POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
4 Jul 2026 20:42:56 EDT (-0400)
  Trivial trigonometry (Message 99 to 108 of 178)
Subject: Re: Trivial trigonometry
Date: 2 Dec 2009 04:20:01
Message: <web.4b1630bd6ad665b96dd25f0b0@news.povray.org>
"scott" <sco### [at] scottcom> wrote:
> With some quick calculations and rather dubious assumptions I estimate that
> from a star like Betelgeuse approximately 10^6 photons are going into your
> eye per second.  This is about the same as a 100 W light bulb 10 km away.
Interesting. Perhaps bizarrely, I know exactly what Betelgeuse looks like to the
naked eye, but not a lightbulb 10km distant!
What are your dubious assumptions? This is just the sort of 'sensible
guesstimation' calculation I used to enjoy at university. :)
Date: 2 Dec 2009 05:27:43
Message: <4b16411f$1@news.povray.org>
That all the energy from the star/light bulb comes out equally in all
directions in the form of 550 nm photons, and your eye has an opening of 2mm
x 2mm.
Obviously all the energy doesn't come out as visible photons, and you could
probably do something clever with the spectrum to get a more accurate
figure.
Date: 2 Dec 2009 05:30:21
Message: <4b1641bd$1@news.povray.org>
> 2mm x 2mm.
> could probably do something clever with the spectrum to get a more
> accurate figure.
To say nothing of the absorption and scattering of the Earth's atmosphere...
Date: 2 Dec 2009 06:15:01
Message: <web.4b164b746ad665b96dd25f0b0@news.povray.org>
> > 2mm x 2mm.
> > accurate figure.
Probably not nearly as important as the error introduced by assuming both star
and bulb emit only in the visible.
Otherwise, not such dubious assumptions at all!
Date: 2 Dec 2009 06:18:32
Message: <4b164d08$1@news.povray.org>
Well, at least he didn't say an LED or a flourescent tube or something
with a complex emission system. A normal light bulb and a star are
(AFAIK) both simple black body radiators, so you just need to know their
colour temperature...
Date: 2 Dec 2009 07:00:01
Message: <web.4b1656226ad665b96dd25f0b0@news.povray.org>
That just tells you the peak power output. The total power output might not be
as much as an order of magnitude different, but it will be different.
In any case, for a lightbulb, less than 10% of that 100W will be visible. An LED
or fluorescent tube will emit mostly in the visible, so the power will be much
more accurate for this comparison.
Date: 2 Dec 2009 07:14:29
Message: <4b165a25$1@news.povray.org>
I was under the impression that the colour temperature tells you roughly
how the signal power is distributed over the whole spectrum. (Initially
just IR, then red as well, and gradually more high frequencies, while
the power at lower frequences decreases.)
Yeah, both stars and lightbulbs presumably put out far more IR and radio
waves than visible light...
Date: 2 Dec 2009 07:35:01
Message: <web.4b165dd96ad665b96dd25f0b0@news.povray.org>
Roughly, in that it tells you where the peak is and the general shape of the
rest of the spectrum.
Actually, many stars peak in the visible - Betelgeuse is red. Ours is yellow. I
think maybe lightbulbs peak in the IR (lower temperature), so all we see is a
section of the tail of the spectrum.
http://en.wikipedia.org/wiki/Black_body
Date: 2 Dec 2009 08:06:30
Message: <4b166656$1@news.povray.org>
Sure. So if you know how hot the star is, you know roughly the shape of
the entire emission spectrum. :-)
The peak is just the single wavelength at which there is the most
energy. I think if you look at *bands* of the spectrum, it's possible
for a wide band with low energy at any specific single wavelength to
have a greater total power and a band containing only a single
high-power (but narrow) peak.
Date: 2 Dec 2009 08:11:02
Message: <4b166766$1@news.povray.org>
How can you have a "wide band" at a specific single wavelength?  Surely the
definition of a "band" is a range of wavelengths?
Sure, if the peak is at 600 nm, then the energy in the band from 599.99 to
600.01 will most likely be less than the band from 100 to 599.
