POV-Ray : Newsgroups : povray.off-topic : One step closer to Permutation City Server Time
19 Apr 2026 05:32:24 EDT (-0400)
  One step closer to Permutation City (Message 21 to 30 of 41)
Subject: Re: AWS[S3]
Date: 18 Dec 2009 16:32:02
Message: <4b2bf4d2$1@news.povray.org>
>> OK. The documentation wasn't very clear about this...
> Uh, OK.  It seemed really clear to me. :-)  They even give you options
> for giving people time-limited access to otherwise unreadable objects.
Oh, I haven't read through all the low-level documentation, only the
summary pages.
>>> You use a library, depending on what language you're using, or you
>>> implement your own.
>> I'd be in the latter group.
> There ya go, then. Read the specs. It's pretty straightforward.
...for somebody who doesn't yet understand what SOAP or REST are?
>> ...right. So I actually need real crypto libraries to be able to use
>> it? Oh well, that's the end of that then.
> I think you need an MD5 implementation, is all.
I actually wrote an MD5 implementation in Haskell. (The hardest part is
the padding. You must get this exactly right, and MD5 allows the
"message" to be an arbitrary number of bits - not necessarily a multiple
of eight, not necessarily non-zero!) I eventually got it to produce the
correct answer in every single case I tested.
You can see where this is going, can't you? Yes, I admit it: It's way,
way too slow to be remotely useful. Files that md5sum.exe can process in
a split second take several minutes. I haven't figured out why yet.
(Alternatively, there's a binding to the C implementation - which
presumably won't work on Windows. Probably not hard to pipe the data to
md5sum.exe tho... Hell, that is one of the *design goals* of the tool!)
http://blog.orphi.me.uk/
Date: 18 Dec 2009 16:43:57
Message: <4b2bf79d$1@news.povray.org>
> summary pages.
I would have thought it's in there, but...
REST is "use HTTP to get and put data".
I think you only *need* to sum some headers, but maybe it's the whole file.
I'm not sure I remember.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 18 Dec 2009 16:52:07
Message: <4b2bf987@news.povray.org>
>> summary pages.
So, if I stick a bunch of HTML pages on S3, I can basically host a website?
So, you upload stuff by making HTTP PUT requests? (As originally
invisaged by Tim Burton?)
>> in a split second take several minutes. I haven't figured out why yet.
> file. I'm not sure I remember.
OK, well I'll go dig through the specs.
Date: 18 Dec 2009 16:53:59
Message: <4b2bf9f7$1@news.povray.org>
Yes. The only thing that doesn't work is
http://blahlbhalbha.com/
You'd actually have to go to http://blahblahb.com/index.html
Yes.  And delete stuff with HTTP DELETE.
Date: 18 Dec 2009 16:59:39
Message: <4b2bfb4b$1@news.povray.org>
HTTP DELETE -R /
Whoops...
Jim
Date: 19 Dec 2009 00:55:19
Message: <4b2c6ac7@news.povray.org>
Jim Henderson wrote:
> HTTP DELETE -R /
> Whoops...
I think WebDAV's "Depth" header would actually let you shoot yourself on the
foot just like that.
Date: 19 Dec 2009 14:14:08
Message: <4b2d2600$1@news.povray.org>
>> HTTP DELETE -R /
>> Whoops...
> the foot just like that.
Doesn't surprise me. :-)
Jim
Date: 21 Dec 2009 04:10:34
Message: <4b2f3b8a$1@news.povray.org>
Can you do this stuff using mget or some similar CLI tool?
Date: 21 Dec 2009 05:07:40
Message: <4b2f48ec$1@news.povray.org>
Obviously I actually meant wget. And it appears wget only supports
downloading, not uploading.
However, apparently libcurl also has a CLI tool simply named curl, and
this apparently supports making HTTP PUT requests...
Date: 21 Dec 2009 05:52:14
Message: <4b2f535e@news.povray.org>
"The Amazon S3 REST API uses a custom HTTP scheme based on a keyed-HMAC
(Hash Message Authentication Code) for authentication."
Oh bugger.
So a custom authentication scheme that curl doesn't support then? :-P
"To authenticate a request, you first concatenate selected elements of
the request to form a string. You then use your AWS Secret Access Key to
calculate the HMAC of that string."
Hmm, great...
Oh, and it appears to use SHA-1 rather than MD5. I wonder if anybody has
binary implementations of SHA-1 that work on Windoze? *sigh*
