside down ;)
Best Regards,
Date: 14 Jan 2010 04:45:52
Message: <4b4ee7d0$1@news.povray.org>
nemesis wrote:
> yes.  I wonder how it'd look like in Haskell. ;)
In any language, I suspect the answer will depend on:
- Which libraries are you allowed to use? [Get a ray tracing library and
the program surely becomes trivial...]
- How fast does it have to be? [A highly-efficient program is likely to
be a lot bigger than a program written specifically to demonstrate how
terse you can be.]
Date: 14 Jan 2010 05:43:49
Message: <4b4ef565$1@news.povray.org>
Darren New wrote:
> Cute. Hard to read, but cute. :-)
Wait... THE WALLS ARE GIANT SPHERES?! o_O
Well that's *one* way to cut down the code size... No ray/plane
intersection test to code.
44:  double n=sizeof(spheres)/sizeof(Sphere);
Well... that's... one way to figure out how big an array is. :-.
Evidently my C++ is weak, but... how is
53:  Vec nl=n.dot(r.d)<0?n:n*-1;
different from "nl = -abs(n.dot(r.d))"?
Also, where THE HELL is "Xi" defined? I can see it *used* in several
places, but I can't find a definitions.
Line 79 means each row of pixels is computed in parallel, right?
Date: 14 Jan 2010 06:00:34
Message: <4b4ef952@news.povray.org>
a?b:c evaluates to b if a is true, or c otherwise.
Line 82, after the x=0 definition.
I guess so.
Date: 14 Jan 2010 06:07:30
Message: <4b4efaf2@news.povray.org>
Ah, wait, I misread that as calculating something, assigning it to n,
and then checking whether n is negative and if not negating it. On
closer inspection, that's not what this does...
Wait - you can define MORE THAN ONE variable in a loop initialisation??
Date: 14 Jan 2010 06:41:59
Message: <4b4f0307$1@news.povray.org>
Don't see why not, would be a pointless limitation to put in on purpose that
just reduced the flexibility, should anyone want it.
Date: 14 Jan 2010 07:49:02
Message: <4b4f12be$1@news.povray.org>
Anybody got any theories on line 55?
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p);} else return obj.e;
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p); else return obj.e;}
I can't decide which "if" the "else" belongs to. o_O
(I also have approximately no idea whatsoever what f=f*(1/p) is in aid
of...)
Date: 14 Jan 2010 08:14:58
Message: <4b4f18d2$1@news.povray.org>
The else always belongs to the closest if at the same scope level...
Which means it's:
I think it's part of the Russian Roulette method (which is what the
comment R.R. stands for I suppose). I don't remember the details but you
can probably look it up by yourself...
Vincent
Date: 14 Jan 2010 08:27:24
Message: <4b4f1bbc$1@news.povray.org>
Ouch. This isn't going to be pretty...
Clearly it flips a coin to decide whether to process further [all of the
code paths beyond this point involve sending out a new ray] or just stop
here. However, "f" is the object colour, and I have absolutely no idea
why it's being scaled by the reciprocol of the brightest component...
Date: 14 Jan 2010 08:37:28
Message: <4b4f1e18$1@news.povray.org>
LPC might be a little different, but can't you negate a variable by
saying a=-a;?  Saves a little CPU cost.
Tim Cook
http://empyrean.freesitespace.net
