POV-Ray : Newsgroups : povray.off-topic : 99 lines of C++ for an unbiased ray tracer Server Time
4 Jul 2026 09:58:01 EDT (-0400)
  99 lines of C++ for an unbiased ray tracer (Message 11 to 20 of 65)
Subject: Re: 99 lines of C++ for an unbiased ray tracer
Date: 14 Jan 2010 06:41:59
Message: <4b4f0307$1@news.povray.org>
> Wait - you can define MORE THAN ONE variable in a loop initialisation??
Don't see why not, would be a pointless limitation to put in on purpose that
just reduced the flexibility, should anyone want it.
Date: 14 Jan 2010 07:49:02
Message: <4b4f12be$1@news.povray.org>
Invisible wrote:
> Evidently my C++ is weak
Anybody got any theories on line 55?
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p);} else return obj.e;
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p); else return obj.e;}
I can't decide which "if" the "else" belongs to. o_O
(I also have approximately no idea whatsoever what f=f*(1/p) is in aid
of...)
Date: 14 Jan 2010 08:14:58
Message: <4b4f18d2$1@news.povray.org>
The else always belongs to the closest if at the same scope level...
Which means it's:
I think it's part of the Russian Roulette method (which is what the
comment R.R. stands for I suppose). I don't remember the details but you
can probably look it up by yourself...
Vincent
Date: 14 Jan 2010 08:27:24
Message: <4b4f1bbc$1@news.povray.org>
Ouch. This isn't going to be pretty...
Clearly it flips a coin to decide whether to process further [all of the
code paths beyond this point involve sending out a new ray] or just stop
here. However, "f" is the object colour, and I have absolutely no idea
why it's being scaled by the reciprocol of the brightest component...
Date: 14 Jan 2010 08:37:28
Message: <4b4f1e18$1@news.povray.org>
scott wrote:
>> 53:  Vec nl=n.dot(r.d)<0?n:n*-1;
>> different from "nl = -abs(n.dot(r.d))"?
> a?b:c evaluates to b if a is true, or c otherwise.
LPC might be a little different, but can't you negate a variable by
saying a=-a;?  Saves a little CPU cost.
Tim Cook
http://empyrean.freesitespace.net
Date: 14 Jan 2010 08:47:47
Message: <4b4f2083$1@news.povray.org>
> LPC might be a little different, but can't you negate a variable by saying
I think he would have to define the unary minus operator for the vector
class before he could write -n instead of n*-1.
Date: 14 Jan 2010 08:58:32
Message: <4b4f2308@news.povray.org>
What do you mean?
I think that it's the part that makes the method unbiased. You have to
scale the rays that you keep in order to account for the fact that you
don't keep them all, or something like that.
Vincent
Date: 14 Jan 2010 09:01:09
Message: <4b4f23a5$1@news.povray.org>
> What do you mean?
I mean implementing this in a language where the else-part is
*mandatory* for all if-blocks makes this slightly tricky to do. (But not
as tricky as I thought; I've found a clean way to do it.)
>> absolutely no idea why it's being scaled by the reciprocol of the
Well, we'll see I guess...
Date: 14 Jan 2010 11:33:27
Message: <4b4f4757$1@news.povray.org>
Invisible escreveu:
> nemesis wrote:
>> yes.  I wonder how it'd look like in Haskell. ;)
> In any language, I suspect the answer will depend on:
> - Which libraries are you allowed to use? [Get a ray tracing library and
> the program surely becomes trivial...]
> - How fast does it have to be? [A highly-efficient program is likely to
> be a lot bigger than a program written specifically to demonstrate how
> terse you can be.]
That's what I'm willing to know.  That piece of code is not using a
"raytracing library", just implementing algorithms from well-known papers.
a game sig: http://tinyurl.com/d3rxz9
Date: 14 Jan 2010 11:33:41
Message: <4b4f4765@news.povray.org>
I had a go at implementing this, but I have clearly screwed up the math
somewhere, because the program is behaving very strangely.
(I've turned off all the fancy stuff until it's just a normal depth-1
ray tracer, and the image still just consists of a few bent lines.)
So far I've found at least a dozen bugs in the ray/intersection code, a
typo in the cross-product (typed an X instead of a Z), and I'm still
finding more. What can I say? I fail at math! o_O
