![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Suppose that the first derivative of f(x) is g(x).
What the hell is the derivative of f(f(x))?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.google.com/search?q=What+is+the+derivative+of+a+composite+function%3F
http://en.wikipedia.org/wiki/Chain_rule
Basic high-school level math. I am slightly surprised that you did not
know it, though I am not in the least surprised that you did not bother to
google for it.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> know it,
What, you mean given that I've never been tought mathematics?
> to google for it.
Oh, I did Google it. I just didn't comprehend the answer. (In
particular, I've already read the Wikipedia entry.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What is so difficult to understand about it? I thought function
composition would be one of the areas of math that you were actually good
at, given your fanatical obsession with a certain functional programming
language.
Anyway:
The derivative of f( g(x) ) is f'(g(x))*g'(x).
Substitute the inner function into the derivative of the outer function,
and then multiply by the derivative of the inner function.
In your example, we want the derivative of f(f(x)) (i.e. the outer and
inner functions are the same), and we know that f'(x) = g(x) (try not to
mix up all the f's and g's).
df(f(x))/dx = f'(f(x))*f'(x) = g(f(x))*g(x)
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
One formula appears to say the derivative is f(x) * g(x), and another
appears to say it's f'(g(x)) * g'(x), which is different, but these are
supposed to be different notations for the same formula...?
> I thought function
> good at, given your fanatical obsession with a certain functional
> programming language.
Function composition I get. It's what that does to the derivating I
can't quite wrap my brain around.
> Anyway:
Right. So basically, the function I'm looking for is f'(f(x))*f'(x)?
So presumably the derivative of f(f(f(x))) is going to be something like
f'(f(f(x))) * f'(f(x)) * f'(x)? And in general, the Nth composition will
be ever more complex as N increases?
Oh dear.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to google for it.
...what I *should* have done of course is
http://www.wolframalpha.com/input/?i=derivative+f(f(x))
*facepalm*
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Oh dear.
Ooo, but wait... The Nth derivative of a polynomial will be zero if N
exceeds the order of the polynomial. Hmm.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> like f'(f(f(x))) * f'(f(x)) * f'(x)? And in general, the Nth
>> composition will be ever more complex as N increases?
>> Oh dear.
...which doesn't help, because the derivative of the Nth iterate will be
f'(x) * f'(f(x)) * f'(f(f(x)) * f'(f(f(f(x))) * ...
which involves only the first derivating of f and the iterates of f.
Damnit, I really suck at math. :'{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
D f[n](x) = D f[n-1](x) * f'(f[n-1](x))
Maybe this isn't so bad...
Or maybe I just need to GROW A FRIGGIN' BRAIN! >_<
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The first one is obviously wrong, unless you mixed up all the f's, g's and
little circles. It is difficult to tell without context.
Yes.
> And in general, the Nth composition will be ever more complex as N
> increases?
Yes.
Except that it is the wrong answer, or rather the wrong question. Wolfram
thought you meant (f <dot> f)(x), when what you actually meant was (f
<circle> f)(x).
Just one more reason why it is better to learn the formulas yourself
instead of relying on a computer to help you all the time.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
