POV-Ray : Newsgroups : povray.off-topic : Q about Unit Tests Server Time
11 May 2026 20:25:16 EDT (-0400)
  Q about Unit Tests (Message 11 to 12 of 12)
Subject: Re: Q about Unit Tests
Date: 5 Dec 2009 12:31:15
Message: <4b1a98e3$1@news.povray.org>
Stephen wrote:
> That’s right for each unit test you can and generally must prep
are the
> data the unit has to test.
That I knew. :-)
> You can run them in any order and since they are independent tests they
> do not rely on other tests passing or failing.
I can see situations in which a test would rely on other tests succeeding
You can't test "read from a file" if "open a file" fails, for example. An
d
if "open a file" fails in a way that leaves "read from a file" dumping co
re,
it can be messy to rearrange tests and still know what's failing.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 6 Dec 2009 02:15:00
Message: <4b1b59f4$1@news.povray.org>
Darren New wrote:
> Stephen wrote:
>> That’s right for each unit test you can and generally must prepare the
> That I knew. :-)
I know that you know ;)
{Quote from an old (60’s) Brit radio show :) }
>> they do not rely on other tests passing or failing.
> succeeding. You can't test "read from a file" if "open a file" fails,
> for example. And if "open a file" fails in a way that leaves "read from
> a file" dumping core, it can be messy to rearrange tests and still know
> what's failing.
This is where your expertise comes in and you create unit tests with
steps. For instance: (and I’m just guessing here)
UT 1 - Initialise Media Player.
Step 1. Initialise Media Player.
Expected Result: Media Player initialised.
Result:
Pass/Fail:
Comments:
UT 2 – Read File
Step 1. Open file.
Expected Result: File opened.
Result:
Pass/Fail:
Comments:
Step 2. Read file.
Expected Result: File read into buffer.
Result:
Pass/Fail:
Comments:
A spreadsheet is a better format. :D
Best Regards,
