POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
5 Jul 2026 07:03:40 EDT (-0400)
  Trivial trigonometry (Message 141 to 150 of 178)
Subject: Re: Trivial trigonometry
Date: 3 Dec 2009 13:37:55
Message: <4b180583@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> As I said, the probability of finding a particle in a particular place is
> based on multiplying complex numbers.
  Btw, I find it curious how you use the mathematical models as some kind
of evidence that photons are not waves. After all, Feynman himself stressed
that his formulation is merely a mathematical description, not an attempt to
describe a real process that we cannot meassure.
Date: 3 Dec 2009 13:41:50
Message: <4b18066e@news.povray.org>
> Warp wrote:
> >   Schrodinger's cat is a thought experiment, not an analogy.
> It's not even that hard to set up. :-)
> I think the point is that you have to question what an "observation" is. If
> the particle gets emitted and runs into the detector when the power is
> turned off, is it "observed"?  If the power is on but the detector isn't
> connected to anything?  If it's connected to a speaker you can't hear? If
> it's connected to poison but there's no cat in the box?  Etc?
> In other words, if it takes an "observer" to collapse the wave function, is
> the cat enough of an "observer" to count? If so, how does the human get
> involved? According to the math, the cat is still superimposed. But that
> would imply the cat isn't sufficiently an observer to cause the collapse.
> *Or* that the math doesn't match reality. And multi-worlds is an attempt to
> say "no, the math really matches reality."
  AFAIK those are the things Erwin Schr?dinger questioned about the
Copenhagen interpretation with his now-famous thought experiment.
Date: 3 Dec 2009 14:52:26
Message: <4b1816fa$1@news.povray.org>
I believe you misunderstand me. I'm saying we never observe a wave. We just
observe math that's the same math as a wave. That isn't what makes it "not a
wave", that's what makes people used to think (and some people still think)
it was a wave. :-)
I.e., just the opposite. The mathematical model is *not* evidence it's a
wave, any more than the interference patterns are.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 3 Dec 2009 14:53:34
Message: <4b18173e$1@news.povray.org>
Yes. I'm agreeing with you, and hopefully adding some more to the discussion.
Date: 3 Dec 2009 16:33:40
Message: <4b182eb4@news.povray.org>
  I don't really know your definition of "evidence", but as I understand it,
the interference pattern *is* evidence for it to be wave. It's not *proof* of
it, but evidence is no proof anyways.
Date: 4 Dec 2009 06:56:42
Message: <4b18f8fa$1@news.povray.org>
> Except that's exactly the point. The math says it's the latter case. And
> the cat experiment is to point out how absurd that conclusion is. Hence,
> the math must be mistaken.
What happens if you shut the double-slit experiment away in a box, with
photon detector attached to each slit?  Will the interference pattern still
be generated?
Date: 4 Dec 2009 11:32:05
Message: <4b193985$1@news.povray.org>
>> And the cat experiment is to point out how absurd that conclusion is.
>> Hence, the math must be mistaken.
> still be generated?
No.  Worse, check out this:
http://en.wikipedia.org/wiki/Wheeler%27s_delayed_choice_experiment
Basically, the photon behaves differently even if you measure it *after* it
has passed through the slits. Which is why it's pretty safe to assume it's
not "going thru both slits" when you get the interference pattern.
http://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser
This one changes whether the photon went thru one or both slits *after* it
has already been detected. Hard to see how that's the behavior of a wave
that passes through both slits.
Date: 7 Dec 2009 02:48:11
Message: <4b1cb33b$1@news.povray.org>
>> still be generated?
> it has passed through the slits. Which is why it's pretty safe to assume
> it's not "going thru both slits" when you get the interference pattern.
But put the whole thing inside a big closed box so nobody can observe the
patterns (exactly like the cat in a box setup).  If a cat's status is not
decided until someone looks inside (even though there is a particle detector
and related mechanisms inside) then why should the interference pattern not
be there if nobody is observing it?
Date: 7 Dec 2009 11:00:25
Message: <4b1d2699$1@news.povray.org>
scott wrote:
> If a cat's status is not decided until someone looks inside
Since that isn't true, it's a meaningless question to ask.
Date: 7 Dec 2009 11:18:49
Message: <4b1d2ae9$1@news.povray.org>
I thought the whole point of that experiment was that according to QM the
cat was both alive and dead until you actually tried to look?  Maybe
something changed since I read about it?
