POV-Ray : Newsgroups : povray.off-topic : Bounding circle intersection Server Time
7 Apr 2026 18:46:33 EDT (-0400)
  Bounding circle intersection (Message 21 to 30 of 43)
Subject: Re: Bounding circle intersection
Date: 11 Dec 2009 04:08:31
Message: <4b220c0f$1@news.povray.org>
>>   Suppose that the most significant non-zero digit of x is in the 2^n
>> place. Let y = x / 2^(n/2). Now Sqrt(x) is approximately x / y.
> Is there a way to quickly get n for a given number?
If you don't mind depending on a specific floating-point
representation... sure. Just find out which bits of the number contain
the exponent. (For example, for a double-precision IEEE float, the
bitmask is 0x7FFF000000000000, and you then shift out those zeros and
subtract 0x3FFF to get the real value.)
That's what makes this so efficient. You just need the exponent field
from the float value, so no need to calculate anything. (Indeed, as an
even rougher approximation, just halve the exponent...)
Date: 11 Dec 2009 04:09:45
Message: <4b220c59$1@news.povray.org>
scott wrote:
> So let me understand this, you are constructing two circles, one around
> the line and one around the triangle, then seeing the circles intersect,
> and if they do proceeding to check if the line actually intersects the
> triangle?
> Wouldn't it be faster to just directly check the line against the triangle?
It would.
Now, if the circle encloses a few *thousand* triangles, it's probably
way, way faster to check the circle first...
Date: 11 Dec 2009 05:45:53
Message: <4b2222e1$1@news.povray.org>
> triangle?
Well, the one around the triangle is precomputed. Otherwise, yes.
> triangle?
Honestly, I don't know. I'm not sure my code for the triangle-line check is
very good. =)
As far as I can tell, to check for an intersection between a triangle and a
line segment, you need to check that one of the triangle's vertices is on an
opposite side of the line from the other two, and then check that both of
the line segment's endpoints are on opposite sides of at least one of the
triangle's edges, or that both of them are inside the triangle.
I did most of these checks with cross products, and then found I had some
precision problems in some cases, and the code got more complicated when I
tried to avoid them. Since intersections are rare, I figured a bounding
check would be the easiest way to improve performance.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 11 Dec 2009 05:54:20
Message: <4b2224dc$1@news.povray.org>
>> triangle?
> very good. =)
Er... yeah, that's not terribly good. ;-)
Do a quick google for "ray triangle intersection". There are several
methods for doing this kind of thing, some of them highly optimised.
Date: 11 Dec 2009 06:28:25
Message: <4b222cd9@news.povray.org>
That tends to give results for a 3D problem, whereas my problem is 2D.
 - Slime
Date: 11 Dec 2009 06:46:53
Message: <4b22312d@news.povray.org>
Many of the methods work for 2D as well though.
But now I'm curious... the cross product is only defined for 3D vectors,
but you said you used a lot of cross products?
Date: 11 Dec 2009 07:14:19
Message: <4b22379b$1@news.povray.org>
Treat your 2D working area as a plane in 3D space (with Z coordinate zero if
you like), then you can do cross products, and checking whether the result
points "in to" the plane or "out of" the plane can be pretty useful (eg to
find out which side of a line a point is on).
Date: 11 Dec 2009 07:40:19
Message: <4b223db3@news.povray.org>
>> vectors, but you said you used a lot of cross products?
> zero if you like), then you can do cross products, and checking whether
> the result points "in to" the plane or "out of" the plane can be pretty
> useful (eg to find out which side of a line a point is on).
Oh, right.
...or you could just take the dot product instead, which requires only 2
multiplies and one addition as opposed to four multiplies and two
subtractions...
Date: 11 Dec 2009 08:23:10
Message: <4b2247be$1@news.povray.org>
> subtractions...
How is that useful?
Date: 11 Dec 2009 08:24:15
Message: <4b2247ff@news.povray.org>
>> 2 multiplies and one addition as opposed to four multiplies and two
>> subtractions...
> How is that useful?
Because you can use it to determine which side of the line a point is on?
