SharkD wrote:
> On 11/19/2009 11:17 PM, Darren New wrote:
>> http://3laws.wordpress.com/2009/08/03/you-will-fail-at-everything-forever/
> An Energy Star rating for software maybe...
> I should write my congressman. :)
Is there actually a tangible difference in a person's electric bill (due
to less energy actually being consumed) when they run a low-CPU program
over the course of two hours vs. running a CPU-intensive program over
the course of two hours?
Tim Cook
http://empyrean.freesitespace.net
Nicolas Alvarez wrote:
> Some people said the world doesn't have enough currency to buy the needed
> bad code offsets to compensate for the world's bad code.
Have you *seen* our project management system?!?
Yes. But don't tell my mom, or she will make me stop my 24/7 100% CPU usage
(she pays the electricity bill).
Last time I clocked it, having my PC running uses about 200W. So, about
the same as two light bulbs.
The kettle, on the other hand, uses OVER THREE THOUSAND WATTS of power. o_O
(I also noted little or no difference in power usage between an idle PC
doing nothing and the same PC with the CPU and GPU both maxed out.
Although I have a bigger GPU now...)
... which you have powered on for how long each day?
>> about the same as two light bulbs.
>> power. o_O
The kettle uses more power in 1 minute than my computer uses in 1,000
minutes ( = nearly 17 hours).
The kettle probably takes approximately 1 minute to boil, and with the
amount of tea my mum drinks, the kettle probably burns through multiple
kWh per day - my PC would have to be on 24/7 for a week or two to
compete with that.
Bah it's winter, both heat up your house thus saving on heating so I
wouldn't worry :-)
> wouldn't worry :-)
Absolutely! Altough my PC heats the building more efficiently than the
kettle, for at least the following reasons:
- The water's phase change from liquid to vapour uses a large amount of
energy for a small change in temperature.
- The kettle is extensively insulated to facilitate rapid heating of the
water. My PC, on the other hand, has special fan systems especially
designed to *dissapate* heat. ;-)
I have noticed that within 30 minutes of turning my PC on, my bedroom
>>> power. o_O
YOU FAIL BASIC MATH! >_<
http://blog.orphi.me.uk/
>>>> power. o_O
Or you are using a pocket calculator.
