POV-Ray : Newsgroups : povray.off-topic : Geometric puzzle Server Time
2 Jul 2026 08:12:05 EDT (-0400)
  Geometric puzzle (Message 101 to 110 of 201)
Subject: Re: Geometric puzzle
Date: 16 Dec 2009 17:06:21
Message: <4b2959dd$1@news.povray.org>
On Wed, 16 Dec 2009 16:33:45 -0500, Warp wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> An assertion that's easy to prove.  Python runs on Macs.  Macs
>> typically have a *1* button mouse.
>   Isn't that info a bit old? Does Apple even sell 1-button mice anymore?
>   (Apple's mice might *look* like they have only one button, but in
>   reality
> they usually have at least four. They can be configured to work as if it
> had only one button, though.)
Perhaps, I'm not a Mac user.  But I reckon that Python was around before
Apple switched to a multi-button mouse.
Jim
Date: 16 Dec 2009 17:09:52
Message: <4b295ab0$1@news.povray.org>
Warp wrote:
>   So the task is simple: Write a function f(m,n) which tells how many
> rectangles can be found in an m x n grid. (Explain how you came up
> with the function).
You mean just something like n*m*(n-1)*(m-1)/4?  The derivation is
pretty direct from the one-dimensional case.
Date: 16 Dec 2009 17:34:51
Message: <op.u41ycjt77bxctx@bigfrog.bredbandsbolaget.se>
On Wed, 16 Dec 2009 22:56:50 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
> Also... Blender seems to incorrectly assume that Z is "up" and Y is
> "back". (It should obviously be the other way around.)
It is not incorrect; it is right-handed.
> Interesting how the amount of scaling is apparently completely unrelated
> to the mouse movement... (Seems to scale the cube by about 20% of the
> distance the mouse is moved.)
It depends on how far the mouse pointer is from the selection.
> OK, this one took me a while to figure out. You'd think you extrude it
> by dragging the face that you want to extrude... but no. You just click
> and Blender places faces at random for you.
Select faces/edges/vertices, press E to extrude. The newly formed
faces/edges/vertices are automatically selected, and by default you are
put in Grab mode; move the mouse to move them or right-click to keep them
where they are. You can also switch from Grab mode to Scale or Rotate by
pressing S or R.
> F9 doesn't appear to do anything.
F9 opens the Editing panel in the Buttons window. If the Editing panel was
already active, nothing will happen.
FE
Date: 16 Dec 2009 17:45:01
Message: <4b2962ed@news.povray.org>
> > with the function).
  It would be interesting to see that derivation.
Date: 16 Dec 2009 17:58:42
Message: <4b296622@news.povray.org>
>>> with the function).
Let's consider the one-dimensional case (so set m=1).  In this case we
have one rectangle of width n-1, two rectangles of width n-2, three of
width n-3, ..., and n-1 of width 1.  We can express the total number of
rectangles as the sum:
sum_{i=1:n-1} i
Which as the solution n*(n-1)/2.
If we relax the restriction that m=1, then we instead get the double sum:
sum_{j=1:m-1} j * sum_{i=1:n-1} i
Intuitively you can think of this as follows: for each of the
one-dimensional rectangles along the m-axis, we have sum_{i=1:n-1}
rectangles along the n-axis.  You can view this sum as expressing every
rectangle as being defined by two line segments along the n- and m-
axes.  In any case, the value of the sum is easy to compute:
= sum_{j=1:m-1} j * n*(n-1)/2
= (n*(n-1)/2) * sum_{j=1:m-1} j
= (n*(n-1)/2) * (m*(m-1)/2)
= n*m*(n-1)*(m-1)/4
Date: 16 Dec 2009 18:20:14
Message: <4b296b2d@news.povray.org>
Random statistic: A standard Go board has 38 lines, 361 intersections and
29241 rectangles.
Date: 16 Dec 2009 18:39:38
Message: <4b296fba$1@news.povray.org>
On 12/16/09 13:21, Warp wrote:
>> that's what the mascot does all of the time - yet he gets chastized from
>> time to time ;-)
>    He presents puzzles for people to think about?
	His presence is a puzzle in itself.
Would the capacity of a Palaeozoic Hard Dive be measured in Trilobites?
Date: 16 Dec 2009 19:06:14
Message: <4b2975f6@news.povray.org>
> 29241 rectangles.
And, rather surprisingly, 42 squares.
Date: 16 Dec 2009 19:14:41
Message: <4b2977f1@news.povray.org>
> > 29241 rectangles.
  Since the lined grid of an official goban is 396 x 426.6 mm, does it form
any exact squares?
Date: 16 Dec 2009 19:26:11
Message: <4b297aa3$1@news.povray.org>
>>> 29241 rectangles.
> any exact squares?
Hmm, no it doesn't.  I was just getting my info from this page:
http://senseis.xmp.net/?path=GoHumour&page=HowManySquaresOnAGoBoard  but
looking into it a bit more it seems that you're correct (at least for
Japanese boards).  I don't about standard sizes in other countries
though (I think a Chinese board is somewhat larger, but I don't know
about Korea or other countries).
